Hi everyone,
when I try to use the shortcut Ctrl+L in order to refresh the document display, FM 11 always freezes and sooner or later it crashes completely.
Using Window > Refresh does not cause any problems.
Anyone else got this issue?
Best wishes from Germany
Sebastian
I found the problem:
It was a FrameScript which had been loaded on start-up and used the same shortcut. I changed the shortcut for the script and now I can refresh with Ctrl+L.
Thanks for your help, though!
Nope, I’ve not had that issue – are you running in structured or unstructured mode? Does it occur if you try a lorsum doc made with one of the factory templates?
