Hi everyone, I'm Lucas. I Have learnt how to deliver a single live video stream to both Flash and iOS from this video
But after that I got a problem with the ".f4m" file and ".m3u8" file (I think) like this video below here. I don't know what happen with the server because my camera is still working perfectly.
I now using Flash Media Server 4.5
Does anyone know how to fix it?
What are the specs of the computer that does the enoding?
I'm now using
Motherboard: ASUS P6X58D
RAM: 4GB
Video Card: FirePro 3D Graphic Card V5800
Windows 7 Home 64 BIT
On your encoder you see that the video is correct?have you tried streaming to live instance or only to livepkgr?
I've tried streaming like that Tutorial Video and this http://help.adobe.com/en_US/flashmediaserver/devguide/WSd391de4d9c7bd609-52e437a812a3725dfa0-8000.ht...
but it seems like the link http://localhost/hds-live/livepkgr/_definst_/liveevent/livestream.f4m has a problem with the server... I just don't know why and how to fix it
Try this :
1: stop any stream.
2: go to root_install\applications\livepkgr\events\_definst_\liveevent and delete any .stream file that is in there
3: Go to root_install\applications\livepkgr\streams\_definst_ any livestream folder that is in there for example if you streamed with name livestream12 there should be a folder with the name livestream12, delete it.
4: Then try streaming a single bitrate stream by adding to the FMLE the following parameters
FMS Url : rtmp://localhost/livepkgr
Stream: livestream?adbe-live-event=liveevent
5: go to sample player and add this url to the field : http://localhost/hds-live/livepkgr/_definst_/liveevent/livestream.f4m
*If you have a public IP do the following :
1: go to http://www.osmf.org/configurator/fmp/#
and add this url : http://public_ip/hds-live/livepkgr/_definst_/liveevent/livestream.f4m (replace localhost with your public IP)
and from the advanced tab say that it is live.
Give it a try!
thank you so much!! Everthing is working perfectly now!!!
To avoid these problems, when you are going to stop the stream do again the cleaning procedure and for the next streams use for the stream value on the FMLE this : livestream?adbe-live-event=liveevent&adbe-record-mode=append.
