I am trying to set my streams locked to only certain domains. As long as I leave it wide open my player plays the content fine. Once I set a domain I get "We are having problems with playback. We apologize for the inconvenience. Below is my current cross domain file.
<?xml version="1.0"?>
<!-- http://mydomain.com/crossdomain.xml -->
<!DOCTYPE cross-domain-policy SYSTEM "http://www.macromedia.com/xml/dtds/cross-domain-policy.dtd">
<cross-domain-policy>
<allow-access-from domain="*www.mydomain.com" />
</cross-domain-policy>
Hello, change it to mydomain.com (no www). For subdomains - dev.mydomain.com.
Changed it as requested and still get the same error.
Have your XML file look like this
-<cross-domain-policy>
<allow-access-from domain="mydomain.com"/>
Still getting the same We are having problems with playback. We apologize for the inconvenience after the change of the xml
Must crossdomain.xml be in the website root or webroot of AMS?
It should be under C:\Adobe Media Server 5\webroot\crossdomain.xml.
Yeah, when I put it in there I just get the same error
Nothing else can be done to make this work?
This is a modified version of crossdomain.xml policy file. Try it and if it doesn't work, you might have some third-party configurations going on.
<site-control permitted-cross-domain-policies="master-only" />
<allow-access-from domain="*.osmf.org" />
<allow-access-from domain="*.adobe.com" />
<allow-access-from domain="*.macromedia.com" />
<allow-access-from domain="*.yourdomain.com" />
