RoboHelp HTML Version 9
In the WebHelp display in IE, the file name shows when I hover over an image.
I could put in a screen tip, but I would have to do that for every image and that will be time consuming after-the-fact.
Can anyone tell me how to change the output so the file name does not display for ALL the images. I looked in the WebHelp Settings dialog, but can't find anything in there.
Thanks!!
Natalie
You'll probably have to edit the resulting HTML to remove the ALT text - I think that's where it's picking up the filename
I should have mentioned that I tried that in RoboHelp... I went into the HTML tab and deleted the alt="" text. Robohelp seems to stick it back in after I save and generate.
Did you mean open the WebHelp in a different HTML editor (not RoboHelp)?
Yes - when you edit in the HTML tab, you're still working with the project files - not the help output. You need to mess about with the output files to test this.
Thanks for the additional info. Yes, I can edit the output files, remove the alt="" and that fixes it. But if I make any changes to the source files and re-generate, I have to edit the output files again.
Helpful, but not practical.
Good to know that was the culprit - if you can't prevent it from being added within RH, maybe setting up a FAR script to clean it out of the output is the way to go. I've never really paid attention to it - is it that big a deal? Maybe Peter Grainge (grainge.org) or Willam (wvanweelden.eu<http://www.wvanweelden.eu>) or Rick (robowizard.com) have something on their sites to address it.
An internal client doesn't "like" it, and I was hoping for a quick easy solution in RoboHelp.
Thanks for the additional links!
Maybe this will help? It helped me resolve the tooltip problem in generated PDF documents.
For what it is worth, I believe this problem is fixed in Rh10.
