I'm going to be producing an epub edition of one of my company's documents. A test document (ToC & two chapters of lipsem) was converted via FrameMaker fairly successfully. It even created a Table of Contents, but placed it at the end of the ebook.
Does anyone know how to get FM to put the ToC at the beginning of the epub? Or did I inadvertently get it to create an index instead?
Justin
Did you set the Properties of your book file to use the FM TOC, and then set the EPUB SSL to use that same TOC?
I also see the TOC in the back, but have one recognized by Adobe Digital Editions and my iBooks reader on iPad.
-Matt
Matt R. Sullivan
co-author Publishing Fundamentals: Unstructured FrameMaker 11
Thanks for the suggestion, Matt. Where do I set those properties?
Justin
To process the FM TOC, right-click on the book file in Rh, and look at the Properties. Once updated, the TOC will be available in the ePub single source layout settings.
-Matt
