Android does not support flash from OS 4 and above. Is there any solution/plugin available so that user can see the flash video streaming (Streaming is sent by Adobe Media server) in andoid devices?
Adobe Media Server supports streaming to Android & iOS devices out of the box in terms of viewing either live or VOD content. In your Android device follow this link for a VOD sample http://osmf.org/configurator/fmp/.
Thanks for the reply. But flash is not supported in latest android device (OS 4 and above), so without flash is it possible to show video streaming?
only way to see flash is by using a flash browser, I have that issue also so I have to use a flash based browser, say for example...Puffin Browser, dolphin browser, etc.
If that’s a latest version regardless of platform, go for HTML5 player. e.g. http://hls.pbochan.com/
to sovle this problem, you can make an AIR application for android from flash professtional and use the FLVPlayback component and set its source property to the address of the video you want to stream.
also you can use pure actionscript in doing so.
Nasser.
