separate table and figure numbering sequences
May 22, 2013 May 22, 2013
I need some pointers and guideance on how to setup autonumbering for tables and figures separately.  As it is, the number sequence advances upon usage by a table or a figure.  For example,  Table 1,  Figure 2,  Figure 3, Table 4.    What I need in that case is  Table 1, Figure 1, Figure 2, Table 2.
964
LEGEND , May 22, 2013 May 22, 2013
Steve,
The easisest way is to use what's called a series indicator for you autonumber sequence. This consists of a single letter at the star of the autonumber. Typically, one could use F:<n+> for figures and T:<n+> for tables. FM will then number these streams differently. You can make things more complex in your setup (and much easier for the authors) using a numbering matrix where parent heading tags reset the lower level counters (which is what Peter was alluding to).
See:
http://www.freeframers.org/archive/99/msg00281.html
http://help.adobe.com/en_US/FrameMaker/9.0/Using/WSF176D8C8-8133-4860-88E3-AF69262623F0.html
http://www.techcomplus.com/reference/autonumbering.pdf
http://www.microtype.com/resources/articles/AUTONUM_DE.PDF
http://www.infocon.com/files/autonum.pdf
Mentor ,
It's a piece of cake for FrameMaker, but it takes a little study to learn how it works. Search Google for terms like "FrameMaker multiple counter autonumbering" without quotes for details.
HTH
Peter
_______________________
Peter Gold
KnowHow ProServices
Steve,
See:
Advocate ,
Assign each a separate series in the autonumbering scheme. It can be any
alphanumeric, followed by a colon. For example, you might precede your
numbering scheme for tables with "T:" and figures with "F:". This will
cause each to be tracked separately.
Separate table and figure numbering can be confusing, though. You might
also want to look at this document, "The case for simple numbering," for
information on why you may not want to number them separately:
http://www.techknowledgecorp.com/nonum.html
