1
Photoshop CC Live Shapes Properties Bug (also in 2022)
Jun 18, 2013 Jun 18, 2013
Checking out the corner radii controls on vector shapes and it looked to be working, until I created a couple of other shapes. The Properties box inconsistently changes for the same kind of shapes.
Link to vid to show my problem: http://cl.ly/PheD
Looks like I can't go back to edit the shape for some reason. What would cause this? It's like the shape has suddenly stopped being a Live Shape.
Cheers!
68.4K
Community Expert , Jun 18, 2013 Jun 18, 2013
What happens if you use the Path Selection Tool to select the shapes instead of the Move Tool?
Adobe
Adobe Employee ,
Hi Jack,
I moved your discussion from the Creative Cloud forum to the Photoshop forum, where you may get more relevent help more quickly.
Could you please post a screenshot of your layers panel?
Michael
Jun 19, 2013 Jun 19, 2013
Guest
Jun 20, 2013 Jun 20, 2013
I have also found this when copying a live shape using the layers panel. When I select the copy the live shape properties are not available. Seems that using the direct selection tool usually switches it back.
Selecting the shape with the Path Selection Tool seems to reset it and turn it back in to a Live Shape — but it doesn't stay that way. Really strange.
Jun 22, 2013 Jun 22, 2013
This bug goes a lot further than what you have stated, if you select the live shape from the tool menu on the left it removes the properties and the width becomes the width of the space.
Very strange issue's happening.
These silly bugs needs sorting out ASAP.
Jun 23, 2013 Jun 23, 2013
Hi Guys,
I have same problem with my CC. Live shape properties just missing when I select shape object.
Cheers,
Michal
Guest
Jun 24, 2013 Jun 24, 2013
Yes I only managed to get the live shape properties to work when reselecting an object once. Pity as this was the feature that made me want to upgrade.
Jun 25, 2013 Jun 25, 2013
I've got the same problem. When alt-copying a live shape all seems fine, but when I copy the shape via the layer panel the live shape properties disappear!
Stop the insanity.
https://sphotos-a.xx.fbcdn.net/hphotos-frc3/996863_10151754854240719_844700773_n.jpg
It appears that PS is losing the shape's designation as a rectangle with round corners – if I create a triangle immediately after making a rect with round corners, it loses its original options.
Jun 27, 2013 Jun 27, 2013
I get exaclty the same issue - although right from the start I never see the correct Properties panel for Live Shapes. I also see the MASK panel as shown in the post above
Sep 11, 2013 Sep 11, 2013
Keith has hit the nail on the head. What's the point of live shape properties if you can't access them once the document has been closed. Unless I am missing something I have this same issue, and it's infuriating. Does anyone have a fix for this, or an eta on a fix.....
I updated to the latest CC the other day. I have noticed the past few days I have not had the problem any more. It all works fin for me.
I believe you have to use the select tool (A) , but make sure you have selected "Path Select" ( the black pointer with the white outline) and not "Direct Select" of the 2 options
Then when you select  the shape, in the properties panel select the "live shapes properties" button to the left of the "mask" button at the top. I have noticed it always goes back to the mask tab, so have to always click the properties tab.
Awesome! Thank you SO much, I really appreciate you taking the time to respond. The live shape properties where driving me batty.
Dec 02, 2015 Dec 02, 2015
So I finally managed to fix my problem - I was drawing shapes and they showed NO properties.
Edit>prefs>general> reset prefs on quit
all behaving properly now
Hope this helps
Dec 23, 2015 Dec 23, 2015
Many thanks
Mar 07, 2016 Mar 07, 2016
sadly, this did not fix it for me
Dec 07, 2016 Dec 07, 2016
The same here, I can see the color, stroke and even size, but forget about the Border Radius, I've seen every video, and I can't find where to edit the shape.
Simply use the hollow point tool, select a point on the live shape, and see the "live shape properties" reappear...
I am also experiencing the same issue.
Jun 28, 2013 Jun 28, 2013
Same problem here. It's indiscriminate. Sometimes it only shows Masks rather than Live Shape Properties. Very annoying.
Jul 01, 2013 Jul 01, 2013
Wondering why there has been no response about this issue. Still seeing it occuring today.
My issue was somewhat skewed by the fact that Adobe seems to have 'stealthed' Adobe CC in as opposed to the cloud based CS6 we are signed up for. That feature works fine in CC but not in CS6, so we had to download and install that version now.
