APSB13-19 does not play nice with another JRUN hotfix we deployed: http://helpx.adobe.com/legacy/kb/error-response-been-closed-illegalstateexception.html
CF is throwing out this error if both hotfixes were found in /server/lib directory:
500
jrun.servlet.JRunResponse.setRequest(Ljrun/servlet/ForwardRequest;)V
java.lang.NoSuchMethodError: jrun.servlet.JRunResponse.setRequest(Ljrun/servlet/ForwardRequest;)V
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:242)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)
at jrun.servlet.http.WebService.invokeRunnable(WebService.java:172)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
Any help would be appreciated.
thanks
David Kwang
Hi David,
Could you please let me know the version of your ColdFusion. I have tried it with the same behaviour let us check this however please do let me know the version of your server.
Priyank
Windows 2008 R2 Standard
CF Version 9,0,2,282541
Do you need any other information?
David
Hi David,
Thanks for the information.
I guess if you remove this jrun4_58765.jar from the lib directory, it should work as this version of ColdFusion contains this fix.
So can you please remove this jar and try putting the security hotfix only and check if you encounter the same issue(http://helpx.adobe.com/legacy/kb/error-response-been-closed-illegalsta teexception.html).
Priyank
APSB13-19 installs correctly after removing jrun4_58765.jar. But we do need the fix contained in jrun4_58765.jar.
Hi David,
Can you run the test and let me know if you encounter this issue as you've removed the jar file and please let me know.
Priyank
