I tried installing from Application manager, within PS6 and as seperate download but all fail.
Saw troubleshooting ideas from
The first step is to go here - http://helpx.adobe.com/creative-suite/kb/error-u44m1p7-installing-updates-ccm.html
If the manual install fails or is not available, then it'll show you how to get into the log files. Copy any errors and that will help us figure out what's wrong.
Here is another document that you can look into:
http://helpx.adobe.com/creative-suite/kb/unable-apply-extension-manager-update.html
I should also mention I am running Windows 7 x64
06/17/13 09:21:23:665 | [INFO] | | OOBE | DE | | | | 1268 | Installer Operation: PayloadInstaller
06/17/13 09:21:23:666 | [INFO] | | OOBE | DE | | | | 1268 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
06/17/13 09:21:23:666 | [INFO] | | OOBE | DE | | | | 1268 | Request to install payload
06/17/13 09:21:23:674 | [INFO] | | OOBE | DE | | | | 1268 | Payload Adobe Photoshop CS6 Core_x64_13.1.2_AdobePhotoshop13-Core_x64 13.1.2.0 {59482051-CFF2-47AE-B944-A7352D74A8B5}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
06/17/13 09:21:26:374 | [INFO] | | OOBE | DE | | | | 1268 | Extracting assets complete. Number assets: 1
06/17/13 09:21:26:375 | [INFO] | | OOBE | DE | | | | 1268 | CustomizedPatch property not found in database
06/17/13 09:21:26:375 | [INFO] | | OOBE | DE | | | | 1268 | Beginning installation for payload at C:\Users\Dopey\AppData\Local\Temp\Adobe\AAMUpdater\AdobePhotoshopCS6Support-13.0\13.1.2\Setup\payloads\AdobePhotoshop13-Core_x64-080113170649\Install.db
06/17/13 09:21:26:402 | [ERROR] | | OOBE | DE | | | | 1268 | DF045: File corruption detected. Re-install the product & then apply the patch again. (Can not repair file "C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plugin.dll")(Seq 14)
06/17/13 09:21:26:402 | [WARN] | | OOBE | DE | | | | 1268 | DW063: Command ARKPatchCommand failed.(Seq 14)
06/17/13 09:21:26:402 | [INFO] | | OOBE | DE | | | | 1268 | Completing installation for payload at C:\Users\Dopey\AppData\Local\Temp\Adobe\AAMUpdater\AdobePhotoshopCS6Support-13.0\13.1.2\Setup\payloads\AdobePhotoshop13-Core_x64-080113170649\Install.db
06/17/13 09:21:26:465 | [INFO] | | OOBE | DE | | | | 1896 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
06/17/13 09:21:26:465 | [INFO] | | OOBE | DE | | | | 1896 | :: END TIMER :: [Payload Operation :{59482051-CFF2-47AE-B944-A7352D74A8B5}] took 2802.87 milliseconds (2.80287 seconds)
06/17/13 09:21:26:466 | [INFO] | | OOBE | DE | | | | 1896 | User specified overrideFile:
06/17/13 09:21:26:469 | [INFO] | | OOBE | DE | | | | 1896 | The csu inventory was not updated for payload Adobe Photoshop CS6 Core_x64_13.1.2_AdobePhotoshop13-Core_x64 13.1.2.0 {59482051-CFF2-47AE-B944-A7352D74A8B5}, value of local var is -1
06/17/13 09:21:26:469 | [INFO] | | OOBE | DE | | | | 1896 | Calling the ROLLBACK custom action code for pre-install for payload Adobe Photoshop CS6 Core_x64_13.1.2_AdobePhotoshop13-Core_x64 13.1.2.0 {59482051-CFF2-47AE-B944-A7352D74A8B5}
06/17/13 09:21:26:476 | [INFO] | | OOBE | DE | | | | 1896 | Calling the custom action code for pre-install for payload Adobe Photoshop CS6 Support_13.1.2_AdobePhotoshop13-Support 13.1.2.0 {B65FABC3-FCF2-4BE6-B12A-600CA2EBFB9D}
06/17/13 09:21:26:476 | [INFO] | | OOBE | DE | | | | 1896 | ::START TIMER:: [Payload Operation :{B65FABC3-FCF2-4BE6-B12A-600CA2EBFB9D}]
06/17/13 09:21:26:480 | [INFO] | | OOBE | DE | | | | 328 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
06/17/13 09:21:26:480 | [INFO] | | OOBE | DE | | | | 328 | Installer Operation: PayloadInstaller
06/17/13 09:21:26:480 | [INFO] | | OOBE | DE | | | | 328 | Request to install payload
06/17/13 09:21:26:489 | [INFO] | | OOBE | DE | | | | 328 | Payload Adobe Photoshop CS6 Support_13.1.2_AdobePhotoshop13-Support 13.1.2.0 {B65FABC3-FCF2-4BE6-B12A-600CA2EBFB9D}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
06/17/13 09:21:26:546 | [INFO] | | OOBE | DE | | | | 328 | Extracting assets complete. Number assets: 2
06/17/13 09:21:26:546 | [INFO] | | OOBE | DE | | | | 328 | CustomizedPatch property not found in database
06/17/13 09:21:26:546 | [INFO] | | OOBE | DE | | | | 328 | Beginning installation for payload at C:\Users\Dopey\AppData\Local\Temp\Adobe\AAMUpdater\AdobePhotoshopCS6Support-13.0\13.1.2\Setup\payloads\AdobePhotoshop13-Support-080113171918\Install.db
06/17/13 09:21:26:965 | [ERROR] | | OOBE | DE | | | | 328 | DF045: File corruption detected. Re-install the product & then apply the patch again. (Can not repair file "C:\Program Files (x86)\Common Files\Adobe\Adobe Photoshop CS6\patcher_trigger\patchTrigger")(Seq 5)
06/17/13 09:21:26:965 | [WARN] | | OOBE | DE | | | | 328 | DW063: Command ARKPatchCommand failed.(Seq 5)
06/17/13 09:21:26:965 | [INFO] | | OOBE | DE | | | | 328 | Completing installation for payload at C:\Users\Dopey\AppData\Local\Temp\Adobe\AAMUpdater\AdobePhotoshopCS6Support-13.0\13.1.2\Setup\payloads\AdobePhotoshop13-Support-080113171918\Install.db
06/17/13 09:21:27:180 | [INFO] | | OOBE | DE | | | | 1896 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
06/17/13 09:21:27:180 | [INFO] | | OOBE | DE | | | | 1896 | :: END TIMER :: [Payload Operation :{B65FABC3-FCF2-4BE6-B12A-600CA2EBFB9D}] took 703.478 milliseconds (0.703478 seconds)
06/17/13 09:21:27:182 | [INFO] | | OOBE | DE | | | | 1896 | User specified overrideFile:
06/17/13 09:21:27:184 | [INFO] | | OOBE | DE | | | | 1896 | The csu inventory was not updated for payload Adobe Photoshop CS6 Support_13.1.2_AdobePhotoshop13-Support 13.1.2.0 {B65FABC3-FCF2-4BE6-B12A-600CA2EBFB9D}, value of local var is -1
06/17/13 09:21:27:185 | [INFO] | | OOBE | DE | | | | 1896 | Calling the ROLLBACK custom action code for pre-install for payload Adobe Photoshop CS6 Support_13.1.2_AdobePhotoshop13-Support 13.1.2.0 {B65FABC3-FCF2-4BE6-B12A-600CA2EBFB9D}
06/17/13 09:21:27:187 | [INFO] | | OOBE | DE | | | | 1896 | No operation. We're done:
06/17/13 09:21:29:189 | [INFO] | | OOBE | DE | | | | 1896 | Total components installed: 0
06/17/13 09:21:29:189 | [INFO] | | OOBE | DE | | | | 1896 | Total components repaired: 0
06/17/13 09:21:29:189 | [INFO] | | OOBE | DE | | | | 1896 | Total components removed: 0
06/17/13 09:21:29:189 | [WARN] | | OOBE | DE | | | | 1896 | DW050: The following payload errors were found during install:
06/17/13 09:21:29:189 | [WARN] | | OOBE | DE | | | | 1896 | DW050: - Adobe Photoshop CS6 Core_13.1.2_AdobePhotoshop13-Core: Install failed
06/17/13 09:21:29:189 | [WARN] | | OOBE | DE | | | | 1896 | DW050: - Adobe Photoshop CS6 Core_x64_13.1.2_AdobePhotoshop13-Core_x64: Install failed
06/17/13 09:21:29:189 | [WARN] | | OOBE | DE | | | | 1896 | DW050: - Adobe Photoshop CS6 Support_13.1.2_AdobePhotoshop13-Support: Install failed
06/17/13 09:21:29:189 | [INFO] | | OOBE | DE | | | | 1896 | Call PostSession Custom Hook
06/17/13 09:21:29:189 | [INFO] | | OOBE | DE | | | | 1896 | :: END TIMER :: [Total Timer] took 15952.4 milliseconds (15.9524 seconds) DTR = 40.1194 KBPS (0.0391791 MBPS)
06/17/13 09:21:30:189 | [INFO] | | OOBE | DE | | | | 1896 | -------------------------------------- Summary --------------------------------------
06/17/13 09:21:30:189 | [INFO] | | OOBE | DE | | | | 1896 | - 0 fatal error(s), 3 error(s)
06/17/13 09:21:30:189 | [INFO] | | OOBE | DE | | | | 1896 | Win OS version: 6.1.1.0 64 bit Type: 1
06/17/13 09:21:30:189 | [INFO] | | OOBE | DE | | | | 1896 | ----------- Payload: Adobe Photoshop CS6 Core_13.1.2_AdobePhotoshop13-Core 13.1.2.0 {4E02C584-5A78-4D4F-AB74-67C5665F8A00} -----------
06/17/13 09:21:30:189 | [INFO] | | OOBE | DE | | | | 1896 | ERROR: DF045: File corruption detected. Re-install the product & then apply the patch again. (Can not repair file "C:\Program Files (x86)\Adobe\Adobe Photoshop CS6\boost_threads.dll")(Seq 15)
06/17/13 09:21:30:189 | [INFO] | | OOBE | DE | | | | 1896 | ----------- Payload: Adobe Photoshop CS6 Core_x64_13.1.2_AdobePhotoshop13-Core_x64 13.1.2.0 {59482051-CFF2-47AE-B944-A7352D74A8B5} -----------
06/17/13 09:21:30:189 | [INFO] | | OOBE | DE | | | | 1896 | ERROR: DF045: File corruption detected. Re-install the product & then apply the patch again. (Can not repair file "C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plugin.dll")(Seq 14)
06/17/13 09:21:30:189 | [INFO] | | OOBE | DE | | | | 1896 | ----------- Payload: Adobe Photoshop CS6 Support_13.1.2_AdobePhotoshop13-Support 13.1.2.0 {B65FABC3-FCF2-4BE6-B12A-600CA2EBFB9D} -----------
06/17/13 09:21:30:189 | [INFO] | | OOBE | DE | | | | 1896 | ERROR: DF045: File corruption detected. Re-install the product & then apply the patch again. (Can not repair file "C:\Program Files (x86)\Common Files\Adobe\Adobe Photoshop CS6\patcher_trigger\patchTrigger")(Seq 5)
06/17/13 09:21:30:189 | [INFO] | | OOBE | DE | | | | 1896 | Please search the above error string(s) to find when the error occurred.
06/17/13 09:21:30:189 | [INFO] | | OOBE | DE | | | | 1896 | These errors resulted in installer Exit Code mentioned below.
06/17/13 09:21:30:189 | [INFO] | | OOBE | DE | | | | 1896 | -------------------------------------------------------------------------------------
06/17/13 09:21:30:189 | [INFO] | | OOBE | DE | | | | 1896 | Exit Code: 7 - Unable to complete Silent workflow.
06/17/13 09:21:30:189 | [INFO] | | OOBE | DE | | | | 1896 | Please see specific errors for troubleshooting. For example, ERROR: DF045 ...
06/17/13 09:21:30:189 | [INFO] | | OOBE | DE | | | | 1896 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
06/17/13 09:21:30:189 | [INFO] | | OOBE | DE | | | | 1896 | END - Installer Session
you're trying to install the 13.1.2 update?
if so, uninstall ps, reinstall using adobe application manager but, close the manager after downloading and installing.
open ps and click help>updates and select 13.1.2. do not update to 13.0.1.2 first.
13.1.2 update? yes
I've looked for a PS uninstaller but not found. I've got Revo Uninstaller but I get messages indicating unisnstall might affect other Adove apps (shared files?)
What is best way to uninstall?
click your start button>in the search field, type uninstall>under control panel, click uninstall a program>find adobe photoshop cs6 and click it.
The normal Windows uninstall totally slipped my mind. doh. I've used Revo for so long I sometimes forget the basics. Uninstall went fine but PS still wouldn't update. I ran some disk utilities which found all kinds of errors and fixed. Still couldn't update until I ran the Adobe cleaner utility then reinstalled and updated with no problems. I'm backing up everything in preparation for doing a complete Windows reinstall just to be safe. It was getting about time anyway.
Thanks for all the help!
Steve aka Grumpyelvis
you're welcome.
See my Windows 7 resolution in http://forums.adobe.com/message/5508172#5508172
