My issue is that when ever user is clicking link or submit a form, sometimes instead of directing to a new page, it will show the internet explorer error page 'Internet explorer cannot display this webpage'. I didnt find any error message in the log in cf admin as well as IIS admin. Then I checked with a simple HTML page which refreshes in every 3 minutes. I found that this page is also showing the same issue. So I think the issue is not related to Coldfusion. Still the issue persists. So does anybody have any idea about this? Please advice. Thanks in advance.
The details are: And also the application is hosted in virtual machine.
Server Product | ColdFusion |
Version | 9,0,0,251028 |
Edition | Standard |
Serial Number | |
Operating System | Windows 2003 |
OS Version | 5.2 |
Adobe Driver Version | 4.0 (Build 0005) |
JVM Details | |
Java Version | 1.6.0_17 |
Java Vendor | Sun Microsystems Inc. |
Java Vendor URL | http://java.sun.com/ |
Java Home | D:\ColdFusion9\runtime\jre |
Java File Encoding | Cp1252 |
Java Default Locale | en_GB |
File Separator | \ |
Path Separator | ; |
Line Separator | Chr(13) |
User Name | SYSTEM |
User Home | C:\Documents and Settings\Default User |
User Dir | D:\ColdFusion9\runtime\bin |
Java VM Specification Version | 1.0 |
Java VM Specification Vendor | Sun Microsystems Inc. |
Java VM Specification Name | Java Virtual Machine Specification |
Java VM Version | 14.3-b01 |
Java VM Vendor | Sun Microsystems Inc. |
Java VM Name | Java HotSpot(TM) 64-Bit Server VM |
Java Specification Version | 1.6 |
Java Specification Vendor | Sun Microsystems Inc. |
Java Specification Name | Java Platform API Specification |
Java Class Version | 50.0 |
Sorry boss......... I worked a lot in this......... no luck am so tired............ immadiri koodara sambavam ini melalkku post cheyyarudu............
I reinstalled coldfusion 9.02 in the server. IIS 6.
Server Windows 2003 R2 Standard x 64 edition.
Tested with html page which refreshes by itself(By javascript). Have the same error.
Any idea?
Seems like an issue with the web server or, perhaps, even your browser. To start with, make sure you have followed the steps for configuring IIS in ColdFusion 9. Next, make sure the MIME type for HTML files in IIS 6 is text/html, not text/htm.
I'm running into the same exact issue - even with regular HTML pages like you mentioned. Did you ever find a resolution?
