Hi everyone,
I have a problem while using the function deserializeJSON.
I have a request looking like this :
Request: { 'config': { 'bgSubtractor': { 'config': { 'learningRate': 1e-06,
'mogHistory': 52,
'mogSigmaSquared': 80.456140350877},
'input': { 'image': 'blur.image'},
'type': 'BGSubtractor'},
'blur': { 'config': { 'size': 3.0},
'input': { 'image': 'cropArea.image'},
'type': 'MedianBlur'},
'cropArea': { 'config': { 'rect': '{meta.areaSampleRect}'},
'input': { 'image': 'video.image'},
'type': 'Crop'},
'cropMaskBGSub': { 'config': { 'rect': '{meta.motionSampleRect}'},
'input': { 'image': 'bgSubtractor.image'},
'type': 'Crop'},
'cropMotion': { 'config': { 'rect': '{meta.motionSampleRect}'},
'type': 'Crop'},
'dataSaver': { 'config': { 'columns': [ 'frameCount', ..... etc
but when i tried to deserialized it I got the error below. I know it's because I have this float as a scientific notation "1e-06". When I removed it, it's working fine.
Is there anyway to resolve this problem?
Kavinsky69
{"ExtendedInfo":"","Message":"Invalid Syntax Closing [}] not found","Detail":"","additional":{},"Extended_Info":"","ErrNumber":0,"TagContext":[{"id":"??","template":"\/home\/ubuntu\/lib-src\/railo-4\/webroot\/optimizer\/index.cfm","codePrintPlain":"130: \t
#qMasterData.request#<\/pre> \n131: \t<\/cfoutput>\t\n132: \t\n133: \t\n134: \t#qMasterData.request#<\/pre>\n","column":0,"line":132,"raw_trace":"optimizer.index_cfm$cf.call(\/home\/ubuntu\/lib-src\/railo-4\/webroot\/optimizer\/index.cfm:132)","type":"cfml","codePrintHTML":"130: \t<pre style="white-space: normal">#qMasterData.request#<\/pre>
\n132: \t<cfset json = deserializeJSON(qMasterData.request) ><\/b>
\n133: \t<cfoutput>
\n134: \t<pre style="white-space: normal">#qMasterData.request#<\/pre>
\n"}],"ErrorCode":"0","StackTrace":"Invalid Syntax Closing [}] not found\n\tat
I'm using Coldfusion 9 and it works fine for me.
isNumeric(1e-06); // true jsn = '{"string":"foo","number":123.456,"scientific":1e-06}'; struct = deserializeJSON(jsn); writedump(struct);
You can try to run isNumeric(1e-06) to double check if it's picking it up as a number in scientific notation.
As I said, it works fine for me in Coldfusion, but it might be a bug in Railo: https://groups.google.com/forum/?fromgroups=#!topic/railo/tzwII5e0caQ
Thanks for your answer.
I'm running on ColdFusion 10.
I checki with isNumeric on railo and for isNumeric("1e-06") is given me false but for isNumeric("1e06") is sending me true.
So I guess you're maybe right and t might be a railo bug
Finally i found what the error was if your request look like that
json = '{"string":"foo","number":123.456,"scientific":1e-06}
it gives you the error but if the request is
json = '{"string":"foo","number":123.456,"scientific":"1e-06"}
it's working fine.
So I guess it sends the error as the "e-" is not recognize as a flot but as string
