Here's my dilemma.I have a form with a radio button list. The list is located in one section of the form. There are two options available. It is currently set so the user has to select one or the other button. I need to add the ability for the user to deselect a radio button in this section if he/she didn't intend to complete this section. How do I do that? I'm not real familiar with adding JavaScript codes to forms so step-by-step instructions would be really helpful.
Have a look at this example: http://assure.ly/j1KdNq. It works on the basis of the user holding the Shift button while clicking the radio buttons. Obviously the user will need an instruction on this.
Hope that helps,
Niall
Total Likes
A simple work-around that I have found helpful is to use two checkboxes instead of a pair of radio buttons. You can use the action builder to create actions so that when one is checked the other is set to null or unchecked. This way, they function like radio buttons but you retain the ability to deselect them. You can then change them to appear as sunken circles so that they do not look any different.
Thank you for the workaround. It sounds like a perfect solution. How do I create the actions to set the other box as null or unchecked?
Total Likes
Here is how to build your actions:
Add two check boxes to your form. It is helpful to name them in the hierarchy for ease of use.
Right click on checkbox 1 and select Actions>Add Action. The Action Builder window opens.
Under CONDITION, set the condition to be "When CheckBox1 is checked" by choosing "is checked" from dropdown. If you opened the Action Builder window without right clicking on the CheckBox object, then you will also need to define which object you are editting
In Select a Result Dropdown, choose "Set the Value of a Field" and select CheckBox2 from hierarchy (a window opens to display the heirarchy to select an object from)
Change the result field dropdowns to be: Set the value of CheckBox2 "TO BE" "UNCHECKED"
Repeat these actions for the second CheckBox.
Afterwards, select each checkbox, and in the Object window, select the Field tab. From there, there is an Appearance dropdown. Use that to select the appearance of your CheckBox. I believe that Sunken Circle is the standard appearance for radio buttons
Total Likes
That worked like a charm. Thank you so much!!!! I really appreciate your help.
Total Likes
Radiobuttons are based on an exclusion group. one will be always selected as they are mutually exclusive. Sounds like the checkBox solution is the right one here for this use case, as you can select multiple, one, or none. You could also provide a third choice representing "no selection".
KJ
Total Likes
I Im currently building a form with multiple radio button groups with child radio button groups and have it working
example scenario
a checkbox to say user wants that section ( if unchecked clears all radio buttons)
if a user clicks a child it must turn on the parent etc
so here is some code examples I used
on the radio button group under change
if ( pg1.suby.subrad.rawValue > 0 )
then
pg1.rad1.rawValue = 1
endif
if ( pg1.rad1.rawValue > 1 )
then
xfa.host.resetData("xfa.form.form1.pg1.suby.subrad")
endif
basically if subrad has any value then rad 1 needs turned on
if the paren is set to anything but one the reset this sub group
if you need a full example of a parent with 3 choices each with a 3 child choices and master check box let me know i figured that short exerpt should sufice though
Total Likes
