I've downloaded and installed Robohelp 10, but can't find it anywhere. How can I find it to work with it? Thanks!
Which operating system?
Moving this discussion to the RoboHelp forum.
@Jeff - should have put this one in the TCS installation forum
@showonroad - probably found in c:\program files\adobe\adobe robohelp 10\robohelp\ - look for RoboHelpHTML.exe
Thanks Jeff but it does look like that forum is not set up to allow posts to be moved to them. Unless you are referring to http://forums.adobe.com/community/framemaker/techcom_suite_installer?
yes, that's the one - maybe Arnis is a moderator for that one
Why should this be in the TCS Installation forum if the poster has only downloaded Rh10
@showontheroad. By design Rh does not create any desktop icons but you should find it in the start menu, probably under Adobe. I don't have a machine with just Rh rather than the full Technical Communication Suite but I am reasonably certain that is where it will be found.
If not, then as Jeff_Coatsworth has covered, you can find the exe and then use Send To > Desktop as Shortcut.
My bad. I hadn't seen the complete thread and reacted to Jeff's messages. Sorry.
@Peter - I'm slightly lost with this shuffle - there aren't any specific FM or RH installation issue forums except the TCS one (I believe that was because there isn't a standalone download path for either product these days, but I haven't checked that out)
I can't move it either Jeff. It must have gotten munged during the changeover last week.
[Found it. The entry was moved out of the FM forum levels and as a separate TechComm Suite entry]
