Not able to load the Elements 11 from my purchased disk. Get the Shared Technologies problem?
I have used the ASA. It says that there are no problems
continue troubleshooting using the info on that page. ie, next step is to check your install logs (http://helpx.adobe.com/photoshop-elements/kb/troubleshoot-install-using-logs-elements.html#main_main...)
Can´t find anything?
did you restart your computer?
if yes and you still could not install/use pse 11, copy and paste the entire log.
Before I copy the entire log, I suppose this is the right log? But looking at the date logdate is old? installation tried yesterdag jul 2 2013.
Can I remove this log reinstall and have a new log with todays date?
I did restart the computer
delete that old directory, to make sure we're checking a current log, and then start you reinstallation.
