CFSAVVY
Amazon Cloud hosting?
Apr 4, 2011 2:22 PM
Dear Colleagues:
Does any of you know, or have experience with hosting a CF application in the Amazon Cloud? Do they have CF licenses for monthly rent under a hosting plan, or do you need to provide your own license and server maintenance? I seem not to be able to find this info, where a seasoned IT/Internet person suggested it to be a possibility (hosting, that is, other than CF of which he knew nothing).
Hope to hear from you.
Hans
    Apr 4, 2011 2:33 PM   in reply to CFSAVVY
    I can't say anything about rent and|or hosting plans that utilize the Amazon Cloud.
    But IIRC, the new EULA for ColdFusion 9 specifically mentions how the license applies to deploying on the Cloud.  So it should be possible some way or the others.  But I know nothing about the details.
    Mar 26, 2013 1:07 PM   in reply to CFSAVVY
    I am planning a similar approach, moving ColdFusion to the Cloud on Amazon EC2. I need to be able to scale adding more web servers with CF on it.
    Did you implementing it? any advices?
    Mar 27, 2013 5:21 PM   in reply to mistermaikcr1
    For scaling you can use elastic load balancer, add webservers or additional app servers. But it is important that you validate your architechture with your application first, depending on the traffic you are expecting.
    In general  its a good practice to use either relational or NoSQL database to handle authentication/client management. Ideally you should be looking at a seperate DB server for scalability and easier maintainance. You can use services provided by Amazon like RDS or of your choice (refer https://aws.amazon.com/running_databases/). However if the setup is small you can use the MySQL DB available with ColdFusion's AMI
    Anit Kumar
    Apr 3, 2013 1:04 PM   in reply to CFSAVVY
    I have Railo running in AWS (Elastic Beanstalk) and it works great. Just don't forget to enable Termination Protection or any changes you make will be blown away in the event of a service disruption.
    Just got my bill for hosting in March (with an email server and MSSQL instance) . $1.61. One dollar and sixty one cents.
