Glossary interaction will not save or publish
Apr 30, 2013 10:07 AM
Tags: #error #publish #glossary #interactions #adobe_presenter #presenter_8
I cannot get the Glossary interaction to publish. I can upload the XML and it appears on the PPT slide. But when I publish I get the default template with no text.  When go back to edit the interaction its set to the default and the changes I made to the template and the uploaded XML are not there.
I am using version 8.0.1 Build 260.
Any help would be much appreciated.
Robert
    Apr 30, 2013 1:51 PM   in reply to rpanetti
    Hi Rpanetti,
    Thank you for contacting Adobe.
    I think the problem is with the XML file that you are trying to import.
    Please try to add word inside GLOSSARY and then try to publish the output.
    Loveesh
    May 1, 2013 10:37 AM   in reply to rpanetti
    Hi Rpanetti,
    Thank you for your reply.
    Can you please check your P.M. as we have requested some details from you.
    Loveesh
    May 15, 2013 1:18 AM   in reply to rpanetti
    Hello,
    We checked the issue and there is no immediate workaround which we can offer to solve your problem.
    For the time being, you can split the content into multiple glossary interactions containing around 100 terms each.
    This should work.
    Mukul
    Adobe Presenter Engg. team.
