My PDFs are doing an odd thing with bookmarks. They list as bookmarks every entry (paragraph) on the TOC and APL. But not consistently. Any ideas?
And is this an Acrobat issue or a Framemaker issue? Individual book chapters are okay as PDFs. It only happens when I make a PDF of the entire book. I've looked at the paratags and the bookmark setup, and can't see anything out of the ordinary.
It appears that it might be possible to have PDF settings, including bookmarks, at both the book and component file level. If so, and if these can be different, who knows what consequences might be. I know this is possible for Numbering..., and nuisance dialogs are the usual result in that case.
So you might try File > Print on just the TOC file, and see what [ PDF Setup ] > [Bookmarks ] has to say.
Is it missing particular headings, or every 4th heading, or is it seemingly random?
Very random. And thanks for asking.
Yvonne Sadler
Technical Writer
641-621-7708
ysadler@vermeer.com<mailto:ysadler@vermeermfg.com
Have you looked at Format > Document > PDF Setup while the book file is active?
Setting the bookmarks there, updating your book, and saving all files in book should clear up the issue.
Yes, we did try that.
Yvonne Sadler
Technical Writer
641-621-7708
And you're using File > Save as PDF to create your file?
And you have your Print Setup set to use the Adobe PDF print driver?
No, we were printing to a ps file. Yes, definitely have chosen the PDF print driver.
Yvonne Sadler
Technical Writer
641-621-7708
lmk if you get the same result using the Save as PDF.
Oh, I will!
But I am excited now because my colleague didn’t have a chance to check her file, so I did. And the TOC booksmarks WERE wonky. So I’m trying the book pdf now, and if that doesn’t work, I’ll try the Save As PDF option too.
Yvonne Sadler
Technical Writer
641-621-7708
You
Are
Brilliant.
Taking the bookmarks out of the TOC and APL files has fixed this.
I don’t know how they got in there in the first place. We don’t remember putting them in there.
But it is FIXED and we are very happy.
Yvonne Sadler
Technical Writer
641-621-7708
Hooray! Make sure to mark the reply as "Correct" to help others find it.
-Matt
Matt R. Sullivan
co-author Publishing Fundamentals: Unstructured FrameMaker 11
Oh yeah, thanks for that!
Yvonne Sadler
Technical Writer
641-621-7708
(how do I do that?)
Yvonne Sadler
Technical Writer
641-621-7708
For discussions you've created, you should see the
Mark as: Correct Helpful
links at the bottom of the correct reply. See the bottom of my supplied screen capture for an example.
That sounds like a worthwhile thing to try. Thanks!
Yvonne Sadler
Technical Writer
641-621-7708
