Facing an issue with Flash builder 4.7:
Flash builder 4.7 gives below error when project export to release build
Error: Flash builder could not publish the project:null
I'm able to create release build with same source file in 4.6 version but only 4.7 gives problem
The builder 4.7 version uses new workspace.
How to solve this?
Imgsrn
In the log file found:
java.lang.NullPointerException
at com.adobe.flexbuilder.codemodel.internal.project.Project.findFileNode(Project.java:805)
at com.adobe.flexbuilder.codemodel.internal.project.Project.findFileNodeInProject(Project.java:845)
at com.adobe.flexbuilder.codemodel.internal.project.ProjectManager.isExternalFile(ProjectManager.java:827)
at com.adobe.flexbuilder.codemodel.internal.project.ProjectManager.getCMProjectForFile(ProjectManager.java:494)
at com.adobe.flexbuilder.codemodel.internal.project.ProjectManager.getProjectForFile(ProjectManager.java:300)
at com.adobe.flexbuilder.codemodel.internal.project.ProjectManager.getCompilerProjectForFile(ProjectManager.java:355)
at com.adobe.flexbuilder.codemodel.internal.project.ProjectManager.getCompilerProjectForFile(ProjectManager.java:383)
at com.adobe.flexbuilder.codemodel.internal.project.EclipseProjectListener.findIncludingFiles(EclipseProjectListener.java:396)
at com.adobe.flexbuilder.codemodel.internal.project.EclipseProjectListener.access$1(EclipseProjectListener.java:395)
at com.adobe.flexbuilder.codemodel.internal.project.EclipseProjectListener$ResourceChangeListener.resourceChanged(EclipseProjectListener.java:190)
at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:291)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:285)
at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:149)
at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:395)
at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:1530)
at org.eclipse.core.internal.resources.Resource.copy(Resource.java:547)
at com.adobe.flexbuilder.project.compiler.internal.BuilderUtils.copyDependents(BuilderUtils.java:602)
at com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.build(FlexProjectBuilder.java:512)
at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.build(FlexIncrementalBuilder.java:171)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Are both projects using the same sdk in the compiler?
were you able to find a fix for this problem, i am having the same issue and could not fix it.
I finally figured out the problem in my context. It was beacuse of the additional compiler arguments under Properties/Flex Compiler. I was trying to set the -advanced-telemetry=true option here, when i removed it started to work again. For others this might be a totally different thing. I think eclipse is throwing a generic error here as "Flash builder could not publish the project:null" when something goes wrong with the compiler options. I am not sure but this is the case for me.
