I'm using AMS 5.0.1 on AWS. I would like to create my own customized AMI - I would like to configure the 'stock' AMI to my liking and then create a new AMI from that customized server.
I've tried some methods that I found to try to create a new AMI but I'm running into problems. It seems that I can't create a new paid AMI from and existing one.
This is the error:
Machine image ami-XXXXXXXX and kernel image aki-XXXXXXXX have incompatible product codes.
I tried to inject the product code using;
ec2-modify-image-attribute ami-XXXXXXXX --product-code XXXXXXXX
but got this error:
Client.AuthFailure: Not authorized for image:ami-XXXXXXX
This is a critical issue for me, I need to be able to automatically create AMS instances within AWS. If anyone can point me in the right direction I would really appreciate it.
Another option would be to persuade Adobe to create some slightly modified AMI's for public use?
I think the main issue here is the billing one. In order for Adobe to properly bill for AMS usage on Amazon Web Services, it needs to control which machine images have AMS. Unfortunately for you, I doubt Adobe will tweak their images specifically for your purposes.
Thanks for the comment. It turns out that you can't just apply product codes unless you are a registered developer, among other things. And I think you are right that Adobe probably won't do anything special for me. This approach is definitely not possible at this time.
