I have problem with launching Photoshop CS6. -
Error massage:
You can’t open the application “Adobe Photoshop CS6” because it’s not supported on this type of Mac.
I have no problems with Dreamweaver CS6 and InDesign CS6.
(purchased products)
Please help if you have any idea!!!
This option is not applicable to you Anihorv as you are not able to install due to not meeting the minimum system requirements. I am sorry but there is no solution but to upgrade to a newer Macintosh.
Hi anihorv
The problem is due to your processor. You have an Intel Core Duo on your Macbook Pro. Photoshop requires at least an Intel Core 2 Duo processor with 64-bit support. You can find the system requirements listed at http://www.adobe.com/products/photoshop/tech-specs.html.
Please refer : http://forums.adobe.com/message/4824197
Thank you!
Do you have any idea what to do without buying a new mac?
You can try , Ctrl+click on the Photoshop icon
Go to "Get Info" , and then check the option , "Open in the 32 bit mode"
Unfortunatley I dont have such option.
Other idea or this just semewhere else???
Thank you for everyone!
these are the details of my mac:
Hardware Overview:
Model Name: MacBook Pro
Model Identifier: MacBookPro1,1
Processor Name: Intel Core Duo
Processor Speed: 1.83 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 2 MB
Memory: 2 GB
Bus Speed: 667 MHz
Boot ROM Version: MBP11.0055.B08
SMC Version (system): 1.2f10
Serial Number (system): W86130P9VJ2
Hardware UUID: 00000000-0000-1000-8000-0016CB8C85B5
Sudden Motion Sensor:
State: Enabled
The reason is your processor is 32-bit but these applications are 64 bit
check this link :-http://support.apple.com/kb/HT3696
It great you send my an idea, but unfortunately I do not have that possibility.
