inability to open an docx file sent as an email attachment
Guest
Aug 22, 2013 Aug 22, 2013
After receiving an email with a docx file attachment, I was unable to open it. The error message says, Adobe Reader cannot open ....docx either because it is not a supported file type or the file has been damaged (for example, it was sent as an email attachment and wasn't correctly decoded). This is a very important document and more may follow soon. Should I uninstall Adobe Reader, then try to open the document ansd save it to the computer before reinstalling Adobe?
34.8K
No, doing those things will not fix the problem. What version of Microsoft Word, if any, do you have installed?
Guest
Microsoft (Office) Word 2010 Starter. I've never had a problem using .docx before.
You need to fix your file associations:
  • .doc, .docx must point to Microsoft Word
  • .pdf must point to Adobe Reader
Guest
Aug 23, 2013 Aug 23, 2013
Thanks, but I'm not very handy with troubleshooting. How do I fix file associations? I'm now also getting script errors constantly.
Guest
I've checked the control panel, default options and they seems to be set at Microsoft for .docx and Adobe for .pdf. What can I try next? These files are really important.
Right click a .docx file and choose "Properties"
Under the General tab, where it says "Opens with" there is an app listed.
If it's NOT Word, click "Change".
Select Word from the list of recommended apps or click Browse and navigate to the C/Program FIles/Microsoft Office/Office14 folder and choose WinWord.exe
Click Open, click Apply and click OK.
That should set Word as the app for .docx files system wide.
Guest
I tried to follow these instructions but when I got to Microsoft Office/Office 14 folder there was no WinWord .exe to choose. I entered this in File name but it said the file could not be found. Was there something wrong in my sequence?
Try C/Program FIles (x86)/Microsoft Office/Office14 instead.
Guest
The .docx file I chose was the won I cannot open. I had downloaded it to documents but it still won't open. After trying the new suggestion (Program Files (x86)/Microsoft Office/Office 14) a file search came up empty. Tomorrow, I'll try to contact Microsoft to find out why. Thanks for your help. I'm sure if I ever manage to locate WinWord.exe it will work.
Can you open it in the normal way - start Word, use File > Open?
Guest
It isn't found in Word. I assume that 's because it never opened. When i saved it to documents, It was still unopened.
If it isn't found in Word, you must be doing File > Open wrong.
I'm not asking you to choose it from the list of recent files, but to choose OPEN, then find the folder with the file in it, and select the file. If the file isn't shown, then it isn't a DOCX file at all.
When I write File > Open, in Word this means Choose the Open command from the File tab menu . The File Open dialog box is then shown.
Guest
Aug 24, 2013 Aug 24, 2013
When I hit file, then open, the file I'm looking for isn't there. I'll ask the sender how he sent the original file.
If the file doesn't show up, either you aren't looking in the right place, or it isn't a DOCX file. Try using Files of type: ALL FILES in Word.
I think it's time that someone asks you what your Windows version is.  The procedure to change file associations is slightly different for some versions.
Guest
My version is Windows 7.
Use this method to change file associations in Windows 7: http://windows.microsoft.com/en-us/windows7/change-which-programs-windows-uses-by-default
If you still have difficulties locating the WINWORD program, you should find it
  • Office 2010 64-bit edition: C:\Program Files\Microsoft Office\Office14
  • Office 2010 32-bit edition: C:\Program Files (x86)\Microsoft Office\Office14
Guest
I tried both but neither opened WinWord.exe. The dialog box said the file name didn't exist.
Sorry I'm lost. Where are you trying to open winword.exe and why?
Guest
I was trying to open a .docx file (the one in question), choose properties, then under the General tab where it says open with, change it from Adobe reader to Microsoft Word (Starter 2010).
Can you post a screenshot of that?  I am really not sure what you are doing.
Guest
Aug 25, 2013 Aug 25, 2013
I haven't been able to post a screenshot but I followed the directions in reply #6 (from C F McBlob).
This must be the longest topic for a very simple Windows operation...
See this how to post a screenshot: http://forums.adobe.com/thread/1070933
