My adobe Framemaker9 can't work
Guest
Jun 27, 2013 Jun 27, 2013
Afterinstalled the Framemaker, everytime i started it, there will be a dialogue appers, as shows in the attachment. If click [confirm], the Framemaker will be closed automatically.
error.pngAnd my operating system is Windows 7.
1.6K
Jun 28, 2013 Jun 28, 2013
Ask in the FM forum.
Mylenium
Guest
OK, thanks
[Moved the discussion here for better help]
What language do you have set for Windows? Are you running 64-bit Windows 7 or 32-bit Windows 7. I have had no issue running FrameMaker 9 under 32-bit Windows 7.
Guest
Jun 30, 2013 Jun 30, 2013
Mine is 32-bit Window 7, is it the Operating system ?
Jul 01, 2013 Jul 01, 2013
You probably have a corrupted Linguistics folder - try renaming it & see if FM will recreate it.
Guest
i have tried, anyone met this problem ?
Jul 02, 2013 Jul 02, 2013
Did renaming the Linguistics folder do anything? Or is it still failing to start? You might also check both maker.ini files to see what & where the LanguageDir entry is pointed.
Guest
yes, in the maker.ini, it is
LanguageDir=dict
I have renames this file and copied from other place, and it doesn't work.
Jul 03, 2013 Jul 03, 2013
You should have a site.dct file in the \dict\ folder – my maker.ini has:
UserDictionary=
SiteDictionary=dict\site.dct
in the section.
I suspect that something is messed up in your installation. Did you have local admin rights to your machine when you installed FM?
Guest
i have the same site.dct file as yours.
before i installed the FM, i  activated the Admin account, so it's not the problem.
But i have installed the other version of FM before, and this may be the problem.
i think i have to reinstall the operating system, maybe can fix it.
Jul 04, 2013 Jul 04, 2013
You can have multiple versions of FM on one machine; only Acrobat fails to play nice with multiple versions on the same machine. You may just need a new profile set up as a local admin. Also give yourself rights to your local c:\ drive manually (since Vista, Windows doesn’t give you full rights automatically just because you’re a local admin – you have to do it manually). Or you can try a tool like Revouninstaller that does a great (free) job of scrubbing out applications before reinstalling.
Guest
i have uninstalled all the versions of FM by Revouninstaller, but it still have the same issues, i have no idea now.
and i  installed as a local administrator privileges.
Jul 05, 2013 Jul 05, 2013
What language is your copy of Win7 set to? Is it different than what language is being installed for FM?
You may have reached a point where you need to contact Adobe Support or the TCS tech team to figure out what's going on with your install.
Guest
ok,thanks very much.
i will contact them and  try to solve it.
