The default option for my quizzes had the font too small to see the text of the questions. When I made the font of the questions larger, the circles for clicking, the letters of the questions, and the question texts all ran into each other.
So I have a question:
1) Is there a way to change the theme or profile--I cannot tell which--on just the quiz questions? And if so, how?
THANK YOU!
You may change the fonts for Quiz answers and questions using the following option:
Go to Quiz Manage->Appearance tab.
Chane the font, size and style for anwers, questions , button and messages.
Let me know if you need any other help.
Alpi Agarwal
Adobe Presenter Engineering Team
That is not the problem, but thanks.
I have changed the size of the font and when I do that, the box to
check, the letter that numbers the answer, and the question all run
together. It appears that the size of the letters have been enlarged
but not the spaces between them. Any ideas?
I think it is possible that i could change this all by inserting a new
master slide into the presentation before the quiz, but I cannot seem
to do that.
Thank you.
Quoting alpi agarwal <forums_noreply@adobe.com>:
the discussion
"Re: Adobe presenter 8 quiz problem"
To view the discussion, visit:
http://forums.adobe.com/message/5409679#5409679
There is a tricky workaround. Once you insert the question on the slide do the following:
1. Select individual text boxes for every answer and adjust the height and width. There are seperate text boxes for the button, option and answer.
2. select the text and adjust the font and size.
This should not disturb the formatting.
If this do not help, please mail me the presentation or the slide in which you have the problem.
Alpi Agarwal
I am speaking about 13 slides that are all part of the quiz. I DID try
switching the sizes of the boxes and ended up with different sizes and
distances since it is all done "by eye" and not by measure. Is there
another way to do it that would be more exact?
Please send me an email address where I can reach you and send you a
single slide or all the slides so you can let me know.
Is it possible to insert a Master Slide for the quiz part, only, that
would make the questions have a larger font (and appropriate distances
from the bubbles that get checked?).
Many thanks.
Hello,
I had the same problem as this. When I individually ungrouped and resized the quiz answer boxes (the choices themselves), when I went back into quiz manager, none of my answers were in the quiz question. It didn't recognize them.
Can you suggest another alternative?
Thanks.
Could you please inbox me your presenttaion.
I will try to fix the formatting.
Mail at alpagarw@adobe.com
Alpi Agarwal
THANK YOU. I will do this tomorrow.
Lisa
