In version 3.8.0.66 Android AIR, when launch the app in full-screen and create an instance of Video, StageWebView disappears.
Is this a bug in the AIR 3.8.0.66 ?
- source
import flash.media.StageWebView;
import flash.media.Video;
private function init():void {
//Create StageWebView
var webView:StageWebView = new StageWebView();
webView.stage = stage;
webView.viewPort = new Rectangle(0, 0, stage.width, stage.height);
webView.loadURL("http://www.google.com/");
//Create Video
//StageWebView disappears when there is this line.
var video:Video = new Video(100, 100);
return;
- app.xml
<fullScreen>true</fullScreen>
We have been able to reproduce the issue and now investigating it.
Thanks for reporting,
Nimit
Try add <containsVideo>true</containsVideo> inside <android> tag in application.xml. Without that new Video() causes problems on android. containsVideo tag is not documented, please update docs.
By using the latest AIR 3.8.0.82, video can no longer play at all, in full-screen mode.
When not in full screen mode, we can play normally.
In addition, I tried to put a <containsVideo> tag, but it was similar.
The issue has been fixed and will available in the next release.
Nimit
Thank you for the fix.
We will wait for the next release.
when can download the next release?
