I am running 10.5.8 on an old mac without intel processor. Which Acrobat can I run, where do I find that download, and can I get a 30 day trial?
Downloads here:
Direct Download Links for Adobe Software
The last PPC-enabled version that would run on your OS should be Acro 9, but v8 definitely works on 10.5.8 (still have it on my old 2006 MacBook with the same OSX) and should also provide everything for a PPC-only environment.
Mylenium
Downloads here:
Mylenium
It should be noted that up until I believe Acrobat 10 we did not have a Mac trial available. JoboKillorin while Acrobat 8 or 9 should work you will still need to locate a copy of this older version of Acrobat to purchase.
I would recommend that you review the return policy for any place which you are able to locate this older software in case you need to return it.
Thanks so much. I found Acro 8 and it works well on my old machine.
Much appreciated.
Thanks so much. I found a free copy of Acro 8 just on the web from some site called TechSpot and it works like a charm. I should mention that the DDL link you sent did not seem to have any link to old Acros, just updates. One link could not be opened by my server.
You're a lifesaver!
