This has been troubling me for awhile and can't seem to find the correct answer.
Yea so how I access a MovieClip's timeline when using that MovieClip in another class?
MovieClip(root).anotherClassInstance.gotoAndPlay("someFrameLabel");
for this to work both classes (the calling and the called) must be added to the DisplayList
(use Event.ADDED_TO_STAGE for this)
Okay so let's say my MovieClip is called "Run" and the class I'm in is called "Main"
MovieClip(Run).run.gotoAndPlay("1");
Would that be right?
MovieClip(root).Run.gotoAndPlay(1);
Ah I see Erm so let's say this is my main class. Would this be correct on how to access it.
package
import flash.display.*;
public class Main extends Sprite
private var _run:Run;
public function Main()
addChild(_run);
MovieClip(root).Run.gotoAndStop(1);
_run.x = stage.stageWidth / 2;
_run.y = stage.stageHeight /2;
there is no need to call a child of the main class via root.
in your case you would write simply:
_run.gotoAndStop(1);
say you have a class called button.as, and you wanted to play the _run instance from there if you click it, the you would this syntax:
public class button extends Sprite
public function button()
addEventListener(MouseEvent.CLICK, startRun);
public fucntion startRune(e:MouseEvent):void{
MovieClip(root)._run.gotoAndStop(1);
TIP:
Be clear about the differences of classes, instances and instance names in as3.
Run is the class
_run is the instance(object)
the descriptor of the instance and the name (what it is called) are not the same
if you don`t assign a name to an instance flash/FB will do that automatically for you (for example "instance123"), but the problem is, the moment you generate multiple instances the descriptior alone becomes useless to reference an object
I tried that but I must be doing something else wrong, I think this is what I need to know the most in FB as I imagine MC's are needed in all games. I've only made small one's where everything can go in one class.
Okay this my main Class.
package
public class Classy extends Sprite
public function Classy()
//By doing this the MC appears on stage but it just cycles through all the different animations.
_run = new Run();
addChild(_run);
_run.x = 275;
_run.y = 200;
//If i try this it doesn't regonise the _run as a MC, as it's to the one with the timeline.
//This causes it to go to debug mode.
MovieClip(root).gotoAndStop(1);
And this is my other class with the MC.
package
public class Hero extends Sprite
[Embed(source="../swfs/movement3.swf", symbol="Run")]
private var Run:Class;
private var _run:MovieClip = new Run();
public var vx:int = 0;
public var vy:int = 0;
public function Hero()
this.addChild(idle);
Sorry I think I'm being a tard >_< ..If you could just show me on that how to access it, I would be so greatful, as I asked around on Newgrounds and no one seemed to respond or give a definate answer. Where as I thought everyone would know how to do it and show and tell.
1.if you work with classes that have or access other timelines don`t extend Sprite, but extend MovieClip;
A Sprite object is similar to a movie clip, but does not have a timeline.
I don`t really understand why you would instantiate Run in two different classes.
What is Hero? Is that your player figure and has it a running state or sth?
What are you trying to achieve?
Also its hard to see if you abbreviated code in your classes (deliberately left it out) or if its missing.
A line like this
can never work in the context you show without having idle somewhere defined.
Attach a screenshot that shows the timeline of your "Run"- Symbol.
That was meant to say "this.addChild(_run)"
I'm trying to achieve the fact that I want to make a bigger game and having my character/enemie's etc in a different class would shrink down code in the main class.
"Hero" is just a class which has my main character, The embedded file has around 24 different animation states.
I just want to access those from another Class.
At the moment I have too few information to give you helpful advise.
How do you achieve the animations of your Hero-Character? Do you use labeled frames?
Or a special game framework like Flixel, CitrusEngine? Do you have stop fames/switches on the timeline of your Run symbol to keep the chjaracter from looping through all animations?
Do you use spritesheets?
Why don`t you add an instance of hero to your document instead of a Run instance?
My original advise, that is nowhere to be found in the code you showed:
if you don`t make sure the instance is present at stage, a call lieke gotoandStop... will never work.
addChild(_run) is not enough to ensure run is actually added to stage when you call gotoAndStop..
stands
Sorry yea had a break from AS3 for a couple of weeks mind seems to have gone blank, but yea I'll try it the way you originally said and get back to you, thanks for your help.
Okay.
I used ADDED_TO_STAGE and got it working
This is my main Class.
package
import flash.events.Event;
[SWF(width="550", height="400",
backgroundColor="#FFFFFF", frameRate="60")]
public class Game extends Sprite
private var _hero:Hero;
public function Game()
_hero = new Hero(stage);
stage.addChild(_hero);
_hero.x = 275;
_hero.y = 200;
My hero Class:
package
import flash.events.KeyboardEvent;
import flash.ui.Keyboard;
public class Hero extends MovieClip
[Embed(source="../swfs/movement3.swf", symbol="Idle")]
private var Idle:Class;
private var idle:MovieClip = new Idle();
//Stage reference
private var _stage:Object;
//Movement variables
public var leftPressed:Boolean = false;
public var rightPressed:Boolean = false;
public var upPressed:Boolean = false;
public var downPressed:Boolean = false;
public function Hero(stage:Object)
_stage = stage;
this.addEventListener(Event.ADDED_TO_STAGE, addedToStageHandler);
private function addedToStageHandler(event:Event):void
startGame();
idle.gotoAndStop(1);
this.removeEventListener(Event.ADDED_TO_STAGE, addedToStageHandler);
public function startGame():void
_stage.addEventListener(Event.ENTER_FRAME, enterFrameHandler);
_stage.addEventListener(KeyboardEvent.KEY_DOWN, keyDownHandler);
_stage.addEventListener(KeyboardEvent.KEY_UP, keyUpHandler);
public function enterFrameHandler(event:Event):void
//Move the hero
idle.x += vx;
idle.y += vy;
//Move 8 directions with different animations.
if(upPressed)
if(rightPressed)
idle.gotoAndStop(6);
vy = -4;
vx = 4;
else if(leftPressed)
idle.gotoAndStop(7);
vy = -4;
vx = -4;
else
idle.gotoAndStop(5);
vy = -4;
if(upPressed)
vy = -4;
vx = -4;
else if(downPressed)
idle.gotoAndStop(8);
vy = 4;
vx = -4;
else
idle.gotoAndStop(3);
vx = -4;
else if(rightPressed)
if(upPressed)
vy = -4;
vx = 4;
idle.gotoAndStop(9);
vy = 4;
vx = 4;
else
idle.gotoAndStop(2);
vx = 4;
if(rightPressed)
vy = 4;
vx = 4;
vy = 4;
vx = -4;
else
idle.gotoAndStop(4);
vy = 4;
public function keyDownHandler(event:KeyboardEvent):void
if (event.keyCode == Keyboard.LEFT)
leftPressed = true;
else if (event.keyCode == Keyboard.RIGHT)
rightPressed = true;
else if (event.keyCode == Keyboard.UP)
upPressed = true;
else if (event.keyCode == Keyboard.DOWN)
downPressed = true;
public function keyUpHandler(event:KeyboardEvent):void
if(event.keyCode == Keyboard.RIGHT)
vx = 0;
rightPressed = false;
idle.gotoAndStop(21);
else if(event.keyCode == Keyboard.UP)
vy = 0;
upPressed = false;
else if(event.keyCode == Keyboard.LEFT)
vx = 0;
leftPressed = false;
idle.gotoAndStop(20);
else if(event.keyCode == Keyboard.DOWN)
vy = 0;
downPressed = false;
idle.gotoAndStop(19);
Thanks for you help and pateince, i know the main class doesn't have an ADDED_TO_STAGE but my "hero" moves and appears as he should. Thanks again.
Congrats for your persistence!
if you will later on in your project use a external preloader to load your game:
this line in your document class will not work any longer:
just to give you a heads up
Oh really how come?
Do you mind me asking but are you a "Flash Developer"?
The contructor of your Game will be immediately called when the preloader starts to load it.
a swf can only acces the highest Object in the hierarchiy (the stage object), if it is part of the display list,
which will not be the fact when you start preloading your Game.swf, but only when you finished.
So the compiler will throw en error.
I use FlashDevelop for coding.
Ah really, if I create my own Internal Preloader will everything be good?
I mean to you have a proffesional job doing Flash coding etc. Just wondered as you've been a member since 2008.
Good luck with that 😉
Yes, working professionally with flash since 2007
Ah congrats , it's what I want to do ..eventually. Hopefully by the end of the year or sooner.
Quick question is it possible to fire "bullet's" in 8 directions with keyboard. I can get the character to move in all 8 directions with different animations etc
but when i use the same principles of coding for firing bullets, he still can only do up down left and right. I read it might be something to do with pressing the
RIGHT, UP and SPACE key at the same time.(well three keys at once)
Here is a KeyManager class that should do the trick (not from me):
package com.snepo.utils
* @author Andrew Wright
import flash.display.Stage;
import flash.events.*;
import flash.utils.*;
public class KeyManager extends EventDispatcher
protected static var stage : Stage;
protected static var enabled : Boolean = true;
protected static var pressedKeys : Dictionary = new Dictionary();
protected static var _sharedKeyManager : KeyManager;
public static function init ( stage : Stage ) : KeyManager
if ( !sharedKeyManager ) _sharedKeyManager = new KeyManager ( stage );
return sharedKeyManager;
public static function get sharedKeyManager ( ) : KeyManager
return _sharedKeyManager;
public function KeyManager ( stage : Stage ) : void
stage.addEventListener ( KeyboardEvent.KEY_DOWN, handleKeyDown );
stage.addEventListener ( KeyboardEvent.KEY_UP, handleKeyUp );
KeyManager.stage = stage;
super ( this );
protected function handleKeyDown ( evt : KeyboardEvent ) : void
pressedKeys [ evt.keyCode ] = true;
dispatchEvent ( evt.clone() as KeyboardEvent );
protected function handleKeyUp ( evt : KeyboardEvent ) : void
delete pressedKeys [ evt.keyCode ];
public function keysPressed ( keys : * ) : Boolean
var validCombo : Boolean = true;
if ( !(keys is Array) ) keys = [keys];
for ( var i : int = 0; i < keys.length; i++ )
if ( !pressedKeys [ keys ] ) return false;
return true;
public static function keysPressed ( keys : * ) : Boolean
return sharedKeyManager.keysPressed ( keys );
//USAGE
/*import flash.ui.Keyboard;
import com.snepo.utils.KeyManager;
var km : KeyManager = KeyManager.init( stage );
km.addEventListener( KeyboardEvent.KEY_DOWN, checkForCombo );
function checkForCombo ( evt : KeyboardEvent ) : void
if ( KeyManager.keysPressed( [ Keyboard.UP, Keyboard.SPACE ] ) )
//put your code here
