Run Photoshop in 32-bit mode (64-bit Mac OS only)
Aug 21, 2012 Aug 21, 2012
This question was posted in response to the following article: http://help.adobe.com/en_US/photoshop/cs/using/WS82af097c4236e2eb70aae8412fa75dc285-8000.html
38.0K
Adobe
don't knwo how to select Open In 32-bit Mode. would you please help us?
Advisor ,
In 64-bit versions of Mac OS 10.5 and later, some older, optional plug-ins are available only if Photoshop is running in 32-bit mode:
  1. In the Finder, choose Go > Applications.
  2. Expand the Photoshop folder. Then right-click the Photoshop application icon, and choose Get Info.
  3. In the General section of the Info window, select Open In 32-bit Mode.
  4. Close the Info window, and restart Photoshop.
Aug 22, 2012 Aug 22, 2012
thank you very much for yout help .but when i follow the step3 ,there is no In 32-bit Mode for me to select .would you help to check this agian ?thanks you very much.
What version of photoshop?
What version of OS X?
version of photoshop:both CS5 and CS6
OS X:10.6.8 64-bit
Could you please post a screenshot?
on my mac,no such options.how to make it display?
the screenshot is same as yours except the option.
maybe it's my CS's prooblem ,like station_two said.
In CS6, there is indeed no such option, because there is not a 32-bit version of CS6 for the Mac.  CS6 is only available in 64 bit for the Mac.
The only version that will give you that option on the Mac is CS5.
There is no such option in CS4, because that version was only 32-bit on the Mac.
actually when i use CS5, it still no such option .whether it is the Mac 10.6 64Bit or 32bit.
i just want plug-in a scanner,what should i do ?Help...
That option is there in Photoshop CS5.
Make sure you selected the APPLICATION and not just the folder that the application resides in.
how silly of me ,i found this option ,
as you said ,i fond this option by select the folder ,not the application ,
thank you vvvvvvvvery much!
Do you know why i still can't plug-in a scanner?
on 64-bit Mac OS ,32-bit mode Photoshop.and i have download the plug-in file .
thank you very much for the help ,i think i can solve this problem in another way .thank you .
Guest
Sep 26, 2012 Sep 26, 2012
Go to Applications - Choose Adobe Photoshop CS5 - Choose Adobe Photoshop CS5 - Then Click "More Info" button below the application Icon - Check the Open in 32-bit Mode Option- Close the window - Open Photoshop
Sep 27, 2012 Sep 27, 2012
thank you for your help.^^
Guest
Sep 10, 2013 Sep 10, 2013
Same here -- no 'Open in 32-bit mode' option for me to select, and I am doing the Command-I on the CS5 app icon, not the folder. Screen shot attached. Suggestions welcome! Lighting effects is a great tool.
Guest
Dec 04, 2012 Dec 04, 2012
I have the same problem trying to run the mac on 64 bit but don't see the option
Adobe Employee ,
Only Photoshop CS5 included the option to run in either a 32-bit or 64-bit mode. Are you running Photoshop CS6?
regards,
steve
Guest
Yes, however I cannot change it to run in 64 mode, how do I do it?
Adobe Employee ,
OK, I'm not following what problem you're having. You have Ps CS6 installed, what are you trying to change for running in 64-bit mode?
thx-steve
Guest
Ok, so I need to run picture package, but I read I have to change the mode of my mac to run this plugin.
Apparently I can run this application to print 2 12X16 frames side by side on a 44"X35" canvas roll.
Adobe Employee ,
Hi, Picture Package is not available or compatible with Ps CS6. Take a look at File> Automate> Contact Sheet II... which was reintroduced as a shipping command in Ps CS6.
Guest
Yes, just did it says; this functionality may not be available in this trial version of photoshop. Completely lost at this point.
Sent from my BlackBerry® wireless device
