I cannot update Camera Raw in PS CS5. I tried both, via the menue in PS and the patch installer (I've already deactivated the firewall) - both fails with the update. I'm running on Lion 10.8.2.
Hi CatDiva
Please see the suggestions on below forum : http://forums.adobe.com/thread/1192032
Hope it helps !
I've read the thread, thanks. I don't have a file "AdobeUpdaterAdminPrefs.dat" in this library - I have found the path, but not such file.
I've updated the Adobe Application manager and it says now after failed installation:
Adobe Bridge CS5 4.0.5 – Aktualisierung
Installation fehlgeschlagen Fehlercode: U44M1P7
Update für Adobe Extension Manager CS5 5.0
Photoshop Camera Raw 6.7-Update
Photoshop 12.0.4-Update für Photoshop CS5
Adobe Device Central CS5.0.1
Please See below links for Error Code U44M1P7 : http://helpx.adobe.com/creative-suite/kb/error-u44m1p7-installing-updates-ccm.html
http://helpx.adobe.com/photoshop/kb/photoshop-cs6-updates-dont-install.html
Sorry, I'm a user, not a programmer, I feel a little lost trying to analyse installation log files .... This is what I get in the last installer logfile (I've tried several times to to this manually)
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 10 error(s), 0 warning(s)
----------- Payload: {4E1B59A1-029E-4C16-BBB3-F10D40EBB6EE} Photoshop Camera Raw_6.7_AdobeCameraRaw6.0All 6.7.0.0 -----------
ERROR: DF006: The path "/Applications/Adobe" already exists and is not a directory, Please rename or delete and retry(Seq 1)
ERROR: DF016: Unable to create directory "/Applications/Adobe/AdobePatchFiles" with mode 775(Seq 1)
ERROR: DF006: The path "/Applications/Adobe" already exists and is not a directory, cannot create path "/Applications/Adobe/AdobePatchFiles",Please rename/delete "/Applications/Adobe" and retry(Seq 1)
ERROR: DW063: Command ARKCreateDirectoryCommand failed.(Seq 1)
----------- Payload: {CC43F132-5096-41FC-A5C2-69E4202AC114} Camera Profiles Installer_6.7_AdobeCameraRawProfile6.0All 6.7.0.0 -----------
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Photoshop Camera Raw_6.7_AdobeCameraRaw6.0All: Install failed
ERROR: DW050: - Camera Profiles Installer_6.7_AdobeCameraRawProfile6.0All: Install failed
Please search the above error/warning string(s) to find when the error occurred.
These errors resulted in installer Exit Code mentioned below.
Exit Code: 7 - Unable to complete Silent workflow.
Please see specific errors and warnings for troubleshooting. For example, ERROR: DF006, DF016 ...
END - Installer Session
So is there any possibility to get help for this issue. I am not keen on reinstalling Photoshop, I've got several upgrades in PS and plugins (Neatimage, Coloreffex, machinewash ...) running. It would be a pain to reinstall everything.
From the portion of the installation log which you have posted it appears you have file permission issues with the Applications/Adobe folder. You can try to adjust the file permissions on Applications/Adobe and apply those permission changes to all enclosed objects. You can find more details on how to accomplish this at Error "Exit 6" or "Exit 7" | Install log | Read, write, system file errors | CS5, CS5.5 - http://helpx.adobe.com/creative-suite/kb/error-exit-6-exit-7.html.
