Hi Guys,
I am new to coldfusion and facing issue with the websites.
Frequently I am encountering 503 errors for my websites sites.
Apache error_log shows below errors at the time of 503 errors:
[Thu Aug 15 14:56:11 2013] [notice] jrApache[12343: 16314] JRun will not accept request. Check JRun web server configuration and JRun mappings on JRun server.
[Thu Aug 15 14:57:26 2013] [notice] jrApache[10249: 30633] JRun will not accept request. Check JRun web server configuration and JRun mappings on JRun server.
[Thu Aug 15 14:57:27 2013] [notice] jrApache[11269: 14799] command error: 104 Connection reset by peer <- [28]
[Thu Aug 15 14:57:27 2013] [notice] jrApache[11269: 14799] returning error page for 104 Connection reset by peer
[Thu Aug 15 14:57:27 2013] [notice] jrApache[21458: 51935] command error: 104 Connection reset by peer <- [28]
[Thu Aug 15 14:57:27 2013] [notice] jrApache[21458: 51935] returning error page for 104 Connection reset by peer
[Thu Aug 15 14:57:27 2013] [notice] jrApache[9210: 52959] command error: 104 Connection reset by peer <- [28]
[Thu Aug 15 14:57:27 2013] [notice] jrApache[9210: 52959] returning error page for 104 Connection reset by peer
[Thu Aug 15 14:57:27 2013] [notice] jrApache[8091: 51679] command error: 104 Connection reset by peer <- [28]
[Thu Aug 15 14:57:27 2013] [notice] jrApache[8091: 51679] returning error page for 104 Connection reset by peer
[Thu Aug 15 14:57:27 2013] [notice] jrApache[21260: 15823] command error: 104 Connection reset by peer <- [28]
[Thu Aug 15 14:57:27 2013] [notice] jrApache[9209: 52703] command error: 104 Connection reset by peer <- [28]
[Thu Aug 15 14:57:27 2013] [notice] jrApache[9209: 52703] returning error page for 104 Connection reset by peer
[Thu Aug 15 14:57:27 2013] [notice] jrApache[28106: 15567] command error: 104 Connection reset by peer <- [28]
[Thu Aug 15 14:57:27 2013] [notice] jrApache[28106: 15567] returning error page for 104 Connection reset by peer
[Thu Aug 15 14:57:27 2013] [notice] jrApache[21260: 15823] returning error page for 104 Connection reset by peer
[Thu Aug 15 14:57:27 2013] [notice] jrApache[3831: 14031] command error: 104 Connection reset by peer <- [28]
[Thu Aug 15 14:57:27 2013] [notice] jrApache[3831: 14031] returning error page for 104 Connection reset by peer
[Thu Aug 15 14:57:27 2013] [notice] jrApache[21264: 14543] command error: 104 Connection reset by peer <- [28]
[Thu Aug 15 14:57:27 2013] [notice] jrApache[21264: 14543] returning error page for 104 Connection reset by peer
[Thu Aug 15 14:57:27 2013] [notice] jrApache[30125: 53215] command error: 104 Connection reset by peer <- [28]
[Thu Aug 15 14:57:27 2013] [notice] jrApache[30125: 53215] returning error page for 104 Connection reset by peer
[Thu Aug 15 14:57:27 2013] [notice] jrApache[9216: 60810] 127.0.0.1:51800 connect failed[28]: 111 111 Connection refused
[Thu Aug 15 14:57:27 2013] [notice] jrApache[9216: 60810] returning error page for 111 Connection refused
[Thu Aug 15 14:57:27 2013] [notice] jrApache[12363: 11782] 127.0.0.1:51800 connect failed[28]: 111 111 Connection refused
[Thu Aug 15 14:57:27 2013] [notice] jrApache[12363: 11782] returning error page for 111 Connection refused
Below is my Jrun settings in httpd.conf file:
# JRun Settings
LoadModule jrun_module /opt/coldfusion9/runtime/lib/wsconfig/1/mod_jrun22.so
<IfModule mod_jrun22.c>
JRunConfig Verbose false
JRunConfig Apialloc false
JRunConfig Ignoresuffixmap false
JRunConfig Serverstore /opt/coldfusion9/runtime/lib/wsconfig/1/jrunserver.store
JRunConfig Bootstrap 127.0.0.1:51800
JRunConfig ConnectTimeout 1500
AddHandler jrun-handler .jsp .jws .cfm .cfml .cfc .cfr .cfswf
</IfModule>
Below are the loaded jrun modules:
# httpd -M | grep jrun
core_module (static)
mpm_prefork_module (static)
http_module (static)
so_module (static)
auth_basic_module (shared)
auth_digest_module (shared)
authn_file_module (shared)
authn_alias_module (shared)
authn_anon_module (shared)
authn_dbm_module (shared)
authn_default_module (shared)
authz_host_module (shared)
authz_user_module (shared)
authz_owner_module (shared)
authz_groupfile_module (shared)
authz_dbm_module (shared)
authz_default_module (shared)
ldap_module (shared)
authnz_ldap_module (shared)
include_module (shared)
log_config_module (shared)
logio_module (shared)
env_module (shared)
ext_filter_module (shared)
mime_magic_module (shared)
expires_module (shared)
deflate_module (shared)
headers_module (shared)
usertrack_module (shared)
setenvif_module (shared)
mime_module (shared)
dav_module (shared)
status_module (shared)
autoindex_module (shared)
info_module (shared)
dav_fs_module (shared)
vhost_alias_module (shared)
negotiation_module (shared)
dir_module (shared)
actions_module (shared)
speling_module (shared)
userdir_module (shared)
rewrite_module (shared)
proxy_module (shared)
proxy_balancer_module (shared)
proxy_ftp_module (shared)
proxy_http_module (shared)
proxy_connect_module (shared)
cache_module (shared)
suexec_module (shared)
disk_cache_module (shared)
file_cache_module (shared)
mem_cache_module (shared)
cgi_module (shared)
version_module (shared)
ssl_module (shared)
proxy_ajp_module (shared)
jrun_module (shared)
Syntax OK
Please suggest me to fix this issue.
Thanks & Regards
Kalyan Pasupuleti
Hi Kalyan,
Thank you for posting your query.
Could you please give us some more information about the CF version, Apache version and Linux.
Priyank
Hi Priyank,
Thanks for your quick reply.
Coldfusion Version is 9
Apache Version is : Apache/2.2.3
OS: CentOS release 5.7 (Final) - 32Bit
Thanks & Regards
Kalyan Pasupuleti
