1
LR5 Trial - Output Sharpening and Noise Reduction not working.
Guest
Jun 10, 2013 Jun 10, 2013
Just installed LR5 final and upgraded my LR4 catalog. Output Sharpening does nothing when exporting. noise reduction doesn't work also, exportet jpej look awful. is this a trial limitation maybe?
37.7K
Adobe Employee , Jul 31, 2013 Jul 31, 2013
This has been fixed in the Release Candidate of Lightroom 5.2, available now at http://labs.adobe.com/technologies/lightroom5-2/
The trial version is fully function. If something isn't wrking as expected then it's usually worth seeing if trashing the preference file helps. You can find details on the name and lcoation of thsi file in the Lightroom FAQ http://forums.adobe.com/thread/358041?tstart=0 The instructiosn for Lr5 should be similar to those for Lr4.
Guest
i've tried everything - reinstalling, deleting prefs file, even another computer. output sharpening is not working. noise reductions seems to do something but exported files look waaay worse than preview in lr5 itself or lr5beta or lr4 files. it leaves out lots of color noise. something is surely wrong there.
I don't have access to a system at present, so can't check myself. Nevertheless, I'll pass the info on to QE. Hopefully, they will have an answer.
Guest
i have tried only 5 images yet but it seems to work for me.
both sharpening and NR look ok when exported as JPG.
what sizes i should try?
Guest
usually i use 720 or 960 or 1280 for long edge. noise reduction only works for 1280. sharpening does not work for any of these. tried exporting sharpened "high" picture and same pic without sharpening at all, files came out identical. byte by byte.
Oct 14, 2013 Oct 14, 2013
Have you found an answer? I recently purchased and downloaded LR5 and all exported files look worse than in LR. Some not sharpened; others very noisy.
The answer is referenced in the post directly above yours, Julita.
I've just found out too - it seems this issue is resolution dependend. There seems to be some kind of treshold for each raw source resolution/crop combination, see the attached photo (100% crop of exported JPEGs, one pixel difference)
Guest
you're right, changed jpeg size, noise reduction now works, but sharpening still doesn't.
Guest
so it seems lr5 has some major bugs in final version. strange. i always thought that's why they release beta - to find out problems and fix them.
Guest
have cropped a dozend images now and exported, did not notice any strange behavior.
so you use the resize option in the export dialog?
Guest
you don't have to crop anything to reproduce this. i'm exporing full uncropped d800 36mpix raw's resized to sizes i've mentioned earlier. output sharpening does NOTHING. noise reduction works depending on exported file size. that's at least two issues i've found out in a few minutes after i installed it.
Guest
works for me.
tried resize to 720 and 960 pixels on the long edge.
maybe a good ideas to post an example RAW so the adobe guys can try it.
Guest
noise reduction or sharpening? which ver of lr5 are you using? x86 / x64 / win / mac ?
Guest
both.
using win7 - 64 bit.
output sharpening yields a stronger halo effect on contrasty edges as no sharpening.
and NR is applied too.
EDIT:
ok... noise has some issues.
noticed it only at 3200 iso images and above.
color noise looks definatley worse then in LR on the exported JPG´s.
Guest
sharpening starts working when i increase long edge's size. 2048pix long edge - sharpening works, 720 960 1280 long edge - sharpening does nothing.
Guest
i tried 960 pixels and output sharpening worked .. i can see a difference.
but yes the color noise reduction looks worse on the exported JPG´s.
worse then expected (keeping the JPG compression in mind).
there are wrong coloured pixels.
the same image, send to PS from LR, resized in PS and exported with the same JPG settings looks much better.
win7/x64
can't really tell much about the sharpening, not sure with the noise difference.
I've just tried different img, ISO 400, D700, uncropped vertical, the output sharpening also kicks in only above certain export resolution, this time 1400px not sharpened while1440px visibly is.
Guest
Jun 21, 2013 Jun 21, 2013
I have found that (apparently) Adobe decides to introduce "last minute changes" when releasing the final version. Sort of: You thought you were getting this much but you are getting THIS much! So you are happy and enthusiastic and buy it inmediately... Later on you realize that "half" the things won't work properly... and that it will take them until .4 to update to fix something (like with LR 4) (-> meaning almost a year of stress and frustration for you)
So... I am buying a new camera and they want to combo LR5 with it. I'm asking for alternatives or store credit. I am not making the same mistake I made with LR 4.
If there is a good working version of LR 5 soon, I'll get it. Otherwise, I'll stay with my LR4 for as long as I can.
http://forums.adobe.com/thread/971581?start=1360&tstart=0
http://forums.adobe.com/thread/1117506?start=0&tstart=0
To test it out, try ISO 3200 or higher, don't crop and export JPEGs from 800 to 2000 pix longer size, each JPG 200px increment and it might appear when you check 100% one after another, usually in darker areas, color noise is easier indicator. The threshold for uncropped D700/D600 3200 ISO RAWs I tested seems to be between 1400-1600px longer side.
It all might be related to the different export times - the lower exported resolution, the faster the export is. Until approx half the resolution of the source is exported, then it takes the same amount of time as hires. Seems to me the source in LR5 is resized to approx double the exported size, then processed and then resized again - smart and much faster for web exports, but with those sharpening and NR issues.
Guest
where can we report this? i'm kinda stuck now - upgraded my catalog to lr5 format and deleted lr4 one. and with these issues i'd like to go back to lr4 until it get's fixed but i can't 😕
Mentor ,
I can reproduce the output sharpening issue, but not the noise reduction issue.  I get noise reduction no matter what I seem to try...on ISO 6400 images.
Guest
this is quite random, i have two raw's taken one after one, i export both at 1280pix long edge. one gets noise cleane other one doesn't. if i export both at 2048 both get cleaned. simliar with sharpening. makes me also think this has something to do with timing or so..
