I've bought a bundle of photoshop + premiere elements. photoshop elements works fine, but
premiere elements does not start after installation without errors.
I already tried test version and registered version ( w and w/o serialnumber)
I tried double klick on the link, on the orig. file, and as admin - nothing happens on the screen 😞
I looked for the service "FLEXnet..." it's "manuell" and started several times "LicenseRecovery109" (w and w/o the 0 at start point) before and after a reboot: nothing happens 😞
I also tried the installation without "windows defender": nothing happens 😞
Using win8-64bit on an intel core i3 with 8GB RAM
Has anybody any ideas????
The solution is absolutly and totally crazy:
My usual login konto was an admin konto. Here I tried to install photoshop elements and premiere elements.
Photoshop elements was working fine - premiere elements could not be started.
So I created a new admin konto and changed my usual login konto to "standard",
installed the program in the new admin konto, set the property "run as administrator",
and now I can start the program from my usual (standard) konto by inserting the admin password.
attach a screenshot of the error message you see.
Avus53 please see http://forums.adobe.com/docs/DOC-2324 for information on how to post an image.
There is nothing to see as I wrote: "nothing happens on the screen"
you wrote, "premiere elements does not start after installation without errors" which means it starts with errors.
but, if that's not true, open the directory with photoshopelements.exe, right click it (not a shortcut) and click "run as administrator".
O.K. my english isn't perfect. I meant "an installation w/o errors" but I also wrote:
"I tried double klick on the link, on the orig. file, and as admin - nothing happens on the screen :-("
and I also set the property "run as administrator"
additional:
sometimes I can see a process "adobe premiere elements 11" in the task manager for less than 1 sec
Ok, I know this is 6 years after the post was made and answered, and i know that at this point Premiere Elements 11 is irrelevant. But. For the strange ones like me here's an easier solution that might work.
I had the exact same problem and it was because my computer had set up the wrong "paths" for the pictures, documents, music, and videos sub-categories which didn't allow premier to start. Here's how i fixed it:
Again, i know this is 6 years late, but this is the first link that pops up in google when you look up this issue so i thought i might share it in case there are other strange people using premiere elements 11 in 2019.
