Hello ,
When I copy something in Framemaker, including copy specials, 90% of the time it will not copy and I end up pasting whatever is last on the clipboard.
If I then copy it again, it works.
It sounds like nothing, but at the moment my life is spent Ctrl-c, Ctrl-v, Ctrl-z, Ctrl-c, Ctrl-v, Ctrl-zzzzzzz.
Anyone seen this behaviour before?
Skype is known to mess up the clipboard when working with FM; now that MSN has been retired in favour of Skype, you may have and not realize it.
Hmm.
I use msn via Trillian, so maybe that is it.
I'll give it a trial without Trillian.
Yes, and on more than just Windows.
Apart from "helpful" apps stealing keycodes, and perhaps not passing them on if they aren't for that app ...
My impression is that paste-fail can be caused by the copy operation being incomplete at paste. This can happen for any number of reasons, including but not limited to:
A work-around that seems to avoid the paste-fail is to perform the copy using the app's own menu tools, Edit > Copy in FM's case.
This is indeed a work-around, thanks.
Glad you mentioned that: it spurred me to kill off the W*ws shortcut that used to dash in, grab some Photoshop/Illustrator keystrokes and change the keyboard mapping while I'm not looking. Worst of it was, the switch from AZERTY to QWERTY replaces ctrl+z – which I'll admit I need from time to time – with ctrl+w: pretty well the opposite of what I want to do!
N
This happens to me regularly after vmware Fusion Tools crashes. Not a problem with FM, really, unless FM is responsible for the crash...
