Every time I try to install Elements I get the error indicated. Thenh the intall program backs out the install. Any help you can give would be appreciated. I am running WIN 8 with all updates applied.
Thank you very much.
Hi jhboston1,
Please follow the steps mentioned in the kb: http://helpx.adobe.com/creative-suite/kb/error-1935-assembly-component-microsoft.html and let us know whether it worked.
Romit Sinha
Jhboston1 which version of Photoshop Elements are you trying to install?
Hi jhboston1,
Romit Sinha
After mucking about with some things, I found the problem was with the install of Net Framework. I had to re-register some things, and recovered the Net Framework. Then Elements 10 installed correctly. Thanks so much for your responses. They also were a help.
John
