Drawscript - turn Illustrator shapes into code
Adobe Employee ,
Mar 21, 2013 Mar 21, 2013
I've just launched a little extension for Illustrator I've been working on called Drawscript - http://drawscri.pt
It converts Illustrator shapes into code (Obj-C, C++, JavaScript, Processing, ActionScript 3, JSON, Bezier array).
It's great for skinning UIs, creating vector assets for gaming and learning/teaching vector graphics programming.
If you have any comments, found bugs, etc. Let me know here or on my Twitter, Facebook, Google+.
Tom
22.0K
Adobe
Mar 22, 2013 Mar 22, 2013
Any plans on adding support for After Effects keyframe and mask data or at least a raw export that outputs the positions as 3 component arrays [X,Y,Z]? This would make a nice workflow with that program... Gonna give this a whirl later today or on the weekend....
Mylenium
Adobe Employee ,
Good point, I need to look into that. Thanks for the feedback!
Can you send me more info on how exactly would you like to structure that data?
Mentor ,
Looks really nice. There are various other methods floating around for some of the individual options, but nice idea to have it all in one output process from within Illustrator. Makes for a much cleaner approach, good work.
I didn't find what versions of Illustrator this works with? Is this only for CS6? It failed to install on CS5.5 for me.
Is this another case of:
if (installedSoftware < CS6 || installedSoftware != Cloud) {
    abandonWare = true;
If so, then it seems quite odd since its just accessing and gathering path data why couldn't it then work in other versions other than CS6? Or am I mistaken that it does indeed work in other versions?
Adobe Employee ,
Hi W_J_T,
it's currently in Beta and first drop, I am looking into this to see if it could potentially support that case as well. It requires more testing and I think it might be possible. Currently it works on CS6 only.
Mentor ,
Ok, sounds good, thanks for the response. Looking forward to further releases and seeing it for other installed versions of Illustrator. * If, you can get doing so past the powers to be that is. But technically it seems like it should be doable, one would think. Keep up the good work Tom, thanks again.
Mar 23, 2013 Mar 23, 2013
After Effects only understands basic JavaScript arrays as coordinates. It doesn't have draw primitives or any of that, so no fancies required. Just lines and lines of [X,Y,Z] will do. Also perhaps a simple CSV export? 3D programs like Cinema 4D can use that for shaping splines and polygons...
Mylenium
Contributor ,
Mar 26, 2013 Mar 26, 2013
Tried it on a few old illustrator files of mine and noticed that 'Javacript Canvas' often seems to have problems.
  • Selected all objects: no output in Javascript Canvas window
  • Selected one brush stroke: no output. Selected another brush stroke made with the same brush: output
  • Selected a region: no output. Selected another region of strokes/objects: output
  • Shapes seem to work fine so I converted all brush strokes to fills: no output or it makes illustrator freeze with the 'rainbow' cursor
  • Drew 50 standard shapes like rectangles, circles, stars, selected them all: output
  • Drew 50 brush strokes all made with the same brush: no output
  • Converted those 50 brush strokes to fills as it seemed to have less problems with shapes: still no output
Other languages seem to have less problems, though sometimes it takes a while looking at the rainbow cursor. Standard shapes work the best and fastest. More complicated objects like brushes seem to give them more problems. For other languages it takes a while for them to give output. Javascript Canvas often don't give output on brush strokes at all. Also not when converting them to fills.
All things which are still worked on when the final version comes out?
Mar 29, 2013 Mar 29, 2013
Will this support Illustrator CS6 masks, too? If so, this could prove very useful over the long run.
Patrick
Adobe Employee ,
I need to look at it, but as of now, try to simplify structures as much as possible, because remember in order to support all the languages there are definitely some trade offs that you have to take.
Mentor ,
Any updates concerning CS5/etc? Is the only thing keeping this working for CS5 the "HostList Version" in the "manifest.xml" ?
Adobe Employee ,
Mar 30, 2013 Mar 30, 2013
@W_J_T: I looked into that solution, but there is more to make it working on older versions. At least complete UI rewrite and other adjustments regarding missing APIs that were introduced in CS6.
Apr 10, 2013 Apr 10, 2013
Will this work with Illustrator CS4/CS5?
I am unable to get generate Javascript code.
Is there an issue with the generator and javascript?
Adobe Employee ,
@carrzkiss yes, there was an issue with Javascript, make sure you try the latest build. Thanks!
Apr 23, 2013 Apr 23, 2013
Hi Tom,
I am seeing an issue where my final point (closing the shape) is not a BezierCurveTo where I would expect it (it gets rendered as a straight anchor point instead of a curved one -- bottom image).
I was able to get around this by making my curve points in the middle of the set, rather than the opening/closing point.
I'm looking forward to seeing this tool grow! Thanks for making it.
Adobe Employee ,
May 02, 2013 May 02, 2013
Hi, I am not able to reproduce this,
I did a quick test and it's fine, would you mind sending me your AI file?
I re-downloaded and installed Drawscript, and now I can't reproduce the issue either. So it's cool!
May 08, 2013 May 08, 2013
Hi All,
I'm drawing a rectangular house with rectangular windows.
DrawScript generated this JavaScript code for the house:
ctx.fillStyle="rgb(139,67,94)";
ctx.strokeStyle="rgb(0,0,0)";
ctx.lineWidth=4;
ctx.fillRect(79,255,458,342);
ctx.strokeRect(79,255,458,342);
ctx.fill();
ctx.stroke();
And similar code for the windows. But everything becomes black. Solution was to delete the ctx.fill() command. It is not needed. I think it is a bug.
best regards
Hey Tom,
I am not using this to it's full potential admittedly, but I am finding it VERY useful.
Drawing in iOS/Core Graphics is new to me but using Illustrator isn't, so I am  using your extension to translate skills between between one 'language' and the other.
Its proven to be a quick way to learn how to use core graphics drawing API - using live example code 🙂
Thank you !
Darren.
Adobe Employee ,
Thanks Darren, that's a great use case! Glad you like it.
Adobe Employee ,
Dec 06, 2013 Dec 06, 2013
Tom,  are you still actively developing this tool?  It seems awfully quiet on the update/release front.  I wouldn't mind purchasing this tool if it had regular updates...  hint hint.
Jun 07, 2013 Jun 07, 2013
hi
when I export from Illustrator to json format the coordinate x and y lose decimals, is it a bug ?
if no ,  are there  another properties to setup when export ?
thanks
Oct 13, 2013 Oct 13, 2013
I LOVE this extension.
Is there any way to change the origin tho? Even when I adjust the origin with the ruler, the numbers come out relative the entire file. I have to export the paths to another file to get them to start at 0,0.
