install CS5 extended on Imac
Apr 30, 2013 Apr 30, 2013
how do I install CS5 extended on my new iMac?  I have read to download trial version then add in serial number - but I cannot find a trial version of CS5 extended.
900
Community Expert , Apr 30, 2013 Apr 30, 2013
these are the only cs5 programs available via adobe or its affiliate prodesigntool.com
if you follow all 7 steps you can dl a trial here:  http://prodesigntools.com/all-adobe-cs5-direct-download-links.html
and activate with your serial.
if you have a problem dl'g, you didn't follow all 7 steps.
May 01, 2013 May 01, 2013
SO I cannot get the extended version as a download??
If you're looking for Photoshop CS5 Extended then that's the download you'll receive from the download link at http://prodesigntools.com/all-adobe-cs5-direct-download-links.html
Thanks, John - but there is NO CS5 extended trial version to download.  BUT - Apple support solved the problem.  I have the disc and serial number - you can install through your laoptop using a remote.  Problem solved.  ALSO - you can purchase an external cd/dvd drive for $79.
Adobe Employee ,
Bluenun77 there is only one Photoshop installer.  Depending on your serial number, and if you meet or exceed the needed system requirements, will depend if Photoshop CS5 Extended will work or not.
You are correct though there are other options such as sharing your optical drive over the network to allow you to install.  You may want to consider transferring your installation files from the DVD to a USB drive for future installations.
