I am having some strange issues when publishing using html5 and then viewing the captivate content on the ipad after creating an app using DPS...
here is the captivate project: you can see everything fits inside the 500X500 file project size
Here everything views correctly in the browser....with the error message displaying correctly and the text in the top right in the correct font and format
here you can see a screen shot from the ipad...now the error message is visible barely in the top left corner (you can see a small red rectangle) and the text in the top left corner is now no longer in the correct font...any ideas as to why?
also is there any way to have the html5 background be "blank" so that it inherits the color or image behind it???
thanks
Hi there,
Does your project look fine if you open the index.html on I-pad? I mean without creating an app using DPS.
You can change the color of HTML background from Skin editor > borders, but it cannot be transparent or blank.
Thanks.
No it doesnt...it appears correctly when I view it locally in my browser but when I view it after uploading the files to the server and viewing online I have the same problem...
here you can see the feedback as a tiny square in the top left corner and the font in the top right doesn't display correctly....any ideas?
