Hey,
I have installed adobe application manager, but when I try to login to the application after giving in my credentials I get an error as "DownLoad Error, contact support", with a quit button. PFA below the screen shot, and suggest what am I missing.
No idea. From your screenshot we can only conclude that you're on Windows 8, but beyond that we have no details. Could be a network configuration error, so check your setup on that end.
Mylenium
Hey,
Are their any other details which you want me to share with you. What sort
of network issues could lead to this problem. Yes I am working on Windows 8
(are their any specific setting for AAM to work on windows 8).
let me know in case you want me to share some other details with you.
Please delete the "opm.db" file found in: C:\Users\<username>\AppData\Local\Adobe\OOBE
Then try to Launch AAM and check.
Hey,
I did try to remove the file (opm.db) from the above mentioned location and
tried again, but am still facing the same issue.
Please let me know if I can try something else. I really need to get the
trial version of Adobe Dream Weaver. Is their any other way of downloading
it apart from AAM.
Do let me know your thoughts on the same.
Between thanks for your response I really appreciate your help.
On Mon, May 20, 2013 at 5:29 AM, Baljeet S. Juneja <forums_noreply@adobe.com
Deves0506 it appears you are facing a download error. Please review the steps listed in Sign in or activation errors | CS6, CS5.5 Subscriptions, CS6 Perpetual - http://helpx.adobe.com/x-productkb/policy-pricing/activation-network-issues.html as it is likely these steps will still be relevant to your current difficulties.
Also if you are on a managed network please make sure to work with your I.T. department to ensure the Adobe Application Manager is being allowed to download the installation files over the network.
Hey,
I have tested my networking settings, everything is working fine. Further I
am using a private network as it is my home connection.
In case their are some settings in order to allow access to Adobe
application manager do let me know.
I am still not able to start the AAM.
I appreciate your response and the fact that you took out some time to
address my issue, but unfortunately the issue is yet not resolved.
Do let me know in case their are some other suggestions.
Also is their any other way to download Adobe Dreamweaver, as that is what
I am actually looking for..?
Devesh0506 you can download Dreamweaver CS6 by following the directions listed at http://forums.adobe.com/thread/981369.
You will want to resolve the difficulties you are facing downloading through the Adobe Download Assistant though. You will need this to function in order to download updates and future versions of Dreamweaver if you are a Creative Cloud subscriber.
I would recommend working with our support team so they can review your download logs. You can contact our chat support at http://adobe.ly/yxj0t6.
