Locked
flash player wont install correctly.
May 21, 2013 May 21, 2013
Im running windows seven, IE 10 , 64 bit and ive tried everything in this forum but nothings worked. PLEASE help.
1.7K
Adobe Employee ,
What's happening when you go to this page:  Flash Player Version
Do you see the Flash Player animation and version number?
I assume you've tried both faqs below?
I get no movie
Adobe Employee ,
And Shockwave Flash is listed and set as enabled?
yes
Im not seeing the program in my program folders and in the controlpanel under system it shows no plug in
If I search programs and put in add IE shows up and says no addons but there enabled in the addon toolbar could that be screwy?
Adobe Employee ,
What files do you have in
C:\windows\syswow64\macromed\flash
how do I tell?
Adobe Employee ,
you'll need to use File Explorer and navigate into that folder.  Alternatively you can use the command prompt (type cmd in the start menu) and then type "cd C:\windows\syswow64\macromed\flash"  followed by "dir".
tells me directory name is incorrect
Adobe Employee ,
I would recommend using Microsoft's Windows Explorer (type Windows Explorer in the start menu), then navigate to the C: drive and go into folders from there.
ok finally found it
what do you need from this
active x
flash 32-11-7-700-202.ocx
flash install
flash player update service
flash util32-11-7-700-202-activex.dll
flashutil32-11-7-700-202-activex
install
mms.cfg
thanks for leaving me hangin DUDE
