Creative Suite 3 install Error
Guest
Jun 15, 2013 Jun 15, 2013
Hello.
I am attempting to install Adobe Creative Suite 3.
Upon launching the install, I'm encountering this error:
http://img703.imageshack.us/img703/2986/ojvu.jpg
I have no idea how to get rid of this, Adobe Support Advisor couldn't determin the problem. I've tried running Creative Suite Cleaner but after removing files and rebooting, i'm still getting the issue, like it's not allowing me to allow old files from previous Adobe installs??
Any suggestions on my next course of action?
I'm on Windows 7 32bit.
Thankful for any help.
1.3K
Community Expert , Jun 15, 2013 Jun 15, 2013
you'll need to check your install logs to pinpoint the problem, http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5-cs5.html
Guest
thank you for the quick response.
i've read the log, but i don't really know what to make of it or what cause of action i should take
whis is from Adobe Photoshop CS5 12.0 06-15-2013.log
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Visit http://www.adobe.com/go/loganalyzer/ for more information *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* START - Installer Session *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* RIBS version: 3.0.121.0 Win OS version: 6.1.0.0  Type: 1 ::START TIMER:: [Total Timer] CHECK: Single instance running CHECK : Credentials Load Deployment File Create Required Folders Assuming uninstall mode Lookup for master payload Ready to initialize session to start with ... ::START TIMER:: [CreatePayloadSession] Supported RIBS version range: [0.0.66.0,3.0.121.0] ----------------- CreatePayloadSession: machine is x86 --------------- ______ Verify Dependency Subscribers ______ [    4980] Sat Jun 15 14:02:16 2013  WARN The payload: Adobe Photoshop CS5 Core  {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} requires a UI parent with following specification:      Family: Photoshop      ProductName: Adobe Photoshop CS5 Core_x64      This parent relationship is not satisfied, because this payload is not present in this session. [    4980] Sat Jun 15 14:02:16 2013  INFO Setting property "driverAdobeCode" to: {15FEDA5F-141C-4127-8D7E-B962D1742728} Setting property "mediaSignature" to: {15FEDA5F-141C-4127-8D7E-B962D1742728} Setting property "removeUserPrefs" to: 1 Overwrite property "userASUPath" to: C:\PROGRA~1\COMMON~1\Adobe\OOBE\PDApp\core\..\DWA Found payload actions:  Deciding what installer mode to use... {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US not installed {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core not installed {15FEDA5F-141C-4127-8D7E-B962D1742728} Adobe Photoshop CS5 not installed {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 not installed {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB not installed {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US not installed {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral not installed {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5 not installed {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 not installed {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5 not installed {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 not installed {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5 not installed {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5 not installed {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 not installed {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5 not installed {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 not installed {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5 not installed {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB not installed {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player not installed {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 not installed {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR not installed {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 not installed {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support not installed {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 not installed {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 not installed {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 not installed {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw not installed {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 not installed {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 not installed {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule not installed {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 not installed {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 not installed {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp not installed {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5 not installed {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 not installed {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer not installed {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE not installed {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 not installed {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 not installed {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding not installed {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 not installed {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 not installed {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 not installed {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 not installed BEGIN Setting requested payload actions Value returned on lookup of payload: {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is: true Action string for  {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB  is none Payload {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is extension payload. Aligning its action according to parent. Value returned on lookup of payload: {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is: false Action string for  {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US  is none Payload {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is extension payload. Aligning its action according to parent. Value returned on lookup of payload: {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core is: false Action string for  {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core  is none Value returned on lookup of payload: {15FEDA5F-141C-4127-8D7E-B962D1742728} Adobe Photoshop CS5 is: false [    4980] Sat Jun 15 14:02:16 2013  WARN Payload {15FEDA5F-141C-4127-8D7E-B962D1742728} Adobe Photoshop CS5 is not installed so should not be there in the deployment file [    4980] Sat Jun 15 14:02:16 2013  INFO Value returned on lookup of payload: {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 is: false Action string for  {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5  is none Value returned on lookup of payload: {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is: false Action string for  {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB  is none Payload {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is extension payload. Aligning its action according to parent. Value returned on lookup of payload: {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is: false Action string for  {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US  is none Payload {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is extension payload. Aligning its action according to parent. Value returned on lookup of payload: {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral is: false Action string for  {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral  is none Value returned on lookup of payload: {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5 is: false Action string for  {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5  is none Value returned on lookup of payload: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 is: false Action string for  {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5  is none Value returned on lookup of payload: {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation is: true Action string for  {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation  is none Value returned on lookup of payload: {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation is: true Action string for  {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation  is none Value returned on lookup of payload: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5 is: false Action string for  {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5  is none Value returned on lookup of payload: {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 is: false Action string for  {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5  is none Value returned on lookup of payload: {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5 is: true Action string for  {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5  is none Value returned on lookup of payload: {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5 is: false Action string for  {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5  is none Value returned on lookup of payload: {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5 is: false Action string for  {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5  is none Value returned on lookup of payload: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 is: false Action string for  {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5  is none Value returned on lookup of payload: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5 is: false Action string for  {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5  is none Value returned on lookup of payload: {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 is: true Action string for  {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5  is none Value returned on lookup of payload: {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 is: false Action string for  {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5  is none Value returned on lookup of payload: {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5 is: false Action string for  {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5  is none Value returned on lookup of payload: {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB is: false Action string for  {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB  is none Value returned on lookup of payload: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK is: true Action string for  {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK  is none Value returned on lookup of payload: {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 is: true Action string for  {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5  is none Value returned on lookup of payload: {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 is: true Action string for  {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5  is none Value returned on lookup of payload: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player is: false Action string for  {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player  is none Value returned on lookup of payload: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 is: false Action string for  {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5  is none Value returned on lookup of payload: {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR is: false Action string for  {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR  is none Value returned on lookup of payload: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 is: true Action string for  {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86  is none Value returned on lookup of payload: {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support is: false Action string for  {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support  is none Value returned on lookup of payload: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 is: false Action string for  {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5  is none Value returned on lookup of payload: {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 is: false Action string for  {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5  is none Value returned on lookup of payload: {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 is: false Action string for  {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5  is none Value returned on lookup of payload: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw is: false Action string for  {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw  is none Value returned on lookup of payload: {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 is: false Action string for  {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5  is none Value returned on lookup of payload: {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 is: false Action string for  {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5  is none Value returned on lookup of payload: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule is: false Action string for  {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule  is none Value returned on lookup of payload: {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 is: false Action string for  {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5  is none Value returned on lookup of payload: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 is: false Action string for  {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5  is none Value returned on lookup of payload: {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp is: false Action string for  {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp  is none Value returned on lookup of payload: {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5 is: false Action string for  {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5  is none Value returned on lookup of payload: {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 is: false Action string for  {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0  is none Value returned on lookup of payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer is: false Action string for  {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer  is none Value returned on lookup of payload: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE is: false Action string for  {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE  is none Value returned on lookup of payload: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 is: true Action string for  {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86  is none Value returned on lookup of payload: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 is: true Action string for  {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86  is none Value returned on lookup of payload: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding is: false Action string for  {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding  is none Value returned on lookup of payload: {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 is: true Action string for  {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86  is none Value returned on lookup of payload: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 is: true Action string for  {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86  is none Value returned on lookup of payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 is: true Action string for  {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86  is none Value returned on lookup of payload: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 is: true Action string for  {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86  is none END Setting requested payload actions INSTALLDIR passed path basic path validation: C:\Program Files\Adobe [    4980] Sat Jun 15 14:02:18 2013  INFO Payloads passed preflight validation. Call PreSession Custom Hook Calling the custom action code for pre-remove for payload {CBDD7465-CE11-4A58-9497-C370B65923F1} ::START TIMER:: [Payload Operation :{CBDD7465-CE11-4A58-9497-C370B65923F1}] [    6048] Sat Jun 15 14:02:18 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Installer Operation: PayloadUninstaller *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Session {15FEDA5F-141C-4127-8D7E-B962D1742728} modify request for AdobeCode: {CBDD7465-CE11-4A58-9497-C370B65923F1} [    6048] Sat Jun 15 14:02:19 2013  INFO Effective AdobeCode for: {CBDD7465-CE11-4A58-9497-C370B65923F1} is {CBDD7465-CE11-4A58-9497-C370B65923F1} Uninstalling payload [    6048] Sat Jun 15 14:02:19 2013 FATAL sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database [    6048] Sat Jun 15 14:02:19 2013  INFO INSTALLDIR property not found in database Beginning un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{CBDD7465-CE11-4A58-9497-C370B65923F1}.db [    6048] Sat Jun 15 14:02:19 2013 FATAL sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database [    6048] Sat Jun 15 14:02:19 2013  INFO UninstallSeq property not found in database [    6048] Sat Jun 15 14:02:19 2013 FATAL sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database [    6048] Sat Jun 15 14:02:19 2013  INFO Completing un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{CBDD7465-CE11-4A58-9497-C370B65923F1}.db Physical payload uninstall result:1 [    4980] Sat Jun 15 14:02:19 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=* :: END TIMER :: [Payload Operation :{CBDD7465-CE11-4A58-9497-C370B65923F1}] took 1006.76 miliseconds (1.00676 seconds) User specified overrideFile:  Calling the ROLLBACK custom action code for pre-remove for payload {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation Calling the custom action code for pre-remove for payload {E39A5ABD-516B-46F9-A042-694BBA6A4E08} ::START TIMER:: [Payload Operation :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}] [    4212] Sat Jun 15 14:02:19 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Installer Operation: PayloadUninstaller *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Session {15FEDA5F-141C-4127-8D7E-B962D1742728} modify request for AdobeCode: {E39A5ABD-516B-46F9-A042-694BBA6A4E08} [    4212] Sat Jun 15 14:02:20 2013  INFO Effective AdobeCode for: {E39A5ABD-516B-46F9-A042-694BBA6A4E08} is {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Uninstalling payload [    4212] Sat Jun 15 14:02:20 2013 FATAL sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database [    4212] Sat Jun 15 14:02:20 2013  INFO INSTALLDIR property not found in database Beginning un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{E39A5ABD-516B-46F9-A042-694BBA6A4E08}.db [    4212] Sat Jun 15 14:02:20 2013 FATAL sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database [    4212] Sat Jun 15 14:02:20 2013  INFO UninstallSeq property not found in database [    4212] Sat Jun 15 14:02:20 2013 FATAL sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database [    4212] Sat Jun 15 14:02:20 2013  INFO Completing un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{E39A5ABD-516B-46F9-A042-694BBA6A4E08}.db Physical payload uninstall result:1 [    4980] Sat Jun 15 14:02:20 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=* :: END TIMER :: [Payload Operation :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}] took 1008.76 miliseconds (1.00876 seconds) DTR = 4060.41 KBPS (3.96525 MBPS) User specified overrideFile:  Calling the ROLLBACK custom action code for pre-remove for payload {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation Calling the custom action code for pre-remove for payload {73A4DC5E-226E-42BA-8ECA-2822592AC044} ::START TIMER:: [Payload Operation :{73A4DC5E-226E-42BA-8ECA-2822592AC044}] [    6064] Sat Jun 15 14:02:20 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Installer Operation: PayloadUninstaller *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Session {15FEDA5F-141C-4127-8D7E-B962D1742728} modify request for AdobeCode: {73A4DC5E-226E-42BA-8ECA-2822592AC044} [    6064] Sat Jun 15 14:02:21 2013  INFO Effective AdobeCode for: {73A4DC5E-226E-42BA-8ECA-2822592AC044} is {73A4DC5E-226E-42BA-8ECA-2822592AC044} Uninstalling payload [    6064] Sat Jun 15 14:02:21 2013 FATAL sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database [    6064] Sat Jun 15 14:02:21 2013  INFO INSTALLDIR property not found in database Beginning un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{73A4DC5E-226E-42BA-8ECA-2822592AC044}.db [    6064] Sat Jun 15 14:02:21 2013 FATAL sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database [    6064] Sat Jun 15 14:02:21 2013  INFO UninstallSeq property not found in database [    6064] Sat Jun 15 14:02:21 2013 FATAL sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database [    6064] Sat Jun 15 14:02:21 2013  INFO Completing un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{73A4DC5E-226E-42BA-8ECA-2822592AC044}.db Physical payload uninstall result:1 [    4980] Sat Jun 15 14:02:21 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=* :: END TIMER :: [Payload Operation :{73A4DC5E-226E-42BA-8ECA-2822592AC044}] took 1003.34 miliseconds (1.00334 seconds) User specified overrideFile:  Calling the ROLLBACK custom action code for pre-remove for payload {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5 Calling the custom action code for pre-remove for payload {54F4466A-091A-46DA-B697-43D55CEF9DF6} ::START TIMER:: [Payload Operation :{54F4466A-091A-46DA-B697-43D55CEF9DF6}] [    5212] Sat Jun 15 14:02:21 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Installer Operation: PayloadUninstaller *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Session {15FEDA5F-141C-4127-8D7E-B962D1742728} modify request for AdobeCode: {54F4466A-091A-46DA-B697-43D55CEF9DF6} [    5212] Sat Jun 15 14:02:22 2013  INFO Effective AdobeCode for: {54F4466A-091A-46DA-B697-43D55CEF9DF6} is {54F4466A-091A-46DA-B697-43D55CEF9DF6} Uninstalling payload [    5212] Sat Jun 15 14:02:22 2013 FATAL sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database [    5212] Sat Jun 15 14:02:22 2013  INFO INSTALLDIR property not found in database Beginning un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{54F4466A-091A-46DA-B697-43D55CEF9DF6}.db [    5212] Sat Jun 15 14:02:22 2013 FATAL sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database [    5212] Sat Jun 15 14:02:22 2013  INFO UninstallSeq property not found in database [    5212] Sat Jun 15 14:02:22 2013 FATAL sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database [    5212] Sat Jun 15 14:02:22 2013  INFO Completing un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{54F4466A-091A-46DA-B697-43D55CEF9DF6}.db Physical payload uninstall result:1 [    4980] Sat Jun 15 14:02:22 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=* :: END TIMER :: [Payload Operation :{54F4466A-091A-46DA-B697-43D55CEF9DF6}] took 1004.96 miliseconds (1.00496 seconds) User specified overrideFile:  [    4980] Sat Jun 15 14:02:23 2013  INFO Calling the ROLLBACK custom action code for pre-remove for payload {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 Calling the custom action code for pre-remove for payload {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} ::START TIMER:: [Payload Operation :{39CB2E53-5326-4939-8B5A-0402C6EFBFE3}] [    5516] Sat Jun 15 14:02:23 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Installer Operation: PayloadUninstaller *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Session {15FEDA5F-141C-4127-8D7E-B962D1742728} modify request for AdobeCode: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} Effective AdobeCode for: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} is {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} Uninstalling payload [    5516] Sat Jun 15 14:02:23 2013 FATAL sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database [    5516] Sat Jun 15 14:02:23 2013  INFO INSTALLDIR property not found in database Beginning un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{39CB2E53-5326-4939-8B5A-0402C6EFBFE3}.db [    5516] Sat Jun 15 14:02:23 2013 FATAL sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database [    5516] Sat Jun 15 14:02:23 2013  INFO UninstallSeq property not found in database [    5516] Sat Jun 15 14:02:23 2013 FATAL sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database [    5516] Sat Jun 15 14:02:23 2013  INFO Completing un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{39CB2E53-5326-4939-8B5A-0402C6EFBFE3}.db Physical payload uninstall result:1 [    4980] Sat Jun 15 14:02:24 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=* :: END TIMER :: [Payload Operation :{39CB2E53-5326-4939-8B5A-0402C6EFBFE3}] took 1005 miliseconds (1.005 seconds) User specified overrideFile:  Calling the ROLLBACK custom action code for pre-remove for payload {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK Calling the custom action code for pre-remove for payload {AE9B837F-D135-42FC-BE03-33545B5DCBDC} ::START TIMER:: [Payload Operation :{AE9B837F-D135-42FC-BE03-33545B5DCBDC}] [    4532] Sat Jun 15 14:02:24 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Installer Operation: PayloadUninstaller *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Session {15FEDA5F-141C-4127-8D7E-B962D1742728} modify request for AdobeCode: {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Effective AdobeCode for: {AE9B837F-D135-42FC-BE03-33545B5DCBDC} is {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Uninstalling payload [    4532] Sat Jun 15 14:02:24 2013 FATAL sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database [    4532] Sat Jun 15 14:02:24 2013  INFO INSTALLDIR property not found in database Beginning un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{AE9B837F-D135-42FC-BE03-33545B5DCBDC}.db [    4532] Sat Jun 15 14:02:24 2013 FATAL sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database [    4532] Sat Jun 15 14:02:24 2013  INFO UninstallSeq property not found in database [    4532] Sat Jun 15 14:02:24 2013 FATAL sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database [    4532] Sat Jun 15 14:02:24 2013  INFO Completing un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{AE9B837F-D135-42FC-BE03-33545B5DCBDC}.db Physical payload uninstall result:1 [    4980] Sat Jun 15 14:02:25 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=* :: END TIMER :: [Payload Operation :{AE9B837F-D135-42FC-BE03-33545B5DCBDC}] took 1006.13 miliseconds (1.00613 seconds) User specified overrideFile:  Calling the ROLLBACK custom action code for pre-remove for payload {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 Calling the custom action code for pre-remove for payload {56540320-C921-1029-83D9-FE864D1FC1DF} ::START TIMER:: [Payload Operation :{56540320-C921-1029-83D9-FE864D1FC1DF}] [    5396] Sat Jun 15 14:02:25 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Installer Operation: PayloadUninstaller *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Session {15FEDA5F-141C-4127-8D7E-B962D1742728} modify request for AdobeCode: {56540320-C921-1029-83D9-FE864D1FC1DF} Effective AdobeCode for: {56540320-C921-1029-83D9-FE864D1FC1DF} is {56540320-C921-1029-83D9-FE864D1FC1DF} Uninstalling payload [    5396] Sat Jun 15 14:02:25 2013 FATAL sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database [    5396] Sat Jun 15 14:02:25 2013  INFO INSTALLDIR property not found in database Beginning un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{56540320-C921-1029-83D9-FE864D1FC1DF}.db [    5396] Sat Jun 15 14:02:25 2013 FATAL sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database [    5396] Sat Jun 15 14:02:25 2013  INFO UninstallSeq property not found in database [    5396] Sat Jun 15 14:02:25 2013 FATAL sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database [    5396] Sat Jun 15 14:02:25 2013  INFO Completing un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{56540320-C921-1029-83D9-FE864D1FC1DF}.db Physical payload uninstall result:1 [    4980] Sat Jun 15 14:02:26 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=* :: END TIMER :: [Payload Operation :{56540320-C921-1029-83D9-FE864D1FC1DF}] took 1000.05 miliseconds (1.00005 seconds) DTR = 75.996 KBPS (0.0742148 MBPS) User specified overrideFile:  Calling the ROLLBACK custom action code for pre-remove for payload {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 No operation.  We're done: Updating driver data - Action: Remove driver entry Updating driver data successful. Driver entry was added. ARP estimated size 528513KB [    4980] Sat Jun 15 14:02:28 2013  INFO Total components installed: 0 Total components repaired: 0 Total components removed: 0 [    4980] Sat Jun 15 14:02:28 2013 ERROR The following payload errors were found during install:  - AdobeColorCommonSetCMYK: Install failed  - AdobeColorJA CS5: Install failed  - Adobe ReviewPanel CS5: Install failed  - AdobeColorVideoProfilesCS CS5: Install failed  - Adobe WinSoft Linguistics Plugin CS5: Install failed  - Required Common Fonts Installation: Install failed  - Recommended Common Fonts Installation: Install failed [    4980] Sat Jun 15 14:02:28 2013  INFO >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Restarting your computer is recommended: In order to complete the installation, please restart the computer >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Call PostSession Custom Hook :: END TIMER :: [Total Timer] took 12098.7 miliseconds (12.0987 seconds) DTR = 283.007 KBPS (0.276374 MBPS) -------------------------------------- Summary --------------------------------------  - 35 fatal error(s), 8 error(s), 2 warning(s) WARNING: The payload: Adobe Photoshop CS5 Core  {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} requires a UI parent with following specification:      Family: Photoshop      ProductName: Adobe Photoshop CS5 Core_x64      This parent relationship is not satisfied, because this payload is not present in this session. WARNING: Payload {15FEDA5F-141C-4127-8D7E-B962D1742728} Adobe Photoshop CS5 is not installed so should not be there in the deployment file ERROR: The following payload errors were found during install: ERROR:  - AdobeColorCommonSetCMYK: Install failed ERROR:  - AdobeColorJA CS5: Install failed ERROR:  - Adobe ReviewPanel CS5: Install failed ERROR:  - AdobeColorVideoProfilesCS CS5: Install failed ERROR:  - Adobe WinSoft Linguistics Plugin CS5: Install failed ERROR:  - Required Common Fonts Installation: Install failed ERROR:  - Recommended Common Fonts Installation: Install failed FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database  Search the same string above to find when the error occured. ------------------------------------------------------------------------------------- Exit Code: 6 - Silent workflow completed with errors *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* END - Installer Session *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Visit http://www.adobe.com/go/loganalyzer/ for more information *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* START - Installer Session *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* RIBS version: 3.0.121.0 Win OS version: 6.1.0.0  Type: 1 ::START TIMER:: [Total Timer] CHECK: Single instance running CHECK : Credentials Load Deployment File Create Required Folders Assuming uninstall mode Lookup for master payload Ready to initialize session to start with ... ::START TIMER:: [CreatePayloadSession] Supported RIBS version range: [0.0.66.0,3.0.121.0] ----------------- CreatePayloadSession: machine is x86 --------------- ______ Verify Dependency Subscribers ______ [    3764] Sat Jun 15 14:13:46 2013  WARN The payload: Adobe Photoshop CS5 Core  {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} requires a UI parent with following specification:      Family: Photoshop      ProductName: Adobe Photoshop CS5 Core_x64      This parent relationship is not satisfied, because this payload is not present in this session. [    3764] Sat Jun 15 14:13:46 2013  INFO Setting property "driverAdobeCode" to: {15FEDA5F-141C-4127-8D7E-B962D1742728} Setting property "mediaSignature" to: {15FEDA5F-141C-4127-8D7E-B962D1742728} Setting property "removeUserPrefs" to: 1 Overwrite property "userASUPath" to: C:\PROGRA~1\COMMON~1\Adobe\OOBE\PDApp\core\..\DWA Found payload actions:  Deciding what installer mode to use... {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US not installed {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core not installed {15FEDA5F-141C-4127-8D7E-B962D1742728} Adobe Photoshop CS5 not installed {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 not installed {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB not installed {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US not installed {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral not installed {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5 not installed {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 not installed {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5 not installed {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 not installed {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5 not installed {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5 not installed {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 not installed {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5 not installed {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 not installed {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5 not installed {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB not installed {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player not installed {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 not installed {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR not installed {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 not installed {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support not installed {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 not installed {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 not installed {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 not installed {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw not installed {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 not installed {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 not installed {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule not installed {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 not installed {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 not installed {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp not installed {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5 not installed {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 not installed {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer not installed {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE not installed {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 not installed {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 not installed {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding not installed {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 not installed {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 not installed {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 not installed {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 not installed BEGIN Setting requested payload actions Value returned on lookup of payload: {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is: true Action string for  {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB  is none Payload {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is extension payload. Aligning its action according to parent. Value returned on lookup of payload: {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is: false Action string for  {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US  is none Payload {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is extension payload. Aligning its action according to parent. Value returned on lookup of payload: {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core is: false Action string for  {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core  is none Value returned on lookup of payload: {15FEDA5F-141C-4127-8D7E-B962D1742728} Adobe Photoshop CS5 is: false [    3764] Sat Jun 15 14:13:46 2013  WARN Payload {15FEDA5F-141C-4127-8D7E-B962D1742728} Adobe Photoshop CS5 is not installed so should not be there in the deployment file [    3764] Sat Jun 15 14:13:46 2013  INFO Value returned on lookup of payload: {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 is: false Action string for  {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5  is none Value returned on lookup of payload: {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is: false Action string for  {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB  is none Payload {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is extension payload. Aligning its action according to parent. Value returned on lookup of payload: {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is: false Action string for  {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US  is none Payload {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is extension payload. Aligning its action according to parent. Value returned on lookup of payload: {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral is: false Action string for  {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral  is none Value returned on lookup of payload: {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5 is: false Action string for  {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5  is none Value returned on lookup of payload: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 is: false Action string for  {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5  is none Value returned on lookup of payload: {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation is: true Action string for  {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation  is none Value returned on lookup of payload: {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation is: true Action string for  {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation  is none Value returned on lookup of payload: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5 is: false Action string for  {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5  is none Value returned on lookup of payload: {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 is: false Action string for  {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5  is none Value returned on lookup of payload: {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5 is: true Action string for  {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5  is none Value returned on lookup of payload: {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5 is: false Action string for  {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5  is none Value returned on lookup of payload: {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5 is: false Action string for  {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5  is none Value returned on lookup of payload: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 is: false Action string for  {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5  is none Value returned on lookup of payload: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5 is: false Action string for  {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5  is none Value returned on lookup of payload: {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 is: true Action string for  {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5  is none Value returned on lookup of payload: {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 is: false Action string for  {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5  is none Value returned on lookup of payload: {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5 is: false Action string for  {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5  is none Value returned on lookup of payload: {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB is: false Action string for  {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB  is none Value returned on lookup of payload: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK is: true Action string for  {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK  is none Value returned on lookup of payload: {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 is: true Action string for  {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5  is none Value returned on lookup of payload: {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 is: true Action string for  {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5  is none Value returned on lookup of payload: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player is: false Action string for  {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player  is none Value returned on lookup of payload: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 is: false Action string for  {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5  is none Value returned on lookup of payload: {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR is: false Action string for  {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR  is none Value returned on lookup of payload: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 is: true Action string for  {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86  is none Value returned on lookup of payload: {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support is: false Action string for  {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support  is none Value returned on lookup of payload: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 is: false Action string for  {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5  is none Value returned on lookup of payload: {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 is: false Action string for  {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5  is none Value returned on lookup of payload: {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 is: false Action string for  {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5  is none Value returned on lookup of payload: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw is: false Action string for  {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw  is none Value returned on lookup of payload: {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 is: false Action string for  {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5  is none Value returned on lookup of payload: {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 is: false Action string for  {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5  is none Value returned on lookup of payload: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule is: false Action string for  {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule  is none Value returned on lookup of payload: {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 is: false Action string for  {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5  is none Value returned on lookup of payload: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 is: false Action string for  {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5  is none Value returned on lookup of payload: {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp is: false Action string for  {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp  is none Value returned on lookup of payload: {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5 is: false Action string for  {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5  is none Value returned on lookup of payload: {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 is: false Action string for  {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0  is none Value returned on lookup of payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer is: false Action string for  {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer  is none Value returned on lookup of payload: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE is: false Action string for  {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE  is none Value returned on lookup of payload: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 is: true Action string for  {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86  is none Value returned on lookup of payload: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 is: true Action string for  {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86  is none Value returned on lookup of payload: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding is: false Action string for  {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding  is none Value returned on lookup of payload: {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 is: true Action string for  {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86  is none Value returned on lookup of payload: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 is: true Action string for  {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86  is none Value returned on lookup of payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 is: true Action string for  {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86  is none Value returned on lookup of payload: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 is: true Action string for  {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86  is none END Setting requested payload actions INSTALLDIR passed path basic path validation: C:\Program Files\Adobe [    3764] Sat Jun 15 14:13:47 2013  INFO Payloads passed preflight validation. Call PreSession Custom Hook Calling the custom action code for pre-remove for payload {CBDD7465-CE11-4A58-9497-C370B65923F1} ::START TIMER:: [Payload Operation :{CBDD7465-CE11-4A58-9497-C370B65923F1}] [    3432] Sat Jun 15 14:13:47 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Installer Operation: PayloadUninstaller *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Session {15FEDA5F-141C-4127-8D7E-B962D1742728} modify request for AdobeCode: {CBDD7465-CE11-4A58-9497-C370B65923F1} Effective AdobeCode for: {CBDD7465-CE11-4A58-9497-C370B65923F1} is {CBDD7465-CE11-4A58-9497-C370B65923F1} Uninstalling payload [    3432] Sat Jun 15 14:13:47 2013 FATAL sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database [    3432] Sat Jun 15 14:13:47 2013  INFO INSTALLDIR property not found in database Beginning un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{CBDD7465-CE11-4A58-9497-C370B65923F1}.db [    3432] Sat Jun 15 14:13:47 2013 FATAL sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database [    3432] Sat Jun 15 14:13:47 2013  INFO UninstallSeq property not found in database [    3432] Sat Jun 15 14:13:47 2013 FATAL sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database [    3432] Sat Jun 15 14:13:47 2013  INFO Completing un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{CBDD7465-CE11-4A58-9497-C370B65923F1}.db Physical payload uninstall result:1 [    3764] Sat Jun 15 14:13:48 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=* :: END TIMER :: [Payload Operation :{CBDD7465-CE11-4A58-9497-C370B65923F1}] took 1008.58 miliseconds (1.00858 seconds) User specified overrideFile:  Calling the ROLLBACK custom action code for pre-remove for payload {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation Calling the custom action code for pre-remove for payload {E39A5ABD-516B-46F9-A042-694BBA6A4E08} ::START TIMER:: [Payload Operation :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}] [    3876] Sat Jun 15 14:13:48 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Installer Operation: PayloadUninstaller *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Session {15FEDA5F-141C-4127-8D7E-B962D1742728} modify request for AdobeCode: {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Effective AdobeCode for: {E39A5ABD-516B-46F9-A042-694BBA6A4E08} is {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Uninstalling payload [    3876] Sat Jun 15 14:13:48 2013 FATAL sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database [    3876] Sat Jun 15 14:13:48 2013  INFO INSTALLDIR property not found in database Beginning un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{E39A5ABD-516B-46F9-A042-694BBA6A4E08}.db [    3876] Sat Jun 15 14:13:48 2013 FATAL sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database [    3876] Sat Jun 15 14:13:48 2013  INFO UninstallSeq property not found in database [    3876] Sat Jun 15 14:13:48 2013 FATAL sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database [    3876] Sat Jun 15 14:13:48 2013  INFO Completing un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{E39A5ABD-516B-46F9-A042-694BBA6A4E08}.db Physical payload uninstall result:1 [    3764] Sat Jun 15 14:13:49 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=* :: END TIMER :: [Payload Operation :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}] took 1004.66 miliseconds (1.00466 seconds) DTR = 107.499 KBPS (0.104979 MBPS) User specified overrideFile:  Calling the ROLLBACK custom action code for pre-remove for payload {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation Calling the custom action code for pre-remove for payload {73A4DC5E-226E-42BA-8ECA-2822592AC044} ::START TIMER:: [Payload Operation :{73A4DC5E-226E-42BA-8ECA-2822592AC044}] [    3592] Sat Jun 15 14:13:49 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Installer Operation: PayloadUninstaller *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Session {15FEDA5F-141C-4127-8D7E-B962D1742728} modify request for AdobeCode: {73A4DC5E-226E-42BA-8ECA-2822592AC044} Effective AdobeCode for: {73A4DC5E-226E-42BA-8ECA-2822592AC044} is {73A4DC5E-226E-42BA-8ECA-2822592AC044} Uninstalling payload [    3592] Sat Jun 15 14:13:49 2013 FATAL sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database [    3592] Sat Jun 15 14:13:49 2013  INFO INSTALLDIR property not found in database Beginning un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{73A4DC5E-226E-42BA-8ECA-2822592AC044}.db [    3592] Sat Jun 15 14:13:49 2013 FATAL sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database [    3592] Sat Jun 15 14:13:49 2013  INFO UninstallSeq property not found in database [    3592] Sat Jun 15 14:13:49 2013 FATAL sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database [    3592] Sat Jun 15 14:13:49 2013  INFO Completing un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{73A4DC5E-226E-42BA-8ECA-2822592AC044}.db Physical payload uninstall result:1 [    3764] Sat Jun 15 14:13:50 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=* :: END TIMER :: [Payload Operation :{73A4DC5E-226E-42BA-8ECA-2822592AC044}] took 1003.43 miliseconds (1.00343 seconds) User specified overrideFile:  Calling the ROLLBACK custom action code for pre-remove for payload {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5 Calling the custom action code for pre-remove for payload {54F4466A-091A-46DA-B697-43D55CEF9DF6} ::START TIMER:: [Payload Operation :{54F4466A-091A-46DA-B697-43D55CEF9DF6}] [     776] Sat Jun 15 14:13:50 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Installer Operation: PayloadUninstaller *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Session {15FEDA5F-141C-4127-8D7E-B962D1742728} modify request for AdobeCode: {54F4466A-091A-46DA-B697-43D55CEF9DF6} Effective AdobeCode for: {54F4466A-091A-46DA-B697-43D55CEF9DF6} is {54F4466A-091A-46DA-B697-43D55CEF9DF6} Uninstalling payload [     776] Sat Jun 15 14:13:50 2013 FATAL sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database [     776] Sat Jun 15 14:13:50 2013  INFO INSTALLDIR property not found in database Beginning un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{54F4466A-091A-46DA-B697-43D55CEF9DF6}.db [     776] Sat Jun 15 14:13:50 2013 FATAL sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database [     776] Sat Jun 15 14:13:50 2013  INFO UninstallSeq property not found in database [     776] Sat Jun 15 14:13:50 2013 FATAL sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database [     776] Sat Jun 15 14:13:50 2013  INFO Completing un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{54F4466A-091A-46DA-B697-43D55CEF9DF6}.db Physical payload uninstall result:1 [    3764] Sat Jun 15 14:13:51 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=* :: END TIMER :: [Payload Operation :{54F4466A-091A-46DA-B697-43D55CEF9DF6}] took 993.308 miliseconds (0.993308 seconds) User specified overrideFile:  Calling the ROLLBACK custom action code for pre-remove for payload {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 Calling the custom action code for pre-remove for payload {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} ::START TIMER:: [Payload Operation :{39CB2E53-5326-4939-8B5A-0402C6EFBFE3}] [     780] Sat Jun 15 14:13:51 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Installer Operation: PayloadUninstaller *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Session {15FEDA5F-141C-4127-8D7E-B962D1742728} modify request for AdobeCode: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} Effective AdobeCode for: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} is {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} Uninstalling payload [     780] Sat Jun 15 14:13:51 2013 FATAL sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database [     780] Sat Jun 15 14:13:51 2013  INFO INSTALLDIR property not found in database Beginning un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{39CB2E53-5326-4939-8B5A-0402C6EFBFE3}.db [     780] Sat Jun 15 14:13:51 2013 FATAL sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database [     780] Sat Jun 15 14:13:51 2013  INFO UninstallSeq property not found in database [     780] Sat Jun 15 14:13:51 2013 FATAL sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database [     780] Sat Jun 15 14:13:51 2013  INFO Completing un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{39CB2E53-5326-4939-8B5A-0402C6EFBFE3}.db Physical payload uninstall result:1 [    3764] Sat Jun 15 14:13:52 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=* :: END TIMER :: [Payload Operation :{39CB2E53-5326-4939-8B5A-0402C6EFBFE3}] took 993.286 miliseconds (0.993286 seconds) User specified overrideFile:  Calling the ROLLBACK custom action code for pre-remove for payload {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK Calling the custom action code for pre-remove for payload {AE9B837F-D135-42FC-BE03-33545B5DCBDC} ::START TIMER:: [Payload Operation :{AE9B837F-D135-42FC-BE03-33545B5DCBDC}] [    3972] Sat Jun 15 14:13:52 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Installer Operation: PayloadUninstaller *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Session {15FEDA5F-141C-4127-8D7E-B962D1742728} modify request for AdobeCode: {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Effective AdobeCode for: {AE9B837F-D135-42FC-BE03-33545B5DCBDC} is {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Uninstalling payload [    3972] Sat Jun 15 14:13:52 2013 FATAL sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database [    3972] Sat Jun 15 14:13:52 2013  INFO INSTALLDIR property not found in database Beginning un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{AE9B837F-D135-42FC-BE03-33545B5DCBDC}.db [    3972] Sat Jun 15 14:13:52 2013 FATAL sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database [    3972] Sat Jun 15 14:13:52 2013  INFO UninstallSeq property not found in database [    3972] Sat Jun 15 14:13:52 2013 FATAL sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database [    3972] Sat Jun 15 14:13:52 2013  INFO Completing un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{AE9B837F-D135-42FC-BE03-33545B5DCBDC}.db Physical payload uninstall result:1 [    3764] Sat Jun 15 14:13:53 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=* :: END TIMER :: [Payload Operation :{AE9B837F-D135-42FC-BE03-33545B5DCBDC}] took 1002.08 miliseconds (1.00208 seconds) User specified overrideFile:  Calling the ROLLBACK custom action code for pre-remove for payload {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 Calling the custom action code for pre-remove for payload {56540320-C921-1029-83D9-FE864D1FC1DF} ::START TIMER:: [Payload Operation :{56540320-C921-1029-83D9-FE864D1FC1DF}] [     588] Sat Jun 15 14:13:53 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Installer Operation: PayloadUninstaller *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Session {15FEDA5F-141C-4127-8D7E-B962D1742728} modify request for AdobeCode: {56540320-C921-1029-83D9-FE864D1FC1DF} Effective AdobeCode for: {56540320-C921-1029-83D9-FE864D1FC1DF} is {56540320-C921-1029-83D9-FE864D1FC1DF} Uninstalling payload [     588] Sat Jun 15 14:13:53 2013 FATAL sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database [     588] Sat Jun 15 14:13:53 2013  INFO INSTALLDIR property not found in database Beginning un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{56540320-C921-1029-83D9-FE864D1FC1DF}.db [     588] Sat Jun 15 14:13:53 2013 FATAL sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database [     588] Sat Jun 15 14:13:53 2013  INFO UninstallSeq property not found in database [     588] Sat Jun 15 14:13:53 2013 FATAL sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database [     588] Sat Jun 15 14:13:53 2013  INFO Completing un-installation for payload at C:\Program Files\Common Files\Adobe\Installers\uninstall\{56540320-C921-1029-83D9-FE864D1FC1DF}.db Physical payload uninstall result:1 [    3764] Sat Jun 15 14:13:54 2013  INFO *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=* :: END TIMER :: [Payload Operation :{56540320-C921-1029-83D9-FE864D1FC1DF}] took 1004.65 miliseconds (1.00465 seconds) User specified overrideFile:  Calling the ROLLBACK custom action code for pre-remove for payload {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 No operation.  We're done: Updating driver data - Action: Remove driver entry Updating driver data successful. Driver entry was added. ARP estimated size 528513KB [    3764] Sat Jun 15 14:13:56 2013  INFO Total components installed: 0 Total components repaired: 0 Total components removed: 0 [    3764] Sat Jun 15 14:13:56 2013 ERROR The following payload errors were found during install:  - AdobeColorCommonSetCMYK: Install failed  - AdobeColorJA CS5: Install failed  - Adobe ReviewPanel CS5: Install failed  - AdobeColorVideoProfilesCS CS5: Install failed  - Adobe WinSoft Linguistics Plugin CS5: Install failed  - Required Common Fonts Installation: Install failed  - Recommended Common Fonts Installation: Install failed [    3764] Sat Jun 15 14:13:56 2013  INFO >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Restarting your computer is recommended: In order to complete the installation, please restart the computer >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Call PostSession Custom Hook :: END TIMER :: [Total Timer] took 10051 miliseconds (10.051 seconds) DTR = 17.9086 KBPS (0.0174889 MBPS) -------------------------------------- Summary --------------------------------------  - 35 fatal error(s), 8 error(s), 2 warning(s) WARNING: The payload: Adobe Photoshop CS5 Core  {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} requires a UI parent with following specification:      Family: Photoshop      ProductName: Adobe Photoshop CS5 Core_x64      This parent relationship is not satisfied, because this payload is not present in this session. WARNING: Payload {15FEDA5F-141C-4127-8D7E-B962D1742728} Adobe Photoshop CS5 is not installed so should not be there in the deployment file ERROR: The following payload errors were found during install: ERROR:  - AdobeColorCommonSetCMYK: Install failed ERROR:  - AdobeColorJA CS5: Install failed ERROR:  - Adobe ReviewPanel CS5: Install failed ERROR:  - AdobeColorVideoProfilesCS CS5: Install failed ERROR:  - Adobe WinSoft Linguistics Plugin CS5: Install failed ERROR:  - Required Common Fonts Installation: Install failed ERROR:  - Recommended Common Fonts Installation: Install failed FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='INSTALLDIR'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM CommandLib' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='UninstallSeq'' (26) file is encrypted or is not a database FATAL ERROR: sqlite prepare: 'SELECT * FROM ExecuteSeq ORDER BY sequenceNum' (26) file is encrypted or is not a database  Search the same string above to find when the error occured. ------------------------------------------------------------------------------------- Exit Code: 6 - Silent workflow completed with errors *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* END - Installer Session *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
Jun 15, 2013 Jun 15, 2013
Refer to this:
Error "Exit 6" or "Exit 7"
Mylenium
the log you posted is about a cs5 installation.  that doesn't match your cs3 screenshot.
Guest
This system previously had CS5 on it, which we had to get rid of and downgrade to the CS3 we're currently trying to install.
The log file is dated to  06-15-2013. Does that mean the old CS5 install is still lingering and causing a clash with our new install?
How are we to get rid of it? We've tried uninstalling everything related, removed folders manually best we can and ran CCleaner to delete any unused registry keys.
did you run the cleaner for both cs5 and cs3?
Guest
CCleaner checks every registry not in use.
We did use AdobeCreativeSuiteCleanerTool.exe version 1.0, i don't recall what CS-version if cleaned. We thought it was universal?
it's universal in the sense that it can clean cs3,cs4,cs5,cs5.5 and cs6.  but you select which version to clean.
you would run it twice to clean cs3 and cs5.
Guest
we tried that, and it said it detected an instance of CS5 which it reported removing, but after reboot (and another session of CCleaner), we still got the error in my origional post.
install logs?
Guest
Jun 16, 2013 Jun 16, 2013
kglad wrote:
install logs?
here is the last activity from today in the:Adobe Creative Suite 3 Design Premium 1.0.log
[1924] Sun Jun 16 10:38:13 2013  INFO
[1924] Sun Jun 16 10:38:14 2013  INFO
RIBS version: 1.0.135.0
-------------------- BEGIN - Proxy File Summary - BEGIN --------------------
AdobeCode: {00E5C764-9525-44C3-8404-712AD06AE12A}
Path: D:\Adobe CS3\payloads\AdobeDreamweaver9en_US\AdobeDreamweaver9en_US.boot.xml
AdobeCode: {06CEA754-616B-40CA-B807-B5F045628BC8}
Path: D:\Adobe CS3\payloads\AdobeInDesignCS3IconHandler\AdobeInDesignCS3IconHandler.boot.xml
AdobeCode: {078B624D-5FF6-40CF-8B92-312FD03FE4EB}
Path: D:\Adobe CS3\payloads\AdobeTypeSupportAll\AdobeTypeSupportAll.boot.xml
AdobeCode: {0A880438-9557-49ED-8E86-BD7B24612713}
Path: D:\Adobe CS3\payloads\AdobeDefaultLanguageCS3All\AdobeDefaultLanguageCS3All.boot.xml
AdobeCode: {193F8A7B-1853-48D5-88AC-19446C2C1D13}
Path: D:\Adobe CS3\payloads\AdobeExtendScriptToolKitAll\AdobeExtendScriptToolKitAll.boot.xml
AdobeCode: {1953AC8E-E91C-437F-83CC-82869A128FDE}
Path: D:\Adobe CS3\payloads\AdobeFontsAll\AdobeFontsAll.boot.xml
AdobeCode: {1C52C3C3-0BCB-4AE2-BA9D-9534C47EE221}
Path: D:\Adobe CS3\payloads\AdobeBridgeTalkPluginAll\AdobeBridgeTalkPluginAll.boot.xml
AdobeCode: {24D77A7C-E10B-4057-9974-FAB8BFDAC853}
Path: D:\Adobe CS3\payloads\AdobeInDesign5en_US\AdobeInDesign5en_US.boot.xml
AdobeCode: {2715DA38-F987-47F1-A768-F94D1B09074A}
Path: D:\Adobe CS3\payloads\AdobeColorEU_RecommendedAll\AdobeColorEU_RecommendedAll.boot.xml
AdobeCode: {28729DCD-3C60-45E3-9C25-4F5056802811}
Path: D:\Adobe CS3\payloads\AdobeColorJA_RecommendedAll\AdobeColorJA_RecommendedAll.boot.xml
AdobeCode: {2E4528EC-5ACB-4D19-98DD-6CC3594EB1A1}
Path: D:\Adobe CS3\payloads\AdobeALMAnchorServiceAll\AdobeALMAnchorServiceAll.boot.xml
AdobeCode: {30C4B843-28DA-466F-AFCA-CB0ED153C826}
Path: D:\Adobe CS3\payloads\AdobePhotoshop10en_US\AdobePhotoshop10en_US.boot.xml
AdobeCode: {3BC8460B-085E-47F3-9C62-8FFCBAF11D78}
Path: D:\Adobe CS3\payloads\AdobeFlash9en_US\AdobeFlash9en_US.boot.xml
AdobeCode: {450CDEDE-2E5F-4659-AC0D-BA693424ACAF}
Path: D:\Adobe CS3\payloads\AdobeExtensionManager1.8All\AdobeExtensionManager1.8All.boot.xml
AdobeCode: {56E0400B-3C4E-4600-A4D7-425EAE09E079}
Path: D:\Adobe CS3\payloads\AdobeFlashPlayer9_plDbg_mul\AdobeFlashPlayer9_plDbg_mul.proxy.xml
AdobeCode: {5CE549BC-DD75-4D03-971A-4D598AC46CF2}
Path: D:\Adobe CS3\payloads\AdobeLinguisticsAll\AdobeLinguisticsAll.boot.xml
AdobeCode: {61D23D99-3398-414E-974E-EBAE498BB298}
Path: D:\Adobe CS3\payloads\AdobeBridge2All\AdobeBridge2All.boot.xml
AdobeCode: {65B2E542-E491-4762-90DB-C18B1200A093}
Path: D:\Adobe CS3\payloads\AdobeXMPPanelsAll\AdobeXMPPanelsAll.boot.xml
AdobeCode: {6EB45C70-7B6E-456C-8C23-58A8409C0E3D}
Path: D:\Adobe CS3\payloads\AdobeFlashPlayer9_axDbg_mul\AdobeFlashPlayer9_axDbg_mul.proxy.xml
AdobeCode: {7005ECBC-F54B-42FD-81E4-934BC43FA329}
Path: D:\Adobe CS3\payloads\AdobeDesignSuitePremiumen_US_Volume\AdobeDesignSuitePremiumen_US_Volume.boot.xml
AdobeCode: {7B53463B-283F-44FF-94B2-CAB60DDE3159}
Path: D:\Adobe CS3\payloads\AdobeDeviceCentralAll\AdobeDeviceCentralAll.boot.xml
AdobeCode: {7BB7F66A-D798-45A3-A383-0727FB1EBF8E}
Path: D:\Adobe CS3\payloads\AdobeFlashVideoEncoder2en_US\AdobeFlashVideoEncoder2en_US.boot.xml
AdobeCode: {7E8C0B6B-A9DD-47C2-9589-43442F753117}
Path: D:\Adobe CS3\payloads\AdobeColorJA_ExtraSettingsAll\AdobeColorJA_ExtraSettingsAll.boot.xml
AdobeCode: {8CFB2641-1439-4FA4-A72E-1658DC58B2F7}
Path: D:\Adobe CS3\payloads\AdobePDFSettingsAll\AdobePDFSettingsAll.boot.xml
AdobeCode: {8cec782a-3a7a-4f34-8452-78d05847efa2}
Path: D:\Adobe CS3\payloads\AdobeAssetServices3All\AdobeAssetServices3All.boot.xml
AdobeCode: {9C4C65E9-3568-4643-A6B0-6FC5D229D987}
Path: D:\Adobe CS3\payloads\AdobeStockPhotos1.5All\AdobeStockPhotos1.5All.boot.xml
AdobeCode: {A874B792-CECE-448A-A05E-B73E2B29299B}
Path: D:\Adobe CS3\payloads\AdobeCameraRaw4.0All\AdobeCameraRaw4.0All.boot.xml
AdobeCode: {AC76BA86-1033-0000-7760-000000000003}
Path: D:\Adobe CS3\payloads\AdobeAcrobat8en_US\AdobeAcrobat8en_US.proxy.xml
AdobeCode: {AD61B275-AE44-4779-8E29-DF10832F5524}
Path: D:\Adobe CS3\payloads\AdobeSINGAll\AdobeSINGAll.boot.xml
AdobeCode: {B2BF8160-B481-4F4A-B4F1-AD01DCC651DC}
Path: D:\Adobe CS3\payloads\AdobeMotionPictureAll\AdobeMotionPictureAll.boot.xml
AdobeCode: {B62B14F8-19D1-4B2E-9608-DC79E98C0FF3}
Path: D:\Adobe CS3\payloads\AdobeHelpViewerAll\AdobeHelpViewerAll.boot.xml
AdobeCode: {B99ACF49-9DDD-448F-B9BB-A8D49F6D3884}
Path: D:\Adobe CS3\payloads\AdobeWinSoftLinguisticsPluginAll\AdobeWinSoftLinguisticsPluginAll.boot.xml
AdobeCode: {BC4E20A8-BE55-4482-8A1B-606080887D46}
Path: D:\Adobe CS3\payloads\AdobePDFL8All\AdobePDFL8All.boot.xml
AdobeCode: {BDFC4A4E-D8D3-44B2-B615-11D05A431FE7}
Path: D:\Adobe CS3\payloads\AdobeColorNA_ExtraSettingsAll\AdobeColorNA_ExtraSettingsAll.boot.xml
AdobeCode: {C4519961-AC64-4565-B3AF-9050296B5D5A}
Path: D:\Adobe CS3\payloads\AdobeIllustrator13en_US\AdobeIllustrator13en_US.boot.xml
AdobeCode: {C9BE6782-B94E-4EA6-9208-CF92811B28E7}
Path: D:\Adobe CS3\payloads\BridgeStartMeeting\BridgeStartMeeting.boot.xml
AdobeCode: {D12E7F7F-9D98-47B9-A16C-A6C5226FE642}
Path: D:\Adobe CS3\payloads\AHVSTIAll\AHVSTIAll.boot.xml
AdobeCode: {D2968B66-F6C1-45AE-A378-04D9FB541210}
Path: D:\Adobe CS3\payloads\AdobeColorEU_ExtraSettingsAll\AdobeColorEU_ExtraSettingsAll.boot.xml
AdobeCode: {D59D24C6-BFD5-4D92-8EE3-06055F6E2827}
Path: D:\Adobe CS3\payloads\AdobeColorPhotoshopAll\AdobeColorPhotoshopAll.boot.xml
AdobeCode: {E1654C7B-8CBF-4301-8B8A-CFA1EB656F4D}
Path: D:\Adobe CS3\payloads\AdobeColorCommonSetAll\AdobeColorCommonSetAll.boot.xml
AdobeCode: {ED77DAD4-1EE4-4259-ABC2-909C58FDA4C1}
Path: D:\Adobe CS3\payloads\AdobeWASAll\AdobeWASAll.boot.xml
AdobeCode: {F33E4400-F4B8-46F9-8B3E-307CCC3B4860}
Path: D:\Adobe CS3\payloads\AdobeColorNA_RecommendedAll\AdobeColorNA_RecommendedAll.boot.xml
AdobeCode: {FA70D08A-5D90-496D-AF9A-9DBCEE4FC005}
Path: D:\Adobe CS3\payloads\AdobeAUM5.1All\AdobeAUM5.1All.boot.xml
AdobeCode: {FB235376-7904-4164-88F4-13CA3944BBB9}
Path: D:\Adobe CS3\payloads\AdobeCMapsAll\AdobeCMapsAll.boot.xml
AdobeCode: {abd781e6-d5ca-45aa-a5f7-f64799eb1c04}
Path: D:\Adobe CS3\payloads\AdobeVersionCue3All\AdobeVersionCue3All.boot.xml
AdobeCode: {de08a23f-60bd-41d3-b703-c1a7bfbc2614}
Path: D:\Adobe CS3\payloads\AdobeVersionCueClient3All\AdobeVersionCueClient3All.boot.xml
--------------------  END  - Proxy File Summary -  END  --------------------
-------------------- BEGIN - Updating Media Sources - BEGIN --------------------
Updated source path: D:\Adobe CS3
Updating media info for: {00E5C764-9525-44C3-8404-712AD06AE12A}, Effective: {00E5C764-9525-44C3-8404-712AD06AE12A}
Updated install source from removable media info
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeDreamweaver9en_US\AdobeDreamweaver9en_US.msi
Updating media info for: {06CEA754-616B-40CA-B807-B5F045628BC8}, Effective: {06CEA754-616B-40CA-B807-B5F045628BC8}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeInDesignCS3IconHandler\AdobeInDesignCS3IconHandler.msi
Updating media info for: {078B624D-5FF6-40CF-8B92-312FD03FE4EB}, Effective: {078B624D-5FF6-40CF-8B92-312FD03FE4EB}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeTypeSupportAll\AdobeTypeSupportAll.msi
Updating media info for: {0A880438-9557-49ED-8E86-BD7B24612713}, Effective: {0A880438-9557-49ED-8E86-BD7B24612713}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeDefaultLanguageCS3All\AdobeDefaultLanguageCS3All.msi
Updating media info for: {193F8A7B-1853-48D5-88AC-19446C2C1D13}, Effective: {193F8A7B-1853-48D5-88AC-19446C2C1D13}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeExtendScriptToolKitAll\AdobeExtendScriptToolKitAll.msi
Updating media info for: {1953AC8E-E91C-437F-83CC-82869A128FDE}, Effective: {1953AC8E-E91C-437F-83CC-82869A128FDE}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeFontsAll\AdobeFontsAll.msi
Updating media info for: {1C52C3C3-0BCB-4AE2-BA9D-9534C47EE221}, Effective: {1C52C3C3-0BCB-4AE2-BA9D-9534C47EE221}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeBridgeTalkPluginAll\AdobeBridgeTalkPluginAll.msi
Updating media info for: {24D77A7C-E10B-4057-9974-FAB8BFDAC853}, Effective: {24D77A7C-E10B-4057-9974-FAB8BFDAC853}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeInDesign5en_US\AdobeInDesign5en_US.msi
Updating media info for: {2715DA38-F987-47F1-A768-F94D1B09074A}, Effective: {2715DA38-F987-47F1-A768-F94D1B09074A}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeColorEU_RecommendedAll\AdobeColorEU_RecommendedAll.msi
Updating media info for: {28729DCD-3C60-45E3-9C25-4F5056802811}, Effective: {28729DCD-3C60-45E3-9C25-4F5056802811}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeColorJA_RecommendedAll\AdobeColorJA_RecommendedAll.msi
Updating media info for: {2E4528EC-5ACB-4D19-98DD-6CC3594EB1A1}, Effective: {2E4528EC-5ACB-4D19-98DD-6CC3594EB1A1}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeALMAnchorServiceAll\AdobeALMAnchorServiceAll.msi
Updating media info for: {30C4B843-28DA-466F-AFCA-CB0ED153C826}, Effective: {30C4B843-28DA-466F-AFCA-CB0ED153C826}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobePhotoshop10en_US\AdobePhotoshop10en_US.msi
Updating media info for: {3BC8460B-085E-47F3-9C62-8FFCBAF11D78}, Effective: {3BC8460B-085E-47F3-9C62-8FFCBAF11D78}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeFlash9en_US\AdobeFlash9en_US.msi
Updating media info for: {450CDEDE-2E5F-4659-AC0D-BA693424ACAF}, Effective: {450CDEDE-2E5F-4659-AC0D-BA693424ACAF}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeExtensionManager1.8All\AdobeExtensionManager1.8All.msi
Updating media info for: {56E0400B-3C4E-4600-A4D7-425EAE09E079}, Effective: {56E0400B-3C4E-4600-A4D7-425EAE09E079}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeFlashPlayer9_plDbg_mul\AdobeFlashPlayer9_plDbg_mul.msi
Updating media info for: {5CE549BC-DD75-4D03-971A-4D598AC46CF2}, Effective: {5CE549BC-DD75-4D03-971A-4D598AC46CF2}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeLinguisticsAll\AdobeLinguisticsAll.msi
Updating media info for: {61D23D99-3398-414E-974E-EBAE498BB298}, Effective: {61D23D99-3398-414E-974E-EBAE498BB298}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeBridge2All\AdobeBridge2All.msi
Updating media info for: {65B2E542-E491-4762-90DB-C18B1200A093}, Effective: {65B2E542-E491-4762-90DB-C18B1200A093}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeXMPPanelsAll\AdobeXMPPanelsAll.msi
Updating media info for: {6EB45C70-7B6E-456C-8C23-58A8409C0E3D}, Effective: {6EB45C70-7B6E-456C-8C23-58A8409C0E3D}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeFlashPlayer9_axDbg_mul\AdobeFlashPlayer9_axDbg_mul.msi
Updating media info for: {7005ECBC-F54B-42FD-81E4-934BC43FA329}, Effective: {7005ECBC-F54B-42FD-81E4-934BC43FA329}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeDesignSuitePremiumen_US_Volume\AdobeDesignSuitePremiumen_US_Volume.msi
Updating media info for: {7B53463B-283F-44FF-94B2-CAB60DDE3159}, Effective: {7B53463B-283F-44FF-94B2-CAB60DDE3159}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeDeviceCentralAll\AdobeDeviceCentralAll.msi
Updating media info for: {7BB7F66A-D798-45A3-A383-0727FB1EBF8E}, Effective: {7BB7F66A-D798-45A3-A383-0727FB1EBF8E}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeFlashVideoEncoder2en_US\AdobeFlashVideoEncoder2en_US.msi
Updating media info for: {7E8C0B6B-A9DD-47C2-9589-43442F753117}, Effective: {7E8C0B6B-A9DD-47C2-9589-43442F753117}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeColorJA_ExtraSettingsAll\AdobeColorJA_ExtraSettingsAll.msi
Updating media info for: {8CFB2641-1439-4FA4-A72E-1658DC58B2F7}, Effective: {8CFB2641-1439-4FA4-A72E-1658DC58B2F7}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobePDFSettingsAll\AdobePDFSettingsAll.msi
Updating media info for: {8cec782a-3a7a-4f34-8452-78d05847efa2}, Effective: {8cec782a-3a7a-4f34-8452-78d05847efa2}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeAssetServices3All\AdobeAssetServices3All.msi
Updating media info for: {9C4C65E9-3568-4643-A6B0-6FC5D229D987}, Effective: {9C4C65E9-3568-4643-A6B0-6FC5D229D987}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeStockPhotos1.5All\AdobeStockPhotos1.5All.msi
Updating media info for: {A874B792-CECE-448A-A05E-B73E2B29299B}, Effective: {A874B792-CECE-448A-A05E-B73E2B29299B}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeCameraRaw4.0All\AdobeCameraRaw4.0All.msi
Updating media info for: {AC76BA86-1033-0000-7760-000000000003}, Effective: {AC76BA86-1033-0000-7760-000000000003}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeAcrobat8en_US\AcroPro.msi
Updating media info for: {AD61B275-AE44-4779-8E29-DF10832F5524}, Effective: {AD61B275-AE44-4779-8E29-DF10832F5524}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeSINGAll\AdobeSINGAll.msi
Updating media info for: {B2BF8160-B481-4F4A-B4F1-AD01DCC651DC}, Effective: {B2BF8160-B481-4F4A-B4F1-AD01DCC651DC}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeMotionPictureAll\AdobeMotionPictureAll.msi
Updating media info for: {B62B14F8-19D1-4B2E-9608-DC79E98C0FF3}, Effective: {B62B14F8-19D1-4B2E-9608-DC79E98C0FF3}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeHelpViewerAll\AdobeHelpViewerAll.msi
Updating media info for: {B99ACF49-9DDD-448F-B9BB-A8D49F6D3884}, Effective: {B99ACF49-9DDD-448F-B9BB-A8D49F6D3884}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeWinSoftLinguisticsPluginAll\AdobeWinSoftLinguisticsPluginAll.msi
Updating media info for: {BC4E20A8-BE55-4482-8A1B-606080887D46}, Effective: {BC4E20A8-BE55-4482-8A1B-606080887D46}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobePDFL8All\AdobePDFL8All.msi
Updating media info for: {BDFC4A4E-D8D3-44B2-B615-11D05A431FE7}, Effective: {BDFC4A4E-D8D3-44B2-B615-11D05A431FE7}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeColorNA_ExtraSettingsAll\AdobeColorNA_ExtraSettingsAll.msi
Updating media info for: {C4519961-AC64-4565-B3AF-9050296B5D5A}, Effective: {C4519961-AC64-4565-B3AF-9050296B5D5A}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeIllustrator13en_US\AdobeIllustrator13en_US.msi
Updating media info for: {C9BE6782-B94E-4EA6-9208-CF92811B28E7}, Effective: {C9BE6782-B94E-4EA6-9208-CF92811B28E7}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\BridgeStartMeeting\BridgeStartMeeting.msi
Updating media info for: {D12E7F7F-9D98-47B9-A16C-A6C5226FE642}, Effective: {D12E7F7F-9D98-47B9-A16C-A6C5226FE642}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AHVSTIAll\AHVSTIAll.msi
Updating media info for: {D2968B66-F6C1-45AE-A378-04D9FB541210}, Effective: {D2968B66-F6C1-45AE-A378-04D9FB541210}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeColorEU_ExtraSettingsAll\AdobeColorEU_ExtraSettingsAll.msi
Updating media info for: {D59D24C6-BFD5-4D92-8EE3-06055F6E2827}, Effective: {D59D24C6-BFD5-4D92-8EE3-06055F6E2827}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeColorPhotoshopAll\AdobeColorPhotoshopAll.msi
Updating media info for: {E1654C7B-8CBF-4301-8B8A-CFA1EB656F4D}, Effective: {E1654C7B-8CBF-4301-8B8A-CFA1EB656F4D}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeColorCommonSetAll\AdobeColorCommonSetAll.msi
Updating media info for: {ED77DAD4-1EE4-4259-ABC2-909C58FDA4C1}, Effective: {ED77DAD4-1EE4-4259-ABC2-909C58FDA4C1}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeWASAll\AdobeWASAll.msi
Updating media info for: {F33E4400-F4B8-46F9-8B3E-307CCC3B4860}, Effective: {F33E4400-F4B8-46F9-8B3E-307CCC3B4860}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeColorNA_RecommendedAll\AdobeColorNA_RecommendedAll.msi
Updating media info for: {FA70D08A-5D90-496D-AF9A-9DBCEE4FC005}, Effective: {FA70D08A-5D90-496D-AF9A-9DBCEE4FC005}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeAUM5.1All\AdobeAUM5.1All.msi
Updating media info for: {FB235376-7904-4164-88F4-13CA3944BBB9}, Effective: {FB235376-7904-4164-88F4-13CA3944BBB9}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeCMapsAll\AdobeCMapsAll.msi
Updating media info for: {abd781e6-d5ca-45aa-a5f7-f64799eb1c04}, Effective: {abd781e6-d5ca-45aa-a5f7-f64799eb1c04}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeVersionCue3All\AdobeVersionCue3All.msi
Updating media info for: {de08a23f-60bd-41d3-b703-c1a7bfbc2614}, Effective: {de08a23f-60bd-41d3-b703-c1a7bfbc2614}
Type: 1, Volume Order: 1, Media Name: Adobe CS3 Design Premium, Path: D:\Adobe CS3\payloads\AdobeVersionCueClient3All\AdobeVersionCueClient3All.msi
--------------------  END  - Updating Media Sources -  END  --------------------
[1924] Sun Jun 16 10:38:15 2013 DEBUG
Adding driver payload ARP data
Added: AddRemoveInfoDisplayName=Lägg till eller ta bort Adobe Creative Suite 3 Design Premium
Added: AddRemoveInfoDisplayVersion=1.0
Added: AddRemoveInfoSupportURL=http://www.adobe.com/go/intlsupport/
Install bootstrapper parameters:
Log of: object
defaultLanguage {string}: sv_SE
installSourcePath {string}: D:\Adobe CS3
platform {string}: Win32
sessionID {string}: 498b43b77cac072081a5692bfc52804
setupVersion {string}: 1.0.135.0
productName {string}: Adobe Creative Suite 3 Design Premium
driverAdobeCode {string}: {7005ECBC-F54B-42FD-81E4-934BC43FA329}
StartMenuSubFolder {string}: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Design Premium CS3
INSTALLDIR {string}: C:\Program Files\Common Files\Adobe\Installers\498b43b77cac072081a5692bfc52804
record {string}: 0
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload0 {string}: {00E5C764-9525-44C3-8404-712AD06AE12A}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload1 {string}: {06CEA754-616B-40CA-B807-B5F045628BC8}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload2 {string}: {078B624D-5FF6-40CF-8B92-312FD03FE4EB}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload3 {string}: {0A880438-9557-49ED-8E86-BD7B24612713}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload4 {string}: {193F8A7B-1853-48D5-88AC-19446C2C1D13}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload5 {string}: {1953AC8E-E91C-437F-83CC-82869A128FDE}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload6 {string}: {1C52C3C3-0BCB-4AE2-BA9D-9534C47EE221}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload7 {string}: {24D77A7C-E10B-4057-9974-FAB8BFDAC853}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload8 {string}: {2715DA38-F987-47F1-A768-F94D1B09074A}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload9 {string}: {28729DCD-3C60-45E3-9C25-4F5056802811}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload10 {string}: {2E4528EC-5ACB-4D19-98DD-6CC3594EB1A1}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload11 {string}: {30C4B843-28DA-466F-AFCA-CB0ED153C826}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload12 {string}: {3BC8460B-085E-47F3-9C62-8FFCBAF11D78}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload13 {string}: {450CDEDE-2E5F-4659-AC0D-BA693424ACAF}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload14 {string}: {56E0400B-3C4E-4600-A4D7-425EAE09E079}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload15 {string}: {5CE549BC-DD75-4D03-971A-4D598AC46CF2}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload16 {string}: {61D23D99-3398-414E-974E-EBAE498BB298}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload17 {string}: {65B2E542-E491-4762-90DB-C18B1200A093}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload18 {string}: {6EB45C70-7B6E-456C-8C23-58A8409C0E3D}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload19 {string}: {7005ECBC-F54B-42FD-81E4-934BC43FA329}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload20 {string}: {7B53463B-283F-44FF-94B2-CAB60DDE3159}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload21 {string}: {7BB7F66A-D798-45A3-A383-0727FB1EBF8E}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload22 {string}: {7E8C0B6B-A9DD-47C2-9589-43442F753117}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload23 {string}: {8CFB2641-1439-4FA4-A72E-1658DC58B2F7}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload24 {string}: {8cec782a-3a7a-4f34-8452-78d05847efa2}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload25 {string}: {9C4C65E9-3568-4643-A6B0-6FC5D229D987}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload26 {string}: {A874B792-CECE-448A-A05E-B73E2B29299B}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload27 {string}: {AC76BA86-1033-0000-7760-000000000003}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload28 {string}: {AD61B275-AE44-4779-8E29-DF10832F5524}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload29 {string}: {B2BF8160-B481-4F4A-B4F1-AD01DCC651DC}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload30 {string}: {B62B14F8-19D1-4B2E-9608-DC79E98C0FF3}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload31 {string}: {B99ACF49-9DDD-448F-B9BB-A8D49F6D3884}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload32 {string}: {BC4E20A8-BE55-4482-8A1B-606080887D46}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload33 {string}: {BDFC4A4E-D8D3-44B2-B615-11D05A431FE7}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload34 {string}: {C4519961-AC64-4565-B3AF-9050296B5D5A}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload35 {string}: {C9BE6782-B94E-4EA6-9208-CF92811B28E7}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload36 {string}: {D12E7F7F-9D98-47B9-A16C-A6C5226FE642}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload37 {string}: {D2968B66-F6C1-45AE-A378-04D9FB541210}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload38 {string}: {D59D24C6-BFD5-4D92-8EE3-06055F6E2827}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload39 {string}: {E1654C7B-8CBF-4301-8B8A-CFA1EB656F4D}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload40 {string}: {ED77DAD4-1EE4-4259-ABC2-909C58FDA4C1}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload41 {string}: {F33E4400-F4B8-46F9-8B3E-307CCC3B4860}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload42 {string}: {FA70D08A-5D90-496D-AF9A-9DBCEE4FC005}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload43 {string}: {FB235376-7904-4164-88F4-13CA3944BBB9}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload44 {string}: {abd781e6-d5ca-45aa-a5f7-f64799eb1c04}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.Payload45 {string}: {de08a23f-60bd-41d3-b703-c1a7bfbc2614}
CAPS_28B98837_8526_4159_B4E7_D0FD5E235960.TotalPayloads {number}: 46
AddRemoveInfoDisplayName {string}: Lägg till eller ta bort Adobe Creative Suite 3 Design Premium
AddRemoveInfoDisplayVersion {string}: 1.0
AddRemoveInfoSupportURL {string}: http://www.adobe.com/go/intlsupport/
[1924] Sun Jun 16 10:38:15 2013  INFO
Installing Bootstrapper
--record option not specified
* Logfile path changed to: C:\Program Files\Common Files\Adobe\Installers\Lägg till eller ta bort Adobe Creative Suite 3 Design Premium 1.0.log *
i see no errors.  are you sure it didn't install?  did you look for that installed files?
