Choppy Transitions
Mar 28, 2013 Mar 28, 2013
I am using FM 11 on Win 7 Pro 64-bit.
Whenever I run a published project, the transitons between slides are choppy.  Specifically, the transition starts, then the window blinks, then the transition completes.  It does not matter which transition I use, even NONE does the same thing.
Strangely, if I jump to the next slide through a command (custom button, Flash UI) before the end of the slide, its runs smoothly.  It is also fine if I have an interactive item on the screen that waits for user input before moving on.
Can anyone tell me why?  Better yet, how to make it a smooth transition?  Is there a file someplace that could be modified to control the transition?
Thanks.
982
"Transitions"? You talking FM here? Sounds more like Captivate or PowerPoint ;>)
Sadly, yes.  Wrong forum.  Just a habit.
Good, because I was thinking I was lacking a total understanding of the concept if it was FM ;>)
I wonder if dcrouse10 is talking about an embedded Captivate / PowerPoint file that has been output to PDF?
Paging dcrouse10! Paging dcrouse10!
