APSB13-19 Installation problem
Guest
Jul 15, 2013 Jul 15, 2013
APSB13-19 does not play nice with another JRUN hotfix we deployed: http://helpx.adobe.com/legacy/kb/error-response-been-closed-illegalstateexception.html
CF is throwing out this error if both hotfixes were found in /server/lib directory:
500
jrun.servlet.JRunResponse.setRequest(Ljrun/servlet/ForwardRequest;)V
java.lang.NoSuchMethodError: jrun.servlet.JRunResponse.setRequest(Ljrun/servlet/ForwardRequest;)V
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:242)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)
at jrun.servlet.http.WebService.invokeRunnable(WebService.java:172)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
Any help would be appreciated.
thanks
David Kwang
865
Adobe Employee ,
Hi David,
Could you please let me know the version of your ColdFusion. I have tried it with the same behaviour let us check this however please do let me know the version of your server.
Priyank
Priyank Shrivastava
Guest
Windows 2008 R2 Standard
CF Version  9,0,2,282541
Do you need any other information?
David
Adobe Employee ,
Jul 16, 2013 Jul 16, 2013
Hi David,
Thanks for the information.
I guess if you remove this jrun4_58765.jar from the lib directory, it should work as this version of ColdFusion contains this fix.
So can you please remove this jar and try putting the security hotfix only and check if you encounter the same issue(http://helpx.adobe.com/legacy/kb/error-response-been-closed-illegalsta teexception.html).
Priyank
Priyank Shrivastava
Guest
APSB13-19 installs correctly after removing  jrun4_58765.jar. But we do need the fix contained in jrun4_58765.jar.
Adobe Employee ,
Hi David,
Can you run the test and let me know if you encounter this issue as you've removed the jar file and please let me know.
Priyank
Priyank Shrivastava
Documentation
