I'm trying to install Illustrator from the installation disk. The installation requests that Disk 1 be inserted into drive L. My optical drive letters are D and G. How can I coerce the program to use an actual dvd/cd drive?
if you have any software mounted drives, you could try removing those.
or, you could work around the problem by downloading the installation files: http://prodesigntools.com/download-adobe-cs4-and-cs3-free-trials-here.html
if you dl the trial, you must follow all 7 steps. your serial number will activate.
RequestURI=/support/downloads/dlm/main.jsp
you MUST follow all 7 steps.
What part of HTTP error 404 has the seven steps???
A 404 error means the page is unavailable.
The fact is, the page that you put a link to is not there!
The 404 means you have not followed the Very Important Instructions on the prodesigntools page before clicking the download links.
The 7 steps are crucial for setting the correct cookies on your hard drive so that the Adobe servers will grant you access to the download files when you click the links.
So:
the links all work IF you read and follow each of the 7 steps.
so again, read each of the 7 steps and then follow each of the 7 steps.
kglad
I did what you instructed. I received 2 files for the Illustrator CS3 download.
Now I have 2 files with no file extensions that I can do nothing with.
I have ADBEILSTCS3_WWE and ILSTCS3_Cont_WWE.
I also have the Adobe Download Assistant.exe.
What do I do with these *_WWE files now?
1. are you using a mac or pc?
2. did you download the mac files or the pc files?
