It just won't go away! I can't find anything on the menus to get rid of it. It blocks the view of whichever document I'm trying to read. What's odd is that when I first opened a PDF document, it looked just fine; but subsequent openings of the same document had that right-hand column blocking about one-fourth of the document, requiring horizontal scrolling. Who can be bothered? Please tell me this is an easy fix. Thank you!
Other than go to full screen there is no way to make it disappear that I am aware of.
Thanks anyway, MichaelKazlow. I found out how to get rid of it: See AbhigyanModi's post, below.
Not sure what you are asking; what "right-hand column"? Can you post a screenshot?
Here's a screen shot, Pat. I'm referring to that column on the right-hand side of the interface. Anyway, AbhigyanModi solved the problem for me. Thanks all the same!
Click on the "Tools" label on top of the right hand column and it should go away.
Thank you very much, AbhigyanModi. Your advice was spot on!
Yes thanks that worked. And was completely non-obvious! Agreed that is annoying both to make the wide column the default display and make it so hard to switch off.
Half of a solution has been offered for this problem: Click on Tools, then click on Tools again. This is so un-obvious that I have to guess it removes the column as a fluke of what's been clicked, not because that is the defined way to remove the column. And the screen shot helped those who haven't seen it. But I've been reading the Freakonomics guys and I have to say that the right question was not asked. Here's the right question:
How can I keep that stupid worthless column from EVER showing up again? I mean, it's nice to have instructions on how to change a tire, but it's even nicer to have a car that doesn't have a blowout every time I try to go for a drive!
I have searched Preferences and cannot find anything that seems to relate to it.
Thanks for your attention to this issue.
