Locked
1
Jquery menus for DW CC
Participant ,
Jun 24, 2013 Jun 24, 2013
So Spry is gone in DW CC. Spry of course made deploying menus very quick and easy. Does anyone have any suggestions for an equivalent tool for menus using Jquery?
25.6K
Adobe Employee ,
Jun 25, 2013 Jun 25, 2013
Hi madwebllc,
There is one free Widget available on Adobe Exchange "Advanced CSS Menu Light" using jQuery. You can give it  a try.
You can access it through DW CC.
1. Window menu < Extensions < Adobe Exchange.
2.  Click on Fee tab in the Exchange Panel.
3. Click "Advanced CSS Menu Light" and follow on screen instructions to install it.
The ZXP installer is downloaded to the user's documents folder.
Bhawna
Participant ,
Jun 26, 2013 Jun 26, 2013
I managed to get the tool you suggested installed, after a number of errors referencing the path was not recognized, and the publisher could not be verified. But when I attempt to use the extension, it was unresponsive when I went to Insert > Ajatix > Advanced CSS Drop Down Menu Light.
Perhaps it is not compatible with CC?
Any ideas of what may be going on? Or perhaps another extension?
And a question that hopefully Adobe staff can answer. DW CC has many great widgets under Jqueryui, why was a menu option left off?
Yes, I had exactly the same problem installing and then the Ajatix menu option appears active in Dreamweaver but it is nonresponsive. I am using Dreamweaver CC version 13.0 Build 6390 and use Window 7. I am hoping for a soluton.
Participant ,
Jun 28, 2013 Jun 28, 2013
I hate to be that guy posting updates to my thread asking why I have't heard anything. I just can't help but be very curious, why of all options under jqueryui to not be added, why is the menu widget left off?
Please.. anyone from Adobe staff. I can't be the only one wondering this.
Adobe Employee ,
Hi all,
Thank you for  your feedback. Will ask around and get back with an answer. With the weekend, the wait might be a little longer.
Preran
Participant ,
Sounds good and thank you, I look forward to hearing from the staff later on
Jul 17, 2013 Jul 17, 2013
I haven't seen the staff get back on this and the final post here has an automatic download. Is there an extention from adobe extention manager that gives the jquery drop down menu? Why this has been eliminated, I don't know.
Preran???
May 29, 2015 May 29, 2015
Hi! On the first lines of this post, I reab about the the Advanced CSS Menu Light extension. I tried to install it but it dont works!… No need to leave this extension installed. Can u tell me how can i desinstall it now? Thanks for ur help!
Deactivate it with your Extension Manager.
Nancy O.
Nancy O'Shea— Product User, Community Expert & Moderator
Alt-Web Design & Publishing ~ Web : Print : Graphics : Media
I had never heard before.about this option! Thks!
Jul 02, 2013 Jul 02, 2013
I have been working with Alex at Ajatix. He was great and worked with me until the problem was solved. Here is the link.
  1. www.ajatix.com/downloads/com.ajatix.AdvancedCSSMenuLight_2.1.5.zxp
    1. Download
    2. Close Dreamweaver, if open
    3. Open Adobe Extension Manager CC
    4. Select File, Install Extension
    5. Browse for the downloaded .ZXP
    6. Follow prompts
    7. Launch Dreamweaver
Scott S-)
May 07, 2015 May 07, 2015
This link worked great for me! Thanks for posting
Contributor ,
Jul 24, 2013 Jul 24, 2013
"There is one free Widget available on Adobe Exchange "Advanced CSS Menu Light" using jQuery."
Advanced CSS Drop Down Menu Light is a CSS menu. It does not use jQuery, Spry or any other JavaScript framework. It does not use JavaScript at all. In fact this makes it compatible with any framework there is. It can be used alongside any version of jQuery, ExtJS, MooTools, etc. You can even disable JavaScript in your browser and the menu will work.
Modern menus are not about JavaScript, they are about CSS. Some of them may use small portions of JavaScript for added functionality (progressive enhancement), but JavaScript is no longer a key technology in that area
P.S. They are also about semantics.
Thanks!!! I love it, and am finding it very easy to customize - I have to add drop menus to an old site (http://www.artandsoul108.com/) and with chrome webmaster tools I am loving it. webmaster tools are giving me the exact place to edit the css.
I did try and merge this with my global css and it broke, but I am sure that is an easy fix when I am not under time pressures.
Again THANK YOU.
I'll check it on the iphone when it is loaded. Presently, I am building it...
Mentor ,
I'm afraid that if you want to joint the mobile-device/responsive
bandwagon, then you are going to have to use JavaScript unless you want
a very simple menu or one with drop-downs that do not work well (or at
all) in touch devices.
Al Sparber - PVII
http://www.projectseven.com
The Finest Dreamweaver Menus | Galleries | Widgets
Since 1998
for now, until the staff answers, I am using my old DW - which I have been for my stylesheet as well since I find editing it much easier there
Adobe Employee ,
Lois,
Apologies for not getting back earlier. I am following up with the product team today.
Preran
Jul 21, 2013 Jul 21, 2013
Hello Preran,
I was using the spry menubar widget in Dw CS6 and found it brilliant, I upgraded to Dw CC lately (Took a dive in at the deep end) so it seems. I am as confused as many other users that there was not a JQuery UI widget available to step in to the shoes and out perform its old predecessor. At the moment in this respect Dw CC is in reverse gear it seems to me. I am lucky because I can open the old sites in Dw CS6 and insert spry that way but that’s not the point. I can’t get my head around the omission of such brilliant functionality. I really do hope that there is a jQuery UI menu bar widget in the making and available soon. A CC membership is not cheap.
What do others think?
Imelda Martin.
Participant ,
I manged to get the add in from Ajatix working, but its limited with functions unless you pay for them. And I am thinking most would agree with me when I say using something native to Adobe DW far beats any most widgets.  Plus as Imelda say pefectly, Adobe CC membership is not cheap, so having this fucntion removed makes no sense.
We are almost a month beyond when we were told the answer would be provided. I hope we can get an update very soon.
Jul 22, 2013 Jul 22, 2013
Hi Preran, We are all waiting on this, any response on a fix yet? This is a huge omission.
Thank you, jkibbe
Adobe Employee ,
Hi jkibbe,
I understand. I rechecked with the product team today. They have asked me to wait. Will update as soon as I have an answer.
Preran
Jul 23, 2013 Jul 23, 2013
We all look forward to it! Thank you.
I too, am curious, and would like to know the reason behind, why Adobe choose NOT to include the jQuery UI Menu Widget when they inculded 8 of the 11 existing widgets.
Dennis
honestly, after trying this for the intro price for the first year, I am finding only the upgrades to photoshop worth anything. I am sticking with my old dreamweaver. When the year is up, and it is time to renew, I am likely to purchase photoshop and drop creative cloud all together if it remains this unimpressive. I do think  I made a big mistake siging on with it
