Getting text from footnotes
Jun 19, 2013 Jun 19, 2013
Dear all,
Having managed to extract citations from ordinary paragraphs and table cells I now want to get it also from footnotes. See the complete script and test-doc (FN-11) doc here.
I get the first footnote paragraph with its citation correctly.
But my construct to get the next paragraph of the footnote obviously is wrong - there is no NextPgfInFn (or NextPgf) mentioned in the Scripting Guide, only FirstPgf and LastPgf. But it is possible to have multiple paragraphs in footnotes (see test-doc). And hence the function GetText fails for the 'second paragraph' in the footnote.
function processFootnote (fn, doc) {
// find citations in footnotes
    var fnText = "";
    var fnPara = fn.FirstPgf;
    while (fn.ObjectValid()) {
      fnText = (GetText(fnPara));
        alert (fnText);                    // the text of the cell
        var citations = GetTempCitations (fnText);
        var nCitations = citations.length;
        alert (nCitations + " Citations = " + citations);
    fnPara = fnPara.NextPgfInFn;                                               // <-------------- this is not valid
function GetText (textObj, doc) {
  // Gets the text from the text object.
  var text = "";
  // Get a list of the strings in the text object or text range.
  if (textObj.constructor.name !== "TextRange") {                        // <--------------- Undefined is not an object
    var textItems = textObj.GetText(Constants.FTI_String);
  } else {
    var textItems = doc.GetTextForRange(textObj, Constants.FTI_String);
  // Concatenate the strings.
  for (var i = 0; i < textItems.len; i += 1) {
    text += (textItems.sdata);
  return text; // Return the text
What would be a valid construct to get into all paragraphs of the footnote?
And there the next question lures: does function processFootnote also handle table footnotes ?
Thanks for Your help.
Klaus Daube
Scripting
914
Community Expert , Jun 19, 2013 Jun 19, 2013
Hi Klaus,
Use NextPgfInFlow
Rick
Hi Klaus,
Use NextPgfInFlow
Rick
Jun 20, 2013 Jun 20, 2013
Thank You, Ric, that worked.
However, i had to add a 'stop', because an endless number of empty footnotes were found.
     var fnText = "";
       if (fnText == ""){ return; }       // <----------------- prevent runaway
          alert (fnText);                    // the text of the footnote
    fnPara = fnPara.NextPgfInFlow;
Hi Klaus, The code in your function is not quite right. The way I understand it, you are using the processFootnote function to process a single footnote. If that is the case, then this line:
is not correct. The fn object will always be valid and that is why you have a runaway loop. You need this instead:
while (fnPara.ObjectValid()) {
This code will be unnecessary:
Rick
Jul 02, 2013 Jul 02, 2013
Thanks Rick - this solved the problem.
Now I'm able to collect the citations in
- ordinary paragraphs,
- table cells
- foot notes
- table foot notes.
For the purpose of my project I postpone looking into textframes in anchored frames and other constructs (something must be left for later enhancements...)
