5
"This project contained a sequence that could not be opened".
Guest
Oct 10, 2012 Oct 10, 2012
Hi everybody,
Well I have a big problem here, with my software Adobe Premiere Pro CS6. There is a project very important to me, on which I have been working for two monthes now... I can't open it.
Everything worked fine untill this evening. Now, when I want open it, it loads and there is a message on which is written : "This project contained a sequence that could not be opened. No sequence preview preset file or codec could be associated with this sequence type.".
I have tried the solutions proposed on http://helpx.adobe.com/premiere-pro/kb/missing-sequence-presets.html : I disactivated and reactivated my Premiere Pro CS6, and I "re-created the Adobe Premiere Pro preferences and plug-in cache" (at the least, I pressed alt + shift during the loading screen of Premiere.. I had no sign that anything was done or changed because the software started as usually, but I suppose it's normal).
So, since it seems that there's no further solutions or ideas to resolve the problem, I want, at the least, find a way to recover the huge cutting work on which I
thoroughly strived during the whole last weeks.
According the error message, there is ONE sequence that doesn't work. It means that the great majority of my sequences are clean. How can I recover them in a way I can edit them again on Premiere ?
Thanks.
PS : sorry if there are mistakes in my words, my maternal language is french.
359.8K
Adobe Employee , Oct 23, 2012 Oct 23, 2012
Advocate ,
Try this solution.
Create a new sequence that has same attributes as the old one.
Open the old one and copy the entire timeline.
Go to your  NEW empty sequence and paste .
Mar 02, 2015 Mar 02, 2015
YOU ARE A GENIUS!!! WE CANNOT OPEN SEQUENCE!!! HOW xxxxx CAN I COPY TIMELINE???
u are not smart
Oct 04, 2015 Oct 04, 2015
Hi everyone, have you had success by now?  Now I'm in this mess, wasted my whole weekend trying uninstalling windows, using recovery tool to uninstall Premier, reinstalled it, did the sign out, did the ALT+Shift, disabled my firewall and windows defender, no success whatsoever.  Also tried opening a new sequence and importing the old one but although it loaded onto the new sequence, the OK button did not highlight, only the Cancel button highlighted.  What is the way forward.  I would buy a new computer just to solve this problem but have heard that people experience the same problem on new computers as well.
Enthusiast ,
What version of Premiere are you using?  6.0 or 6.0.1 or 6.0.2 or 6.0.3?
Also sometimes this problem occurs when you used a customized sequence in the project but this sequence/codec is no longer installed is this possibly the case? For example did you have any capture cards installed that aren't installed anymore? Did you recently re-install your OS or remove codecs or make any system changes?
Also from what I have read another quick work-around for this issue is to open the Premiere Pro Project up inside Notepad ++ and change all instances of the current preview codec from I-Frame Only MPEG to Microsoft AVI. Because some other people have said this solution works in some cases. However I'd only do this as a last resort. This solution will only work though if the problem was being casued by the I frame only mpeg preview codec option though which isn't always the case. So this might not work anyways. I'd honestly recommend just re-installing though if you've already tried to deactivate and you personally already know that you weren't using I frame only mpeg as a preview choice and you also know for a fact you haven't uninstalled any capture cards recently or any codecs. If you do uninstall though, use the adobe cleaner tool when doing so.
http://www.adobe.com/support/contact/cscleanertool.html
Guest
Thanks you both for your fast answers !
ComputerNovice25, I edited my project on notepad ++ as you told me, and now it works really great. I can open it again ! Thanks you.
Best regards !
Enthusiast ,
Glad to hear it worked, looks like this problem has been solved!
Sadly though I don't know what caused it, other than something has obviously gotten corrupted. I'd recommend uninstalling and then using then adobe cleaner utility for a perm fix.
Not really.  His MPEG codecs still aren't properly activated.  That could cause other issues in the future.  The Notepad edit is more of a Band-aid than a solution.
Enthusiast ,
Well yes and no, we know what the problem was now so, in that since it's solved. Sadly though like you very correctly stated it's not a perm fix at all. Which is why I recommended a clean install for the perm solution. So the problem has been solved, a solution hasn't fully been provided yet. Only a suggestion on how to get there.
I suppose it's a matter of semantics, really.  But the problem was unactivated MPEG codecs.  A work around was found, but that problem hasn't really been solved.
Enthusiast ,
You're correct the source hasn't been solved. Only the cause disovered. So I guess I should have technically said "looks like we have solved the cause of this problem".
(Even though that is not technically fully solved because the cause of how exactly it was corrupted is still unknown)
Guest
Oct 11, 2012 Oct 11, 2012
Hi again !
Is that what we could call an Adobe Philosophy ?
Well now I have another problem xD Each time I open my project, I get the error message... so each time I have to edit it with Notepad ++ and each time I lose every renders.
Is there a solution to definitely tell Premiere to make the renders on "Microsoft Avi" instead of "I-Frame" ?
Enthusiast ,
Like I mentioned earlier you're going to need to uninstall the suite, then run the cleaner utility. Then reinstall, unless someone else knows how to fix the issue that caused the corruption in the first place. Which I have no clue how it managed to get corrupted, I just know that somehow it did. That's why that problem is solved (meaning knowing what exactly the problem was), since we know it's corrupted, sadly though I still have 0 clue why.   I'd really just recommend the uninstall option. It's by far the fastest solution IMO because you could end up spending hours/days trying to work around a issue that can be fixed by a fresh re-install (most of the time). I've fallen in this trap myself before.
Just make sure to follow the steps listed from the link I posted in my earlier post.
If you really want  avoid a fresh install though. (Which I'd strongly recommend doing instead of doing what I'm about to say)
You can technically create a customized sequence that is using a different codec for preview, then paste your old sequence into the new sequence then delete your old sequence which was using the I-frame only mpeg for previews, then click save as  and name the project w/e you want then use the project which only contains the good sequence which is using a different/ your newly selected preview codec.
Hi all,
I've recently run into this issue as well. My client gave me a 2TB external with a mess of PProCS6 projects, and I cannot get a single one of them to work.
System:  Win7/64 Ultimate
i7-2760QM
32gigs Ram
3gig NVidia 560m
First attempt to fix was the notepad workaround. Unfortunately each project file ranges from 300mb to 600mb (rounded, obviously). Not only did the rename process take upwards of 15 minutes to complete on the seemingly massive text docs, but I still received the error.
Next attempt was to completely wipe CS6 off my system, and follow up with Adobe Cleaner. Ran Cleaner 5 times back-to-back, reinstalled Master and still have the issue.
What gives?
Additional info, I have tried in CS6.0.0 & .0.3, and both on my Macbook Pro & Win machine. Moreover, since uninstalling/reinstalling, I cannot access my deactivate or update buttons in any of my CS apps....
Enthusiast ,
What preview codec was the project previously listed as using?
I-Frame on the Mac, but I-frame is gone on my PC. If I could just get I-Frame on the win computer, I would be gold. I have been able to open one of the files on my mac, but the workhorse is my PC--so, Im still stuck in a rut...
Enthusiast ,
Okay so obviously you've attempted to reinstall and it didn't work. Very strange scenario going on here, usually that fixes the problem. However when you start Premiere Pro up now does it say anything about using a trial version? Because it it sounds like your not activated still. Try disabling your firewall, and see if it activates. Your "deactivate" should stop appearing as greyed out if it works.
Enthusiast ,
Also if the firewall option didn't work try the following solutions as well.
Although it sounds like you already have done at least one of the suggetions from this link so please ignore if you have.
Mar 20, 2013 Mar 20, 2013
Could a Disk Defrag cause this scenario?  I just came on here with the same issue as described at the top of the chain and the ONLY thing I have done between the time my project worked and the time that it didn't (with the aforementioned issue) was perform a Disk Defragmentation.
Dec 31, 2012 Dec 31, 2012
I had this same issue with a CS5.5 project - I swapped out the I-Frame Only MPEG with Microsoft AVI and everything worked fine after that.  Thanks.
Jul 07, 2014 Jul 07, 2014
Thx VERY MUCH. This realy Works, and save our life. Once more THANKS VERY MUCH!
Jan 28, 2015 Jan 28, 2015
Same issue here.
Day before everything worked fine...
Clean new install of premiere did the trick. Next time I will also try the signout and in of the Adobe Creative Cloud..
But for now I can go on... pfiew
Aug 23, 2016 Aug 23, 2016
WOW! I cant believe that worked!!!! Thanks!!
Guest
Nov 22, 2016 Nov 22, 2016
You didn't answer the TheMtyThor question: how the hell can we edit *.prproj files in the notepad++???
It shows only a mess like this:
|ß ľdq( ',đ Ý7†|ÓÚď ˙˜Ju˙ ć ó¦F*›$jĽönŮŹź őůf"&ęňU2^í Zé• ˇÇ‰ ƒ@   A 0î1 ‹X?€\aO=*± ˛‘ŠŽT”Z-tńr(Ő—??ň–Ĺ÷řE’Ť'O¤OBě1
â˜)@`@Ač+ @?
i R
úřjVvYőFEéP®OËěíUą'[u ®uŃŁ A Ö SĐ Dy „Ä'   …QŔ" E‹.˘ ]\1®›„ čAŤ0 ˇF]l&9 B Bîƒ QO
p†Ů*ôîçďy:˜Ţ
Ç« ĘűŤWú˝ ·—×-g°Şf-Ő7Yr› Ĺ@—ńć@Ĺ_‹? ÔW(Ô¶ň, ę× VTź˝şŻ©>éWćőĺĎÉ8     ęI, cej®żşgčp˘†9ŐËWbś˙CÉ'ş»5o  _jčäďŢ˜Ţ…C‘ .o’ßÔ HuÝş—‹ĘfúŞŢëŞuŻšÚÍÁ9É¦ŞşĺÂňŞ˘ź ˜3«öý‚ŔMšM.ß ĺ˝˝˙Qx}ťdzŞ4x—eîź
ÎđśŻęeŃŐgEÜ›ľÍ§e|9_ Oˆ™ŞÚ·kĂţQÜ©Yů_ 9ůP`yů]Ýzo±ÜQ§ËťlXîí¤á®Ë}Gar’Ë ynąźËrżoweˇăUă
FÇµ5‰©Ś azµ3dô ¦>•8 ŇG•vŮ|ˇW˝[ĽĽ7ĎV% ˝— ĺ‚°PĐŻ/ˆ
ƒú‚¸PŐ $…‚Ľľ - „^}IżX Ö— Š%Q}IV,‰ëKňbIŇŔőâüŔ¦    *Î l˜"Xś#Ř0I°8K°aš`qž`ĂDÁâLˇ†™‚Ĺ©B
S ‹s… ć
' 5L ,Î j˜-Tś-Ô0[¨8[¨iA g 5Ě *Î j˜-Tś-Ô0[¨8[¸a¶Pq¶pĂlˇâlá†ŮBĹŮÂ
ł…Šł… f  g 7Ě .Î n˜-\ś-Ü$ ‹ł…Wfkˇ––ľŕŠšjT äa  nZô…’¤    EĹ’
*r4`¨ wŇ ˇ"ÚI ‚Š`'
*bť4ৠuŇ ź"ŇI“d.N iš¤â,Ń&É\ś&Ú$™‹óD›$sq˘h“d.Î mŇŁĹ©˘Mz´8W´IŹ '‹6éŃâlŃ&É\˛Éš$sÉ*kZSĹŮň›$sq¶ü&É\ś-żI2 gËoŇŁĹŮň›ôhq¶ü&=Zś-żIŹ gËßR2ß» +’™®HfŹ’@;˝ DŚp@ü  ˇĐ><ˇŠKIą
›$sîl<1-šź=)•Ň îâ_ĂI– ÇItY¨´â Ďź,|łŐźĄ"ů(VĘĚ~—› ˙H©† Ď°ü¸T|ć2ĺîoáÉ‚Ç÷ ]<z%B5Xc˛żĘäE‘ !ĐĘN  ’  !9 (Ś b ĆDlfrŢNK.Ďăö_ß«/“ËbĹ=8
;ŕ4¬ĺô
So how to "change all instances of the current preview codec from I-Frame Only MPEG to Microsoft AV"??
You have to be more speciffic.
Please help.
I have the same issue and I don't understand your workarround.
