Hi all,
I developing a mobile application support working offline. I using cache feature of LiveCycle Data Services.
This is my datasevice ( it has associate to others dataservice ) and autoSaveCache = true and cacheID = "xxx":
<destination id="expenseData">
<properties>
<source>expense.ExpenseDataAssembler</source>
<scope>application</scope>
<item-class>expense.ExpenseData</item-class>
<metadata>
<identity property="id" />
<one-to-many property="expenseItems" destination="expense-item" />
</metadata>
</properties>
</destination>
when I run application in the first, it run nomarly but when I close and run it again , i get the errror message as below :
Error: Object instance needs an mx_internal::referencedIds property inorder to be managed: Object
at mx.data.utils::Managed$/getReferencedIds()[C:\depot\DataServices\branches\milestone\adepds46_rc\frameworks\projects\data\src\mx\data\utils\Managed.as:292]
at mx.data::DataStore/restoreAssociations()[C:\depot\DataServices\branches\milestone\adepds46_rc\frameworks\projects\data\src\mx\data\DataStore.as:5010]
- The error message not showed when I remove line <one-to-many property="expenseItems" destination="expense-item" /> .
Please help me if you know about this problem.
Thanks so much.
Total Likes
no body help me !!!
Total Likes
Please share the valueObject(java and .as) classes and the complete dataservice config file.
Total Likes
