Best tool for HTML conversion: RoboHelp or FrameMaker 10
Guest
May 07, 2013 May 07, 2013
We are approaching an HTML conversion of our FrameMaker books. What tool would you suggest using for best results, RoboHelp or FrameMaker? We have a simple style set but many graphics (screenshots). We currently single-source from Frame to PDF and online Help.
974
FM’s native HTML output has traditionally not been that good – thus the existence of Mif2Go – the TCS route via RH works fine and gives you a variety of output formats. How are you currently creating “online Help”?
Guest
Hi there,
Thanks for the quick reply. We're single-sourcing Help from Frame into RoboHelp.
Ok, so what are you really asking then? Is there a better tool than TCS? Is that it?
Guest
Hi there,
I guess what I'm asking is yes, is there a better tool than TCS, and/or if you've had better luck converting to HTML directly from RoboHelp or FrameMaker 10. There's one school of thought in my organization that it would be better to go directly from RoboHelp to HTML, which I'm not sure I agree with.
well, that's a different discussion...should you use RH or FM to manage your content.
RH is HTML (XHTML, to be specific) so it depends on your need for print, willingness to change tools, and to convert content to a new format.
-Matt
If you still need to create PDF output, the authoring in FM and creating PDFs from there is best; then use RH to create your WebHelp/AIRHelp/HTML5 Help
Without purchasing additional s/w, RH will be your best bet, and miles ahead of the FM HTML output.
A few other solutions are available, and will require you to remap your content much like you've already done for RH.
Make sure you've explicitly mapped your styles (thus eliminating the FM_ styles that show in the HTML view, and you'll be 90% there.
-Matt
Matt R. Sullivan
co-author Publishing Fundamentals: Unstructured FrameMaker 11
P: 714.798.7596 | C: 714.585.2335 | matt@mattrsullivan.com
@mattrsullivan LinkedIn facebook mattrsullivan.com
