I can run the preview for 5 slides at a time and they will preview. However, this presentation I am currently working on will NOT preview the entire presentation. I have other presentations that are longer than this one that will preview the entire presentation just not this one. I never get an error. I published it to our server and it does the same thing. Will open like it's going to show but the Presenter window just spins and spins and never gives an error but never plays. What would cause this to occur? Using Presenter 8.
Hi Kornieme,
Thank you for contacting Adobe Support.
Can you please try and select all slides from the PPT/ PPTX and then paste them into a new blank PPT or PPTX.
Then try to publish or preview the slides because it could be the theme specific issue.
Moreover check if any animation has been applied outside the Presentation (means any animation not from the Powerpoint)
Loveesh
Hi Kornieme,
Loveesh
That worked thank you!
